04-10-2016, 10:11 AM | #1 |
Rep 147
Aftermarket brake pads that give off less dust.
So I was spoiled previously because I had carbon ceramics on my M3. ZERO brake dust was the best! I rather not spend 12k on buying ceramic brakes so I'm seeing if anyone has come across aftermarket pads that give off less dust then the factory ones.
Thank you |
04-10-2016, 10:38 AM | #2 |
Rep 676
Drives: 2015 M6 Gran Coupe
The ones I've been recommended, but haven't tried yet are Pagid Ceramic Brake pads. Reportedly has less squeaking issues.
only front pads are available https://www.turnermotorsport.com/p-1...FcOBfgodieYE-w |
04-10-2016, 02:31 PM | #3 |
Rep 18,713
I have tried Pagid RS29 on M6 brakes retrofitted into F06 650. It has moderate brake dust, grip much better than stock oem pads. But a little noisy.
If you are interested, I had it for 2 weeks and sold the car. Going to post it sometime next week in classified section.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-10-2016, 04:17 PM | #4 |
Rep 676
noisy as in squeaky?
04-10-2016, 06:22 PM | #5 |
Rep 170
I need to find the work order from when the dealer changed mine out so I can share the part numbers. I had really bad squealing initially , once I pressure washed the rims/calipers it would go away for a day or so.
Dealer said they would swap out the pads ONE time (good will) for what ever pad they put in. SA said its was way more expensive of a part and had to get the OK from someone at BMWUSA so that they could do it. All I can say is its night and day different now, way less dust and ZERO squeal. While I do not track the car or use the breaks to their full potential I can not sense a difference in performance . |
04-11-2016, 01:59 AM | #6 |
Rep 676
Which dealer did you get this done from?
04-12-2016, 06:30 AM | #8 |
Rep 3,071
Hawk pads
04-12-2016, 11:32 AM | #9 |
Rep 676
please share the part numbers and work order if you can
04-13-2016, 12:48 AM | #10 | |
Rep 6,067
Sometimes the reason of noise is not brake pad... it's the cracked rotors and there is a service bulletin that I posted long time ago here: http://f10.m5post.com/forums/showthread.php?t=1112127
05-08-2016, 05:58 PM | #12 | |
Rep 147
05-08-2016, 07:33 PM | #13 | |
Rep 18,713
If you didn't bed it properly, it will squeak terribly.
05-08-2016, 08:07 PM | #14 |
Rep 147
