      10-27-2017, 10:12 AM   #1
BigRoc916
BigRoc916's Avatar
9
Drives: 2013 650i GC
650i GC FUEL PROBLEM
650i xdrive GC FUEL PROBLEM
PLEASE HELP!!! So I bought bought my 13 650i xdrive GC a little over a month ago with 59k miles and all of a sudden last week it starts bogging down and sputtering like crazy. I brought it to my mechanic to have him check it out and he said its a misfire and it around 60k miles I should be changing the plugs anyway. He changes the plugs and its doing the same thing. No power and sputtering like crazy. We start doing research on the issue to see if theres a recall of some sort and I come across the CUSTOMER CARE PACKAGE CAMPAIGN PROGRAM (bulletin B001314) and it seems like my car falls under that issue. It states that all the cars produced between the certain dates with the 50i motor have this issue. I call up my local dealer to set up an appointment and when they run my vin, I'm told that there are no open recalls on my car. Looking into the recall further, I see that my car isn't listed in the recall. I have the F06 model GC. My question is, if all of these motors are the same, how could it be that my car isn't included in the recall? The 650i coupe is listed in the recall but the GC that is produced during the same time isn't?
Info on my car:
Type code 6b43
E series F06
Engine N63TU
Prod. Date: 7/24/12
13 650i GC
16 Audi A6 3.0
14 MB E350
      10-27-2017, 10:48 AM   #2
bravo261
Drives: F06 650
sounds like a problem i've had multiple times on my car. never got the details, but the words "hydraulic fuel pump" come to mind, and i know they replaces some hoses. sorry i couldn't be more informative
      10-27-2017, 10:55 AM   #3
BigRoc916
BigRoc916's Avatar
9
Ahhh. Gotcha. Well I appreciate the feed back. Hopefully if that's the case, it won't cost me too much
13 650i GC
16 Audi A6 3.0
14 MB E350
      10-27-2017, 11:13 AM   #4
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
The TU motors are not covered by the customer care program. Take your car to a BMW specialist. If it is sputtering that bad, it should be throwing codes, which will help diagnose the problem. Have your mechanic check the vacuum lines, too.
      10-27-2017, 11:15 AM   #5
BigRoc916
BigRoc916's Avatar
9
And that's the strange thing....it's kicking no codes.
13 650i GC
16 Audi A6 3.0
14 MB E350
      10-27-2017, 11:54 AM   #6
upstate650
upstate650's Avatar
No codes? that seems almost impossible. Again, have your mechanic check the vacuum lines, which are a known replacement item - they bake in the heat of the motor's V. Then I would be taking a trip to the dealer to diagnose what is happening. Otherwise, you are just throwing parts at a problem hoping something works.
      10-27-2017, 12:26 PM   #7
BigRoc916
BigRoc916's Avatar
9
No codes? that seems almost impossible. Again, have your mechanic check the vacuum lines, which are a know replacement item - they bake in the heat of the motor's V. Then I would be taking a trip to the dealer to diagnose what is happening. Otherwise, you are just throwing parts at a problem hoping something works.
It's kicking the drivetrain malfunction code now. I don't know whether to be happy or sad about that.
13 650i GC
16 Audi A6 3.0
14 MB E350
      10-27-2017, 02:21 PM   #8
upstate650
upstate650's Avatar
Be happy -now you can figure out what's wrong. And please report back.
      10-27-2017, 02:23 PM   #9
BigRoc916
BigRoc916's Avatar
9
Will do. Thx for the replies guys
13 650i GC
16 Audi A6 3.0
14 MB E350
      10-27-2017, 06:35 PM   #10
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
check your high pressure fuel pump. Those are usually the first to go. Very expensive fix.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      11-01-2017, 06:48 AM   #11
Viker88
Drives: 2014 650i
Hey guy, brand new to the forums.
This sounds like the HPFP, make sure your SA gets left and right one tested. I had one replaced and the other one went bad the next day. (I think they replaced the wrong one, but i got 2 new HPFP out of it, so it's okay)
Aside from that, the spark plugs should last ~80,000, not 60,000.
Cabin filters, and intake filters should be done by now too, if you haven't.
Best of luck!
      11-01-2017, 01:36 PM   #12
rsdshoreman
shoreman
Drives: 2012 650I convertible
I have a '12 650I conv. with 53K miles and BMW just replaced the fuel pump under a recall. the car had no issue until the worked on it and now I have a ck eng light and they said it the DMTL pump.
      11-01-2017, 01:38 PM   #13
rsdshoreman
shoreman
does anyone know where this dmtl pump is located and had any issues with it?
      11-01-2017, 02:31 PM   #14
BigRoc916
BigRoc916's Avatar
9
Best of luck!
So it looks like the problem was the ignition coil. This is what I got from my mechanic.....
CONNECTED BMW DIAGNOSTIC SCANNER AND MISFIRING FAULTS STORED FOR CYLINDER #7. REMOVED BANK 2 AIRBOX, TRACED FAULT TO BE DUE TO FAILED IGNITION COIL. REPLACED IGNITION COIL #7, RESET DME ADAPTATION VALUES, CLEARED FAULTS, ROAD TESTED AND MISFIRING FAULT ELIMINATED AT THIS TIME.
Looks like I dodged a bullet with this one. $150 fix
13 650i GC
16 Audi A6 3.0
14 MB E350
      11-01-2017, 03:00 PM   #15
upstate650
upstate650's Avatar
good to hear. Enjoy the car!
      11-07-2017, 03:53 PM   #16
Jerinoid
Drives: 2007 BMW 530xiT Wagon
Don't get comfortable just yet with it just because they cleared the codes. My 650i coupe (11/15/2012 build) is in for the 3rd time on this exact issue. First they replaced the vacuum lines for the open campaign on that (cost the dealership nothing to do that), but I kept getting the "Drivetrain Malfunction" and massive limp mode home. Now I'm getting 2 new fuel injectors. This problem with the N63tu has been documented as being the bad injectors from the prior (no "tu" motor) still being used in the early production 2013 models. Also may be bad coils, but I doubt it.
      11-08-2017, 06:12 PM   #17
BigRoc916
BigRoc916's Avatar
9
My mechanic didn't just clear the codes....he changed the ignition coil as well. But he did warn me that these injectors tend to go on this motor so we'll see what happens
13 650i GC
16 Audi A6 3.0
14 MB E350
      12-12-2017, 12:22 PM   #18
J. Dub
Bob Saget
J. Dub's Avatar
Drives: 2010 335i e92 N54 A/T
How are things today OP?
In memory of Robert E. Flynn (AR)
      01-23-2018, 08:16 PM   #19
Sena27
Drives: 2013 650i BMW
Ok this all sounds too similar. So I’ve been bringing my 2013 650i in for about a year. For the dreaded Drive train Malfunction.
I’ve had my fuel pump changed HPFP
I’ve had coils
I’ve had spark plugs
I’ve had injectors
They even got me a new engine! If you could believe that!
Two weeks later after new engine
I still have a problem with the HPFP trouble code
Brought it back now they said they need to put a wiring harness restraint on the wires near high pressure fuel sensor.
Just picked up the car.
Hope this fixes the problem
Just don’t understand why they didn’t put the harness on when they changed the fuel pump the first time?
I’ll keep everyone updated. This might be the issue (wire harness next to fuel pump)
      01-24-2018, 02:41 AM   #20
Giggs11
Giggs11's Avatar
49
Drives: 13' f13 650i xdrive,M package
Hi guys first of all sry to hear about the issues , as I m reeding all this posts about the problems you all experiencing is puzzling that some don't experience any problems at all how is that possible same yhr and month of production specs etc
      01-31-2018, 12:17 PM   #21
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Avoid older years model, that seems to be where the issues are
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
