      09-17-2014, 01:33 PM   #1
AstonMartian777
Drives: 2014 M6 F06
Who can get me cheapest DOWNPIPES ?
Looking to get downpipes, catless, cheapest, thank you !
      09-17-2014, 01:48 PM   #2
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Motive Concepts are $1599 I believe. I don't think they get that much cheaper but I could be wrong.
Brian
      09-17-2014, 01:51 PM   #3
AstonMartian777
Drives: 2014 M6 F06
Maybe some vendors can hook me up
      09-18-2014, 07:04 PM   #4
C's Bimmer
C's Bimmer's Avatar
Drives: '15 M6 GC,'08 M5,'14 958 GTS
I just had the AMS Catted Downpipes installed, along with the P3 Vent Gauge, upped the BMS Tune to 5psi and had the Alcantara Steering Wheel installed. MY GOD - This car is a freakin beast now -- it's so INSANE!!!!
Current Garage:
*2015 Singapore Grey F06 M6 Gran Coupe (The Beast)
*2014 Black Cayenne GTS 958 (Wife & Kids Beast)
*2008 Imola Red E60 M5 (My Other Beast)
      09-18-2014, 08:14 PM   #5
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Careful with that +5 my man... Personally I would run a bit of race fuel (110 or 112) mixed in the tank with that setting just for "insurance" if you know what I mean.
Brian
/// 2o13 m6 f13 . jb4 tuned . meth injected . msr intake . 21" adv1 wheels . eisenmann race w/ catless DPs . vorsteiner full aero . accuair e-level w/ bagged KW V3 struts . dinan sways . bel stir+ w/ alp jammer . jl audio subs
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      09-18-2014, 09:34 PM   #6
AstonMartian777
Drives: 2014 M6 F06
Getting catted downpipe is the biggest waste of money, alcantara wheel on the other hand is super sexy , how are you liking the gauge ?
      09-19-2014, 11:43 AM   #7
C5driver
C5driver's Avatar
3471
Drives: 55...just kidding.
Why?
      09-19-2014, 11:51 AM   #8
AstonMartian777
Drives: 2014 M6 F06
Originally Posted by C5driver View Post
Why?
you will barely get any results, whatever he is feeling, it's just in his head, and the price of catted after market dp is over 2k, that why in my opinion.
      09-19-2014, 11:57 AM   #9
michel lane
Drives: BMW M6 F13
Just take your cats out and use a very large chisel to destroy the cells . Many have done it on GTR , Supra's and I believe the Singapore member has done it aswell.
Catt'ed Dp will let more flow through yet keep the engine light under control and fall under emissions level in certain countries .
      09-19-2014, 12:44 PM   #10
C5driver
C5driver's Avatar
3471
I've heard that the decatted DPs don't create enough back pressure, so there's excessive waste gate chatter from the turbos. Any experience with this?
      09-19-2014, 12:49 PM   #11
AstonMartian777
Drives: 2014 M6 F06
You don't need no back pressure if you're running higher boost
      09-19-2014, 03:32 PM   #12
EuroKar
What about the engine control module seeing that the oxygen sensors are receiving too much of a reading due to no cats and the computer backs everything down as it is programmed to do.
BMS is not resolving that issue. Upping the boost does not fix that either.
A catlless exhaust system performs lower on a dyno then a engine with a stock exhaust. Seen it done back to back many times
      09-19-2014, 03:41 PM   #13
AstonMartian777
Drives: 2014 M6 F06
It needs time to adopt
      09-19-2014, 04:06 PM   #14
m6beast
m6beast's Avatar
185
Drives: stock m6
+1
Adaptation is the key!
When I cut my muffler off the car had no power like I lost 4 cylinders. If I would have dynoed the same day it would have shown loss if power tremendously.
After the car adapted it was a beast
Full torque and in 1000rpm sooner and power across the board.
Same with catless DP power across the board and coming in earlier. Test need to be taken at least after a week to make sur car has adapted fully especially for a change like that.
Making some catless DP right now and hoping to take care if the cel using my M5 as test mule hopefully will work like my past cars
Once I have ready for install will Dyno before and after adaptation
      09-19-2014, 04:47 PM   #15
C's Bimmer
C's Bimmer's Avatar
Brian
I'm running 100 octane all the time now.
Current Garage:
      09-19-2014, 04:51 PM   #16
C's Bimmer
C's Bimmer's Avatar
I completely disagree. Huge difference. 400 cell vs 200 cell is without a doubt much better. I also got mine used, so they were actually cheaper than catless DP's.
Current Garage:
      09-19-2014, 06:43 PM   #17
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
Yes I did the remove of ceramic cat in the stock DP, results is day n night. The turbo spool way much faster n if u install a micro cat on the bung u will not get the CEL light.
But now I'm using SS catless DP n got the CEL light even with 2 extended micro CATTED bung.
      09-19-2014, 07:00 PM   #18
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Anything that flows better is going to yield better performance. I would have to see for myself a Dyno run with OEM catted vs Catless to truly believe the catless loses power.
Brian
      09-19-2014, 07:33 PM   #19
EuroKar
Brian
I am trying to find the dyno sheet to show this.
M6 Gran Coupe with GT Haus full catless exhaust system with no tune VS M6 Coupe completely stock.
Both are forum members here.
The stock M6 out performed the Gran Coupe back to back dyno runs. Same dyno, operator, fuel, etc..
LSM is the forum member with the stock M6 coupe. He made a post on here and its somewhere back in the list.
His posts even states that we went with the Gran Coupe and he posted the numbers for everyone to see.
It didn't blow it out of the water insanely but it was enough to think twice about spending thousands of $$$$
Now, I love aftermarket exhaust just like the next guy. Just my opinion on dyno results of the current topic
      09-19-2014, 11:29 PM   #20
C's Bimmer
C's Bimmer's Avatar
100% agree. Is it as good as catless? Of course not, but once you compare the 2 downpipes (OEM vs Catted) and have them side by side and look at the cats themselves, it's so obvious that the AMS catted DP's flow better than OEM.
Current Garage:
