06-20-2015, 05:32 PM | #68 |
Rep 3,247
Drives: BMW i8
06-20-2015, 05:36 PM | #69 |
Rep 1,125
06-20-2015, 05:50 PM | #70 |
Rep 3,247
Drives: BMW i8
06-20-2015, 06:01 PM | #71 |
Rep 1,125
06-20-2015, 06:19 PM | #72 |
Rep 3,247
Drives: BMW i8
06-20-2015, 07:40 PM | #73 |
Rep 6,072
What's the monthly payment of this beauty ==================================^^^?
06-20-2015, 07:56 PM | #74 |
Rep 1,125
06-20-2015, 10:43 PM | #76 |
Rep 3,247
Drives: BMW i8
06-21-2015, 10:47 PM | #78 |
Rep 3,247
Drives: BMW i8
Its different in a couple ways. Obviously you give up perfect shifts every time with zero lag in between however' the clutch/gearbox is so advanced/forgiving- Ive never been able to power shift so easily. However- its a tricky clutch because while smooth as butter, the sweet spot is further into the clutch, so it takes a little getting used to.
It really comes down to how well experienced you have with a MT that will make the drivability up to par w/ the dct- but fun factor (for me) theres no comparison. Until you get the timing down- its big long shifts. However- if you plan to track the car-its honestly too heavy and the perfect shifts of a dct are necessary. Theres no question dct is slightly faster if you havent really learned the clutches sweet spots, but like I said above- once you get used to it- I wouldnt trade it in for the world one thing that bothered me about the dct is how jerky it is in 1st gear. None existent with the Mt. |
06-21-2015, 11:55 PM | #79 | |
Rep 6,072
The first gear of DCT has 4.81 :1 gear ratio while in case of MT it is 4.06 :1 ; So DCT (in first gear) is 18.5% shorter and transfers 18.5% more torque to the rear wheels and that's what you call it jerky especially when the throttle response is set to sport+
06-22-2015, 12:34 AM | #80 | |
Rep 3,247
Drives: BMW i8
06-22-2015, 02:12 AM | #81 |
Rep 2,352
I don't understand why 1st is so short unless it is for clutch life when people are unexpectedly slipping the DCT clutches. It isn't like you're ever going to get grip in 1st!
06-23-2015, 12:43 AM | #82 | |
Rep 6,072
With that said, the first gear ratio of new X5M/X6M is rated at 5.00:1 with about 10% more torque (at crank); however those cars are AWD.
06-23-2015, 08:30 AM | #83 |
big pimpin
38
Rep 327
zero room in the back seat of a 2 door. Have him sit up front and her short ass in the back. My 12 year old can barely get his feet on the floor in my Gran Coupe in the rear without the front seat squishing the front passenger.
dont let her tight black dress, light brown hair, freshly shaved backyard fool ya
2014 //M6 GC
2015 750Li 2015 435i GC |
06-23-2015, 09:31 AM | #84 |
Rep 1,125
Flying Ace4987.00 |
06-23-2015, 02:08 PM | #85 | |
Rep 2,352
Their rolling radius is also more however, 13.48" versus 14.34". Final drive is the same, and of course as you said first is shorter. Here is a fantastic and actually relevant article! http://m5carblog.blogspot.co.nz/2013...er-part-2.html So the torque to the ground in an M6 DCT in first is actually a peak of 502 * 3.15 * 4.80 / 13.48 * 12 = 6757lbft. Note his numbers are similar but I've used the actual numbers, he rounded a bit. In the X5M it is 553 * 3.15 * 5 /14.34 * 12 = 7288lbft. A manual M6 would be 5715lbft, probably a lot easier to get grip in! |
06-23-2015, 05:49 PM | #86 |
Rep 418
Updated Pics!
Some new pictures with tint and the vorsteiner side skirts.
Full Vorsteiner Aero Kit, ADV5.0 M.V2 CS rims, KW HAS kit, M Performance Exhaust w/ CF tips, CF Mirror Caps, CF Gear Selector Lever, CF Side Marker Gills, CF Front Grill, Dinan CF Intake, AFE CF Engine Cover, Stage II Dinan Tune, Exhaustmeister, Internal Escort 9500ci + Laser Shifters, Photosync window tint 65% windshield 35% windows, Full PPF xpel ultimate wrap, RK Autowerks noncatted DPs, reflector delete, various coding
06-23-2015, 06:28 PM | #87 | |
Rep 6,072
Torque (at wheel) = Torque (at crank) * gear ratio * FD ratio * (1-drivetrian loss) So at 576 lb-ft torque at crank ( measured by Dinan) and considering 12% drivetrain loss, M6 DCT transfers 8709 lb-ft (576*4.8*3.15) and puts down 7664 lb-ft of torque (576 *4.8 *3.15 * 0.88) M6 MT puts down 6482 lb-ft. I believe the actual torque of X5M/X6M is more than 600 lb-ft (at crank) so they put down over 8000 lb-ft of torque!
06-23-2015, 07:00 PM | #88 |
Rep 1,149
