      06-22-2015, 10:54 PM   #45
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Originally Posted by bigbrian View Post
I have been driving around with the CEL for some time now. Unfortunately you will need an ECU tune to remove the CEL. I don't believe the DINAN box removes the CEL (correct me if I am wrong guys) because the JB4 box doesn't remove it.
Once my new turbos are built I will be having EuroCharged in Houston do an ECU tune on my car that will remove CEL.
Brian
Thanks for the info Brian!
I'll let you know once the Dinan tune is done ... Victoria BMW seems to think that will eliminate the CEL issue ... see what happens!
Talk soon Bro ... thanks for the replies and advice
Sunny
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      06-23-2015, 12:45 AM   #46
Msizzle
Drives: 2013 M6 Coupe
the dinan tune is a piggy back so it will not remove the cel, it makes power by actually send the ecu bad information, the ecu adds an additional 3-4 psi as a result of the "box" telling the ecu the engine is short 3-4psi. unlike a custom tune the timing,afr's, and other parameters are left for the ecu to handle on its own, it  is not modified at all with dinan or jb4 or any other piggy back. Top speed limit,rpm raised, or cel can't be controlled with this method. Not for nothing though the only advantage to a piggy back is the price, the jb4 is 499 the dinan is around 2500 if not more, for that money you can get a custom tune that is much better and will give you all the additional options .
      06-23-2015, 04:28 PM   #47
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Sunny
For the price you are paying for the DINAN tune you can get a full ECU tune done by a tuning shop. It's a much safer and more effective way to tune the car. Full ECU tunes are $2,500 - $3,000 and they adjust timing, fuel, boost, and can do so along the whole RPM range. The full ECU tune will remove the CEL and top speed limiter as well (DINAN cannot do this).
Only thing DINAN does is increase the boost being relayed back to the car which for $2,500 is pricey for what you are getting.
Brian
      06-23-2015, 10:47 PM   #48
2007 to 2016 M6 Cab
Brian
Thanks Brain!!!
Will have to see who can do this in Victoria or Vancouver BC ..
Talk soon!
Sunny
Current Garage:
Past Cars:
      06-25-2015, 12:39 PM   #49
n0shadowkick
Drives: Schwinn
If you are running catless downpipes there are two methods that i learned of that you can use to remove cel
One is a Bluetooth obd2 tool which removes the cel code but you have to keep resetting it after a certain amount of miles driven.
Another is installing something called a "fauler" which tricks O2 sensor but I hear it's hit or miss with this so do your research.
      06-26-2015, 09:29 AM   #50
S800vxr
Drives: F13 M6 Coupe
Whilst the Fauler may work for a short while the idea is flawed for a number of engineering reasons eg: The tiny hole for sensing WILL block, the surrounding gases will have the same content more or less. As such I would not bother with this route on such a Tech car.
Full tune and removal of the CEL code is the only real way to go.
      06-26-2015, 02:29 PM   #51
n0shadowkick
Drives: Schwinn
Thats good info. I never knew of the negatives of faulers.
Whats weird is that I am running BMS stage 2 tune and catless downpipes but I'm not getting any CEL light. Does anyone know why that may be?
I have had the N63 recall done and I remember talking to someone saying that BMS stage 2 clears CEL but others have said that is not true.
I guess its either that or maybe my tune wasn't installed correctly... so confused lol
      06-26-2015, 09:33 PM   #52
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
BMS tune does nothing to clear the CEL. The tune isn't going to come into play if your CEL isn't on so I doubt the tune is installed incorrectly. It's literally 2 plugs so installing incorrectly would be VERY hard to do.
m6beast's car doesn't have the CEL either. Sounds like some get the light and some don't. Most get the light.
Brian
      06-27-2015, 11:03 AM   #53
2007 to 2016 M6 Cab
Brian
I hope not to see it come on! We are at 1759 km, Monday car goes in for the 2000km first service, rear carbon fibre deck lid spoiler from the BMW Performance Parts Bin, AND HOPEFULLY CATLESS
I have heard that many of you running catless setups have been running with the CEL on
My dealer has the Supersprint Down pipes ... but concerned if there is 2016 M6 specific Dinan programming avail, and they seem to think if avail will remove the CEL
Also, if the CEL remains on after going catless ... due to a rich mix/burn of fuel and emisions issues once catless, could the ECU shut the engine down? Dealer concern now that we are close has to do with reliability and ECU interpretations of the CEL and safety!!!
Any concerns there Big Brian, seeing as you and a few others have been running with CEL on?
dealer cold feet ... got to love it
I will likely do an ECU Tune, but issue becomes warantee
Current Garage:
Past Cars:
      06-28-2015, 10:52 AM   #54
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Good luck! Lots of subjectivity when it comes to warranty...
Full Vorsteiner Aero Kit, ADV5.0 M.V2 CS rims, KW HAS kit, M Performance Exhaust w/ CF tips, CF Mirror Caps, CF Gear Selector Lever, CF Side Marker Gills, CF Front Grill, Dinan CF Intake, AFE CF Engine Cover, Stage II Dinan Tune, Exhaustmeister, Internal Escort 9500ci + Laser Shifters, Photosync window tint 65% windshield 35% windows, Full PPF xpel ultimate wrap, RK Autowerks noncatted DPs, reflector delete, various coding
      06-28-2015, 10:59 AM   #55
2007 to 2016 M6 Cab
Brian
COULD IT BE THE FUEL THAT RESULTS IN SOME HAVING CEL ON AND OTHERS NOT WHEN CATLESS?
my 2007 M6 Cab with V10 with K&N cold air intake and Eissenman Sport Cat Back would have the CEL on if I ran anything other than Shell 91 Octane/V-power (and here in Victoria BC we have no ethanol blended in our Shell 91/V-power)
WHAT FUEL ARE THE OTHERS WHO ARE CATLESS AND NO CEL ON RUNNING?
As for the warantee issue, I think they will be good about it based on past cars and performance mods ... just seem a little reluctant to make a mod that could cause a problem ... some new staff in higher rolls as others more senior moved along to other brands under the German Auto Import Network (Namely moved from Victoria BMW to Porsche Centre Victoria)
1858 km now!
Current Garage:
Past Cars:
      06-28-2015, 07:04 PM   #56
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
If you put catless on I am are the CEL will come on. I am also sure DINAN nor BMS box will remove it. The CEL won't do anything in terms of shutting down the ECU or negate performance of the engine. The light will just be illuminated on the dash. The only way to remove the light is an ECU tune. The faulers do not work as I've tried them. I have also tried the SmartWhatever device that is supposed to trick it and it doesn't work.
I would put the catless on and the rest of your mods. If you want a quick bang for your buck tune right now I would do the BMS and wait to spend your money on an ECU tune.
Don't get caught up worrying about the CEL. I've had the CEL for probably 11 months now and it's no biggie. You will actually get used to seeing it displayed on the dash lol.
Brian
      06-28-2015, 09:16 PM   #57
Roadrage
Drives: M6 GC
As Brian stated BMS or Dinan piggyback will not remove cel, I had the BMS for about 7 months before I got the AMS ecu tune. I am running AMS catless down pipes as well did not get cel light until like 150 miles on car, like everyone you get use to it. Only cure was the full ecu tune
2014 M6 Gran Coupe, Strasse Forged 22", AMS DP, H&R Springs, Vorsteiner Carbon Aero Lip, IND body parts, side markers, carbon mirrors and spoiler, carbon diffuser.
      06-28-2015, 10:28 PM   #58
n0shadowkick
Drives: Schwinn
BMS Stage 2 n63 tune is a bit more complicated to install than the plug and play stage 1 but I don't think it was installed incorrectly either and doesn't matter (now I know).
I guess time will tell if I get CEL, fingers crossed.
I'm bummed out to hear that you've tried faulers and the bluetooth device with no avail. That's what I heard though; 50% of the time, it works every time.
ECU tune sounds tempting. I mean I love my BMS tune but its inconsistent. I heard that ECU tuning in non-reversible? I mean you can always tune it back to factory/default settings though, right?
      06-29-2015, 04:47 PM   #59
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Yes, you can change the settings in the file back to default and upload it to the ECU to go back to stock. It's just more of a pain because you need someone to do it for you. If we ever get to the point where it can be done via ODB2 port then we can all do it ourselves with a laptop or handheld programmer -- this would be ideal!
I am with you though in the fact the BMW is a badass box. It's by far the best bang for the buck that I have spent on the car. I just know the ECU tune is safer due to the fact you can control fuel and timing and boost vs. just boost with BMW/DINAN.
Brian
      06-29-2015, 10:28 PM   #60
2007 to 2016 M6 Cab
Brian
Thanks Brain ... and everyone else!
Car in today for the 2000 km service, CF rear Deck Lid spoiler ... then I am off for Canada Day Long weekend to wine country and a wedding ... We catless next Tuesday ... another delay ... but a 5 day weekend vs being catless now ... sucks, but road trip in Benz the for a wedding ... will have to wait till next week .. then figure out the ECU Tune!
Thanks everyone for their advice and input ... not as worried!
Sunny
Current Garage:
Past Cars:
      11-18-2016, 08:32 AM   #61
TrevorM3
Drives: 6.3 AMG
s63tu guys are still runing jb4?
jesus..
      11-24-2016, 10:45 AM   #62
S800vxr
Update from me. Fitted DPs (Catless) and car would go into limp mode at high rpm and speed. Changed everything but eventually had it re mapped by Evolve. Now running 752hp (run on a local dyno I've used for years which gives a solid reading if a little low compared to most). Also had the cold start cycle removed and the cars a dream now. Absolute animal once it grips and pulled off the speedo with 7th to go!
Seems the tune has too be perfect to run decat DPs and DMS couldn't manage that.
