      11-23-2014, 08:36 PM   #1
Tuskir
Drives: BMW M6 CP
Stock pirelli's simply not cutting it!
Having major traction issues with stock pirellis on my 14 M6 CP (and that's even before adding Dinan or BMS which I plan to do asap). Car simply does not put down power in 1st and 2nd. I've done a lot of research on this issue and, unfortunately, it's very difficult to find any drag radial tire that will fit stock wheels. I've found this one - Nitto NT05, it has gotten pretty good reviews. Now my question is, will these tires fit stock 20's 275/40 front and 305/30 rear? That's pretty close to stock.
      11-23-2014, 09:30 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Your front rims are 9.5" wide and the rear one is 10.5" so you are basically good to go upto 285 in front and 305 in rear! Recently I installed PSS 305/30/20 in rear with no issue. I couldn't find PSS 275/35/20 for front so I got the original one(265/35/20).
Just keep in mind the 275/40/20 makes the total diameter of your front wheels about 1.35" (5%) taller than stock!
Edit: Nitto NT05 is most likely track tire! You might experience some issues in wet roads regarding to handling and traction. The Michelin Pilot Super Sport (PSS) is the best tire for this car (IMO). It is a high rated tire you may need to try.
See this for PSS : http://www.michelinman.com/tire-sele...er-sport-tires
And see this for NT05 : http://www.nittotire.com/race-tires/...g-radial-tire/
      11-23-2014, 10:25 PM   #3
Tuskir
Drives: BMW M6 CP
Thanks for the recommendation M6-coupe. I was definitely considering Pilot Super Sport, I'm just afraid it won't be a big upgrade from the Pirelli Pzero. I don't generally drive in the rain with the M6, so I want something that's really going to hook up and make the most of the Dinan tune.
      11-23-2014, 10:41 PM   #4
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
You may want to ask @Fantasm ! I know he has the same tire (Nitto) installed in his M5!
      11-23-2014, 10:53 PM   #5
twm6
Drives: 2015 Protonic Blue I8
what tires would you guys recommend for daily/spirited driving?
      11-24-2014, 08:56 AM   #6
jnkirk1974
jnkirk1974's Avatar
I think at the end of the day, no tire of truly going to cut it for our cars. Rear wheel drive with a ton of torque.
I have the Pilot Super Sports on mine and am wanting to switch from them to something else.
If you want maximum traction in the lower gears, semi slicks are probably the only option. Otherwise, the Michelins and the Pirellis are going to be as good as it gets (unfortunately).
      11-24-2014, 11:04 AM   #7
Tuskir
Drives: BMW M6 CP
Has anyone tried Pirelli P Zero Corsa? Looks like it's far superior in terms of traction to regular Pirelli P Zero.
      11-24-2014, 03:29 PM   #8
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
I have 325 rear P-Zeros on my ADV.1s and I can say traction is much improved over the stock Michelin or Pirellis.
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
      11-24-2014, 08:09 PM   #9
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Twitch it's because of the wider size! I feel better traction compare to stock since I had 305 installed
      11-24-2014, 08:09 PM   #10
Twitch Massacre
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
Twitch it's because of the wider size! I feel better traction compare to stock since I installed 305
+1
H&R Springs
Coming Soon:
      11-24-2014, 08:53 PM   #11
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
I don't think you are going to find any tire that "hooks" out the gate on this car. I imagine even drag radials are going to cause some slippage as the power this car makes is extreme.
You can look into Mickey Thompson ET Street IIs as they released 19-20" sizes recently but I don't know the widths available. The thing is drag radials are not really meant for everyday driving so keep that in mind.
Brian
      09-18-2015, 06:47 PM   #12
jnkirk1974
jnkirk1974's Avatar
Old topic, but bringing it back to life. Cannot get Pilot Super Sports anywhere! Out of stock.
So, I'm switching to a 305 rear tire and having to go to the P Zero. Wasn't wanting to, but the Pilot Sport Cup 2 is also out of stock.
Hopefully, the 305 rears will help give me a bit more grip than the 295s.
      09-22-2015, 06:56 AM   #13
LI M6
Drives: 2014 M6 GC
Is your car lowered ?
Mine's lowered 3/4" and I wonder if the 305"s will work OK....
      09-22-2015, 08:22 AM   #14
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No my car is not lowered but I'm sure it works out even if you have lowered the car. The difference between 295 and 305 is 5 mm outside and 5mm inside. There is lots of room at suspension side so there is no issue for inside rubbing ... 5 mm outside is negligible too as you can see in pictures
