      02-11-2015, 01:18 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Post 2016 BMW ALPINA B6 xDrive Gran Coupe gets 600 HP and styling update
BIMMERPOST NEWS
The updated 2016 BMW ALPINA B6 xDrive Gran Coupe
192
COMMENTS
2016 BMW ALPINA B6 xDrive Gran Coupe Updates:
  • Revised front fascia
  • Revised front spoiler
  • Revised hood
  • Revised kidney grilles
  • 4.4L V8 now delivers 600 HP @ 6000 RPM / 590 LB-FT @ 3500 RPM (+60 HP over 2015 model)
  • 0-60 MPH in 3.6 seconds (preliminary)
  • Blue brake calipers with ALPINA lettering. Rear brakes are now 370 x 24 mm (increased from 345 x 24 mm)
  • Standard equipment now includes Full LED Adaptive Headlights with High Beam Assistant, and new B6 model designation in the B-pillar in high-gloss Shadow Line
Woodcliff Lake, N.J. February 11, 2015… The new 2016 model year BMW ALPINA B6 xDrive Gran Coupe gains subtle BMW enhancements and benefits in particular from the results of continuous development by ALPINA. The four-door Gran Coupe, already widely recognized for aesthetic beauty and impressive driving performance, raises the benchmark with exciting new details. The new BMW ALPINA B6 xDrive Gran Coupe will become available to order starting in March 2015, with US deliveries slated to begin at BMW Centers in June. Pricing will be announced closer to the on-sale date.
The BMW ALPINA B6 xDrive Gran Coupe is available as a special-order vehicle with capacity-limited production underscoring its exclusivity. The B6’s body is manufactured in the BMW 6 Series factory (Plant Dingolfing) and hand-finished with the remaining ALPINA components at the ALPINA factory in Buchloe, Germany. The hand-finishing sequence at ALPINA increases the production lead-time by approximately two weeks. European Delivery at the BMW Welt delivery center is available for the BMW ALPINA B6, as is BMW Performance Center Delivery in Greer, SC, USA.
A more-dynamic front spoiler and fascia enclose the subtly-revised BMW kidney grill, and shape the transition to the new ALPINA hood which features character chines, lending the new B6 xDrive Gran Coupe an even more powerful appearance and accentuate its class-leading performance potential.
The 4.4 liter V8 Bi-Turbo V-8 engine – known amongst aficionados as the embodiment of power, torque and refinement – now delivers an astonishing 600 horsepower at 6,000 rpm and maximum torque of 590 lb-ft at only 3,500 rpm (all figures preliminary). The increase in output of 60 hp over the 2015 model has been achieved through extensive rework of the air intake ducting and air filter housing, with enhancements to the fuel supply system. Coupling the BMW xDrive intelligent all-wheel drive system with an ALPINA-developed performance calibration means the new B6 xDrive Gran Coupe delivers heroic straight-line performance. With a 0 – 60 mph acceleration time of only 3.6 seconds (preliminary), it is the fastest-accelerating BMW ALPINA model ever developed. The new B6 xDrive Gran Coupe is capable of a maximum speed of 200 mph (electronically limited).
The ALPINA sport suspension utilizes BMW’s advanced electronic suspension technologies including Dynamic Damper Control (adjustable, adaptive shock absorbers) and Adaptive Drive (Active Roll Stabilization), which work together with the fully-variable torque distribution of the all-wheel drive system to achieve very neutral, agile driving dynamics.
The powerful brake system now features blue calipers with ALPINA lettering on the front axle with brake discs measuring 374 x 36 mm on the front and 370 x 24 on the rear (increased from 345 x 24 mm).
The standard equipment level has been extended to include attractive features such as Full LED Adaptive Headlights with High Beam Assistant, and a discrete new B6 model designation in the B-pillar in high-gloss Shadow Line.
Refined performance with powerful delivery.
Continuous development of the 4.4 liter V8 Bi-Turbo V-8 engine has resulted in a number of upgrades leading to a significant increase in power output in the new B6 xDrive Gran Coupe. The engine now develops 600 hp at 6,000 rpm and a maximum torque of 590 lb-ft between 3,500 and 4,500 rpm (preliminary figures).
Two specifically-constructed, large-diameter turbochargers, operating in parallel, are primarily responsible for achieving a high power and torque output over a very broad engine speed range, without sacrificing spontaneous throttle response at low rpm. The high-performance water-air intercooler system with a short intake distances consists of a large-volume low-temperature heat exchanger, and two near-engine intercoolers. Additional oil and water coolers are located just behind the front spoiler to ensure overall thermodynamic efficiency of the engine. Extensive optimization of the air intake ducting and air filter housing leads to a substantial reduction of losses, which together with an upgraded fuel supply system results in the hike in output of 60 hp over the previous model year.
Inside the cylinders, specific MAHLE pistons are designed to deal with temperatures and pressures associated with up to 1.2 bar (17.4 psi) boost pressure and the engine’s 10.0:1 nominal compression ratio.
ALPINA-tuned 8-speed Sport Automatic transmission.
Adapted and tested in co-operation with ZF, the advanced ALPINA SWITCH-TRONIC 8-Speed Sport Automatic transmission is perfectly tailored to the power and torque of the V-8 Bi-Turbo engine. It excels equally in the disciplines sport and comfort, playing a central role in infusing the B6 xDrive Gran Coupe with ALPINA typical characteristics.
In Automatic (D) Shift Mode, the flexible blend of eight speeds and high torque makes for smooth gear changes only a torque converter can provide. Explicitly programmed for comfort, the B6 Bi-Turbo Gran Coupe glides effortlessly and efficiently at low engine speed and tall gears, offering unmatched cruising ability.
In Sport (S) Shift Mode, the transmission becomes significantly more dynamic, gear changes are executed faster and feedback becomes more direct. The system allows for multi-simultaneous downshifts in only milliseconds, wherein the transmission will skip several gears depending on engine loads and speeds to select the most favorable gear for optimum acceleration.
The Manual (M) Shift Mode allows full driver control over the transmission. The ALPINA SWITCH-TRONIC buttons are ergonomically mounted on the rear of the steering wheel, their actuation allowing the driver to shift up or down as required. A unique feature of the transmission software in Manual (M) Shift Mode in combination with the selection of Sport+ or DSC OFF Mode using the Driving Dynamics Control button is the cancellation of automatic upshift function. In this mode of operation, the transmission will maintain the selected gear up to maximum engine speed and will not automatically upshift to the next gear. This is desirable in certain driving situations, for example during especially dynamic driving on roads with multiple tight hair-pin corners, or on race track segments featuring pronounced elevation change.
Hardware modifications to the transmission, output and driveshafts enable unrestrained power delivery. In combination with the single-cylinder fade-out and ALPINA specific software modifications, this eliminates the common reduction of torque required by the transmission in order to up-shift. This allows super-quick upshifts under full loads which, together with xDrive intelligent all-wheel drive, means the B6 xDrive Gran Coupe requires only 3.6 seconds for the sprint from 0 – 60 mph (preliminary).
BMW xDrive intelligent all-wheel drive.
The ALPINA all-wheel drive system exploits the technical potential of BMW’s xDrive system and its intelligent, dynamic distribution of drive power which continuously and variably distributes torque between the front and rear axle within milliseconds, for a maximum of traction and control.
For the BMW ALPINA B6 xDrive Gran Coupe, the programming of the torque distribution control system, which is interconnected with the Dynamic Stability Control (DSC) and engine management system, is performance-oriented and increases driving agility and dynamics – especially under lateral acceleration – while maintaining a neutral balance. Besides allowing optimum traction under acceleration by eliminating slip-induced losses, the system continuously monitors a wide range of sensory inputs – for example steering angle, lateral acceleration, yaw angle and speed - to distribute torque to achieve maximum safety in challenging conditions or when encountering sudden changes in road surface friction.
Exhaust system.
The B6 xDrive Gran Coupe features a full stainless steel exhaust system with ALPINA trademark elliptical twin tailpipes. The character of the deep exhaust note is prominent but not intrusive. Active exhaust valves allow balance between enthusiasm and comfort on long journeys. The driver can influence the sound experience using the Driving Dynamics Control button. In Comfort Mode, the exhaust valve is closed up to 2,500 rpm, and in Sport Mode the valve is permanently open.
Chassis, wheels, and tires.
BMW ALPINA automobiles place special demands on chassis and suspension – requiring high levels of comfort for relaxed cruising, light-footed and dynamic agility for purposeful driving as well as safe and neutral handling at high speeds.
The B6 xDrive Gran Coupe’s chassis and suspension technology builds upon the basis of a BMW double-wishbone front suspension and integral rear axle. Furthermore it utilizes sophisticated electronic suspension technologies including Dynamic Damper Control (adjustable, adaptive shock absorbers) and Adaptive Drive (BMW Active Roll Stabilization). This allows the driver to change the chassis and suspension settings distinctly between Comfort+, Comfort, Sport, and Sport+ using the Driving Dynamics Control rocker switch.
The ALPINA-specific calibration of dampers and stabilizers is tied into other system parameters including torque distribution, stability control, steering assistance, and throttle response.
Stiffer springs and increased front wheel camber, combined with the 20” staggered ALPINA CLASSIC wheel and tire set, result in direct steering response and precise handling. The high performance MICHELIN Pilot Super Sport tires forego run-flat technology in order to maximize comfort and they have a high speed rating to allow for the B6 xDrive Gran Coupe’s maximum possible speed of 200 mph. The dimensions of the rear wheel and tire have increased to 10” x 20” and 295/30 ZR20 for improved traction while the front dimensions remain at 8.5” x 20” and 255/35 ZR 20.
All season tires measuring 255/35 front and 285/30 rear are available as a factory option. Vehicles supplied with this option from the factory have a non-removable limited top speed of 130 mph. ALPINA recommends the appropriate use of performance summer tires and winter tires according to weather conditions for the best performance, handling and safety of your BMW ALPINA vehicle.
Exterior design.
The ALPINA design features blend seamlessly and stylishly into the surfaces and lines of the BMW 6 Series Gran Coupe, accentuating its dynamic, graceful silhouette.
A new, more aggressive front spoiler and apron enclose the subtly-changed BMW kidney grill and shape the transition to the new hood with character chines. These lend the new B6 xDrive Gran Coupe an even more authoritative appearance and hint at the enormous performance potential of the V-8 Bi-Turbo engine.
The design and shape of the new ALPINA front spoiler ensures the effective flow of sufficient air to the radiator modules of the performance cooling-system, including inter-cooler, water and oil. A subtle, integrated splitter directs air over and around rather than underneath the vehicle, thereby stabilizing the front end at high speeds.
Special NACA air channels at the front of the underbody suck cold air towards the powerful brake system with blue calipers which are visible through the delicate spokes of the ALPINA CLASSIC 20” wheels. Large diameter brake discs measuring 374 x 36 mm on the front and 370 x 24 mm on the rear (up from 345 x 24 mm) guarantee effective brake performance.
Interior & equipment.
The new B6 xDrive Gran Coupe has a comprehensive, comfort orientated range of standard equipment, a luxurious interior, and only the highest-quality materials. Nappa leather and a leather instrument panel remain standard in addition to essential features such as electric comfort seats. The BMW Navigation system with BMW ConnectedDrive services is also standard.
Blue ALPINA instrumentation, an ALPINA steering wheel covered in hand-stitched LAVALINA leather, the ALPINA production plaque overhead, door sill trims with blue illuminated ALPINA lettering, and the classic ALPINA luxury wood trim in Myrtle or Piano lacquer – these are some of the exclusive features of the B6 xDrive Gran Coupe’s interior.
2016 Updated Alpina B6 xDrive Gran Coupe
      02-11-2015, 03:33 PM   #2
Mr.SugarSkulls
Mr.SugarSkulls's Avatar
Drives: BMW i8
2016 BMW F13 M6  [10.00]
Nice!
I'm always sunny, hunny.
      02-11-2015, 03:33 PM   #3
Jmpascual
Jmpascual's Avatar
Drives: G82 M4 Competition, G05 X5 40i
Super sexy
      02-11-2015, 03:35 PM   #4
Nordkeyz73
Nordkeyz73's Avatar
Drives: E90 328i ZSP, Macan Turbo
M6 has to play catch up in the torque department.
BMW Performance SSK, BMW Performance Blackline Tails, BMW Performance Exhaust, BMW 3-Stage Intake Manifold, Evolve Automotive Tune, Weisslicht LED Halos, Black Kidneys, Digital Speedo
      02-11-2015, 03:37 PM   #5
PabloK
PabloK's Avatar
Drives: F30
Will the B7 get these engine & brake upgrades? or is it too late in it's life.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      02-11-2015, 03:37 PM   #6
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
Wow-- enough power to make your passengers puke
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      02-11-2015, 04:12 PM   #7
fndrsn
Netherlands
111
Drives: Nothing...yet!
Heaven above Hope it sounds as amazing as it looks!
      02-11-2015, 04:17 PM   #8
BMW335iOn18s
Resident BMW Fanboy
BMW335iOn18s's Avatar
Drives: F82 CS SMB
I have a feeling this will outsell the M6 GC
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT
      02-11-2015, 04:19 PM   #9
TheBingoBalls
TheBingoBalls's Avatar
Alpina is killing it with all the FXX chassis BMW's!
      02-11-2015, 04:23 PM   #10
bigant66
bigant66's Avatar
13
Drives: f82 m4
2015 f82 m4  [0.00]
Wow those are some nice numbers. I wonder if it had a dct would 0-60 times be closer to the e63 amg? Considering the HP
      02-11-2015, 04:25 PM   #11
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
What is the msrp on this thing? May get this over the M6GC...
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      02-11-2015, 04:45 PM   #12
Btyler227
Btyler227's Avatar
Drives: 2017 X4 M40i
Brilliant move. Test M6 like power with AWD in the market but without putting in the R&D to make it an actual M car.
F26 X4 ///M40i Carbon Black
      02-11-2015, 04:49 PM   #13
SickFinga
Drives: *
This is exactly why Alpina cars were introduced in the US.
      02-11-2015, 04:50 PM   #14
ChrisMT79
ChrisMT79's Avatar
Drives: 2015 F80 M3- Alpine White
So wait, if a person opts for the all-season tires deciding later to change them, they are stuck with the "non-removable" 130 factory set limit? This would have to be able to be coded otherwise after the fact I'm assuming? And that would really stink if they made any other alterations limiting vehicles which opted these tires to that limit.
      02-11-2015, 04:56 PM   #15
3M TAPE
3M TAPE's Avatar
Drives: M3
I would take this over an M6 now.
      02-11-2015, 05:20 PM   #16
clbmw
Drives: 320d M135i
      02-11-2015, 05:31 PM   #17
GOLFFRR
GOLFFRR's Avatar
10827
Drives: GOLFFRR cart
car is amazing! so much luxury and power. I love Alpina stuff
      02-11-2015, 05:46 PM   #18
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
Awesome.
      02-11-2015, 06:18 PM   #19
RingMeister01
Croatian
RingMeister01's Avatar
Drives: PORSCHE
Love Alpina. Bring them all to the U.S. Please
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      02-11-2015, 06:57 PM   #20
Roadkiller
Philosophiae Doctor
Roadkiller's Avatar
Drives: 2015 M4 BSM
+1
      02-11-2015, 07:31 PM   #21
spuntyb
spuntyb's Avatar
Drives: 2019 F90 Competition
Do want. Would take over an M6
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold)
2018 F80 ZCP TB|SS (sold)
2015 F30 335 AW|CR (sold)
2015 F31 MG|CR (sold)
2011 E90 JB|Oyster (sold)
      02-11-2015, 07:33 PM   #22
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
And in the AWD department.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
