      04-14-2024, 07:02 AM   #1
Big G 1979
Big G 1979's Avatar
Drives: BMW 640d
Help diagnosing issue
I've been chasing this issue where the car veers to the right under acceleration and would track straight when lifted off, I've had her tracked and replaced front arms to no avail. I had her on ramps this afternoon and found this, would this movement be classed as normal would this arm if worn exhibit my symptoms? Any advice/help greatly appreciated
Hopefully videos in link below....
https://photos.app.goo.gl/bQpdae5nN1gT5ByW7
      04-14-2024, 07:40 AM   #2
Opie55
Drives: '15 650i Convertible
Without being there to actually see the rubber bushing in person to see if it is degraded or torn, I'd say the movement you are showing is normal. The bushing is just rubber which is fixed at its inner circumference where the bolt goes through and is fixed at its outer circumference where it is pressed into the arm. But in between those two fixed points it's flexible rubber so you will be able to flex it sideways when you get a screwdriver in there like that. If it's torn that's a different matter, but your does not look torn, at least that I can see. The movement at the ball joint end is totally normal - that's what ball joints do. When driving, that arm is not really subject to those side to side forces. It's gets pressure straight in and out.
      04-14-2024, 07:48 AM   #3
Big G 1979
Big G 1979's Avatar
Drives: BMW 640d
[QUOTE=Opie55;31071776]Without being there to actually see the rubber bushing in person to see if it is degraded or torn, I'd say the movement you are showing is normal. The bushing is just rubber which is fixed at its inner circumference where the bolt goes through and is fixed at its outer circumference where it is pressed into the arm. But in between those two fixed points it's flexible rubber so you will be able to flex it sideways when you get a screwdriver in there like that. If it's torn that's a different matter, but your does not look torn, at least that I can see. The movement at the ball joint end is totally normal - that's what ball joints do. When driving, that arm is not really subject to those side to side forces. It's gets pressure straight in and out.
Thanks for the reply, I'm really struggling to find the fault, like said I thought it was the control arms on front so replaced those but didn't fix it. I've started to look at the rear as I think it's steering from the rear under acceleration.
      04-15-2024, 12:35 AM   #4
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
If the pulling happens mainly under acceleration, check all the bushing in the rear suspension and subframe. The rear it generally the source of on and off throttle shift in behavior.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      04-15-2024, 02:51 AM   #5
Big G 1979
Big G 1979's Avatar
Drives: BMW 640d
Thanks I have opted to replace the RTAB and see if thats the issue, doing some research the symptoms I have are link them so fingers crossed this sorts her out!
