      10-06-2017, 03:22 PM   #23
drantispy
Drives: M5 E60
before i exchange my wheels i am thinking to replace my wheel hubs which are 7cm width with the m6 /m5 ones which are 4.5 cm. the m5/m6 are smaller by 2.5 cm.
first image is the 640 wheel hub and the rest the m5/m6 wheel hub. the only problem is that the abs ring on the up of the m5/m6 hub is not identical with the 640.
anyone knows if this mod would be a possible solution?
      10-07-2017, 01:39 PM   #24
cjackson1906
Drives: 2018 Alpina B6 GC & 2019 M5C
2013 BMW M5  [0.00]
Originally Posted by P1et View Post
You can find two more front wheels and mount them on the rear.
Why not go with this suggestion?
2019 M5 Comp; 2018 Alpina B6 GC; 2019 M4 CP (gone); 2018 X3 M40i (gone); 2015 M5 Comp Pkg (gone); 2016 X5M (gone); 2013 650 xDrive Coupe M-Sport (gone); 2013 F10 M5 (gone); 2011 550i (gone)
      10-07-2017, 08:03 PM   #25
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
My suggestion makes far too much sense.
Flying Ace4984.50
      10-08-2017, 02:57 AM   #26
drantispy
Drives: M5 E60
the overall cost would be huge. i prefer to spend 200 to test drive my theory
      10-08-2017, 04:10 AM   #27
elvisisdog
Drives: F06 MSport 2013/09
I really like the hub idea. Just having a look on realoem.com and the wheel carriers are obviously different but the abs sensor might be something you could modify. Why settle for something less than what you're after..
Might be something that could be fabricated using both parts.
      10-08-2017, 05:14 AM   #28
elvisisdog
Looking at the pictures again, I can't see this working. There is a significant flange on the M6 hub that would fit into a recess in the M6 wheel carrier. Where as the standard hub has little flange. Looks like the bearing in the M6 hub is within this flange and hence the hub carrier bolt holes are so shallow to the outer part of the hub. From these pictures it looks like you'd be replacing the wheel carrier and all of the rear suspension for M6 components, or a modified wheel carrier but not sure how much I'd trust a part where metal has been removed (as in creating a recess in the wheel carrier to accept hub). You'd probably run into issues in the length of the driveshaft as well.
      10-09-2017, 02:41 PM   #29
drantispy
Drives: M5 E60
looking into other bmw models rear wheel hubs but its so difficult to find dimensions to compare
      10-10-2017, 12:24 PM   #30
F30Andy
F30Andy's Avatar
1774
Drives: An Entire Fleet
Looks amazing.
Now this seems like a lot of headache you are going through, so how about you sell me the wheels?
      10-11-2017, 04:09 AM   #31
drantispy
Drives: M5 E60
Originally Posted by F30Andy View Post
Looks amazing.
it is indeed. will let you know
      10-11-2017, 04:10 AM   #32
F30Andy
F30Andy's Avatar
1774
      11-08-2017, 11:42 PM   #33
drantispy
Drives: M5 E60
new bmw m5 601m alloys with oem m5 sizes installed.
Flying Ace4984.50
      11-09-2017, 12:10 AM   #34
BMPOWERED
BMPOWERED's Avatar
65
Drives: 2014 650 GC M sport
Good choice....about 2 months and a lot of unnecessary headaches too late but it looks great.
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW
1991 Nissan 300ZX Twin Turbo
2007 Chevrolet Corvette Z51 (sold)
2001 BMW 325ci (sold)
