      11-13-2014, 03:59 PM   #1
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
2013 M6 Recall
FYI, just took my M6 to dealer for service, when I discovered there is a recall that was recently issued. Concerns turbo's melting some cooling lines. Have to install a heat shield in between. Says they will need car 2-3 days due to extensive work of removal of turbo's. Thought this was weird since I never received notice via mail. I confirmed with another dealer here in AZ though. Anyone else dealing with this?
      11-13-2014, 04:38 PM   #2
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Interesting... I just hit up my Service Rep at BMW to find out more about this because this is the first I have heard about it.
Brian
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      11-13-2014, 07:19 PM   #3
aj1985
Drives: 2013 m6 coupe sapphire black
Interesting thanks for the info.
Side note. Does anyone with a 2013 have issues with the steering wheel rattling when driving on the freeway or at speeds anove 65. I feel like im wrestling with a bear when im driving at hog speeds cause the wheels vibrates so much.
      11-13-2014, 07:27 PM   #4
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
^^ Have you checked to make sure your wheels/tires are properly balanced? Sounds like that might be the issue.
Brian
      11-13-2014, 07:38 PM   #5
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Is this the new one or that "retrofit heat protection mat to coolant lines"
      11-13-2014, 07:52 PM   #6
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
21" wheels
sounds good brian, let me know what you hear.
on another note, i am looking at strasse 21" wheels. i have the h&r lowering springs, so want to make sure they still tuck in! here is a rendering of the style i am looking at.
i noticed you have 21" wheels. any input would be greatly appreciated! how do you like the fit?
      11-13-2014, 07:57 PM   #7
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
yes, this appears to be it. does it really require turbos to be removed as dealer is stating??? did you have it done?
      11-13-2014, 09:14 PM   #8
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No it's not required to remove the turbos! all they need is to remove the plastic cover. I had my car done and this is the result:
      11-13-2014, 09:25 PM   #9
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
Wow, excellent info. I will contact my advisor first thing in the morning. Thanks!
      11-13-2014, 09:33 PM   #10
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
The fitment on my 21" wheels is perfect. I run 265/30/21 on the front and 305/25/21 on the rear. H&Rs will make the tires tuck in the fenders because from what others say it puts the front a tad lower than the KW kit (which I have). I can just barely get my finger in between the fender and the tire so the tuck is perfect. It doesn't rub or anything which is the question I get asked often.
I am not sure if you need to do this with the H&Rs (maybe ask Twitch on here) but to get mine to sit down all the way I had to remove the white bump stop that is on the shock. When I left it in place the shocks were literally sitting on the bump stop, the ride quality was bouncy, and the car didn't lower down all the way. Once I removed the bump stop I was good to go. Also, I don't experience any bottoming out at all.
Post some pics once you get everything mounted up and installed.
Brian
      11-13-2014, 10:13 PM   #11
adibaiz1
adibaiz1's Avatar
27
Drives: 23 M8GC,22 S580,21 M4,22 SF90
I am also running Strasse wheels 21x9.5 and 21x12 rears with 325's and no rubbing what's so ever, perfect fitment and I am lowered on KW V3's. I am on my 3rd set with Strasse for my last 3 cars. Best customer service and very very good quality wheels. Here is the link from the photo shoot i did. Sorry for highjacking the tread.
http://www.6post.com/forums/showthread.php?t=1054491
      11-13-2014, 10:41 PM   #12
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
Brian
Ok, ride is definitely more bouncy now, so I will check on bump stops. Thanks for the wheel info. I will def put some pics up!
      11-13-2014, 10:46 PM   #13
jvise
jvise's Avatar
14
Drives: 2013 BMW M6
Wow, looks awesome! Yea, their responsiveness has been second to none. Took me two weeks to get a response from hre. I wanted to do 12" width in the rear, but strasse said I would need some minor mods. Did you have to do anything special to get those to fit?
      11-13-2014, 10:59 PM   #14
adibaiz1
adibaiz1's Avatar
27
Nope , no mods at all...i have to stop by their shop one day, they want to see if my set up will fit an M6 that is lowered on H&R springs...don't forget I'm lowered on KW V3's, maybe they are different than the H&R or KW sleeves.
      11-16-2014, 06:10 PM   #15
BTF13M6
BTF13M6's Avatar
Drives: 2013 BMW M6 Coupe
I had the recall performed this week. It was done in one day though.
They did all of the software updates and... I am not sure if it is the cold weather or the software updates, but my cars shifts much harder now.
2013 F13 ///M6 Coupe - Singapore Grey
20" ADV.1 5.0 MV1SL with Pirelli Pzero's
Custom Painted Grill, side markers and tinted front reflectors, Dinan Stage 1.
      11-17-2014, 07:45 AM   #16
Wolfgang_K_
Wolfgang_K_'s Avatar
Germany
33
Drives: M8 Competition Convertible
I have performed the recall 3 weeks ago, also the software update:
- the first few hundred km/mile the car shifts strange, but now i am really happy - really smooth and fast
- best thing after SW update: B&O blue lighting - now it will light up really bright -
      11-24-2014, 04:10 PM   #17
jettie1767
Drives: '23 BMW i7 xdrive60
I went to the dealership today and they see the recall bulletin. I have scheduled that appointment in two weeks. However, they said there are no software updates for my car. What do I tell them regarding the software update?
Tags
m6 recall
