BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      02-25-2014, 08:33 AM   #23
gallian93
gallian93's Avatar
Drives: 18 M3 cs/72 tii
Originally Posted by JamesKilcarr View Post
hi guys i currently have a 295/30/19 rear tire on my e92 and it rubs slightly while hitting big bumps, does anyone know the best tire performance wise for that size that will not rub or rub very slightly like it does now, the car is not lowered at all
thanks
I'm running 275/30 and 295/30 on VMRs
haven't had any rubbing issues...
did you have passengers when you hit the big bumps?
[/B]2018 BMW M3 CS (SMB) (Daily Driver)1991 E30 w S52 swap(New addition)[/B]1972 BMW 2002tii (ITS ALIVE)2013 X5M (Wife's DD) ,2009 AUDI A4 3.2 (Winter/Aupair) 2010 e90 M3 (Sold 2020),2011 X5 5.0i (Traded 2019),2007 335 IX(sold 2018),2008 Z4 MC (sold 2017 Still sad about it), 2011 X6M (sold 2015)2008 E93 M3 (Traded 2013), 2005 e46 M3(solidified affair)(wrecked 2010), 2002 330Ci (started love affair)(Sold 2009)
      02-25-2014, 05:40 PM   #24
flea333
flea333's Avatar
Drives: 2013 M3 ZCP, LMB, DCT
2008 328i  [0.00]
Originally Posted by Kurt_OH View Post
Can you please share the rest of the tire info?
Brand/model, aspect ratio.
I'd love to run 275 / 295 and I'm thinking the PSS 275/30/ZR19 and 295/30/ZR19 look like a good set. Is that what you're running, stock?
Did you end up getting this set? I'm very interested in getting the same for some nice thick tires. What differences did you notice from stock? Any rubbing?
2013 M3 LMB, DCT, ZCP, Premium, EPS, Bamboo Beige, Apps, sunroof
      02-27-2014, 06:03 AM   #25
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
I haven't done it yet. February isn't really M3 weather here in central Ohio...I'll probably put them on in early April, and I'll be sure to report back ASAP.
But, since I've received only favorable responses from folks who have done it, this IS my plan:
PSS 275/30/19 and 295/30/19 on stock ZCP rims. Everything else stock (Except brake pads on track weekends...).
What's your tire schedule?
I need to search for info on what I can do camber-wise with my stock setup - find out how much adjustment is available and how much I should tweak it...
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream.
- Jeremy Clarkson, discussing the S65 and then S55 M3 engines.
      02-27-2014, 06:31 PM   #26
flea333
flea333's Avatar
2008 328i  [0.00]
Well the only thing I have to worry about here is rain, unless I drive up to the mountains, which I haven't ventured to do yet, so I'm getting mine installed next week.
Slicer and other forum members convinced me that the 255/35, 275/35 is perfect for the car and rims. So I ordered those in PSS's. If PSS came in 285/30 I would have done that.
I figure unless I get my car supercharged, there's probably little benefit to having such a massive tire, although much sexier.
      02-27-2014, 06:54 PM   #27
M3/4 life
M3/4 life's Avatar
Drives: E92 M3
2013 BMW X5  [0.00]
2009 BMW M3  [0.00]
I’m currently running the PSS 255/35/19 upfront & 295/30/19 in the rear on Velos VII wheels 8.5 front 11 in the rear at stock height and have no rubbing. As for as gas mileage goes I’m getting the same mpg as before however I did just get the spark plugs changed as well.
2009 E92 M3 DCT: BPM tune + DCT tune & Servotronic | Velos Solo VII 19x 8.5, 19x11 | Michelin Pilot Super Sport 255/35/19 front 295/30/19 rear | M Performance Exhaust | BCM Air Intake Filter
      07-01-2014, 08:40 PM   #28
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
Just did it today on the back: PSS 295-30-ZR19s. Only drove home, but no rubbing and looked great - way better than stock and way better than I thought it would look. Wheel wells look stuffed but not sticking out, and look FAT from behind.
I did get on it a little to see if any squat caused a rub - no rub so far. They are still kinda slippery though; spun easily.
Originally Posted by JAdamz View Post
I just put 275/295s on my E92 ZCP (stock height), absolutely no rubbing and it grips incredibly.
Thanks for the advice/encouragement; I'm very happy with the look and no rubbing so far!
      07-02-2014, 08:51 AM   #29
jra85
M3NTAL
jra85's Avatar
Drives: 2011 E92 M3 ZCP
Looks good, glad to hear they fit well! I definitely noticed the increase in grip once I swapped (though I'm also running 275/30 fronts). They look much better than stock too.
      07-03-2014, 03:17 PM   #30
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
Update: occasional rub at highway speeds during even moderate compression.
May adjust camber and report back
      07-04-2014, 09:42 AM   #31
jra85
M3NTAL
jra85's Avatar
I would give it a few weeks of driving and see if the rub disappears. My rears rubbed very very slightly when new by maybe a millimeter or so. Didn't hear it, just observed it on the edge of the tires. Doesn't happen anymore.
      07-04-2014, 01:55 PM   #32
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
Agreed.......wait it out and see what happens. J, how's the 275 up front doing? I will be going to that size on my next tire purchase..............Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
      07-04-2014, 03:30 PM   #33
slicer
slicer's Avatar
2738
Drives: 'E46 M3 Race Car, '23 X7
I don't see the point in running 295's on a 10" wheel or 275's on a 9". You need at least 1/2" wider wheels for proper support of that size tire. The only reason I can imagine is if you are running in an Autocross class that limits wheel sizing.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      07-04-2014, 05:44 PM   #34
jra85
M3NTAL
jra85's Avatar
Holding up very well, zero rub, though I started a new job about 8 months ago where I work from home so I haven't been driving the car as much. There has definitely been a little feel lost in the steering with the wider tires, but for street driving the added grip (and look) is everything I wanted. Thanks again for being the "guinea pig" as one of the first to try this setup on your car
Slicer, I understand your opinion on this subject and you've voiced it many times before, but once I have an idea in my head and I've decided that's what I want, logic be damned I like the ZCP wheels and have no plans to buy wider wheels, and with the 275/295 combo being (just barely) the second closest to factory diameter apart from the 255/275 combo, I decided to go for the wider rubber at the expense of steering feel. I'm happy with it, and I think that's all that matters.
      07-21-2014, 03:32 PM   #35
Nola 32/65
Nola 32/65's Avatar
Drives: 2012 E92 ZCP M3 6MT
Will a 295/30 PS2 on a stock height stock suspension ZCP E92 work?
From this thread I've seen people are saying the PSS tire in the 295/30 works with no rubbing but what about the PS2? Are people buying the PSS because its cheaper or because it doesn't rub and the PS2 does?
Thanks in advanced!
      07-22-2014, 08:26 AM   #36
jra85
M3NTAL
jra85's Avatar
The PSS is the successor to the PS2 and is a superior tire in nearly every way. Unless you have access to an old stock of PS2s that you're getting for free or something, I don't see any reason to go with PS2 over PSS.
      07-22-2014, 04:44 PM   #37
Nola 32/65
Nola 32/65's Avatar
Ohhhh, well that makes sense.
I found someone selling a pair of 295/30/19 PS2 tires with maybe 1000miles on them for a really good price so that's why I asked. Thanks for the information though!
      07-25-2014, 07:16 PM   #38
quiksi
quiksi's Avatar
Taiwan
75
Drives: E90
ZCP suspension, my rear wheels are 10.5 +28 and I do not rub with 295/30/19 Bridgestone S04's
2011 E90 M3 6mt AW/Speed Cloth - ZCP, Moonroof, non-iDrive - PCD 12/9/10
Painted reflectors, matte black grills/gills, Deansbimmer Belly Pan, DEI Alarm, Homelink/compass retrofit, Passport MAX2 Hardwire, GP Thunder 8500K, modmy3 LED interior, Dinan Mufflers, HRE P40 19" Satin Charcoal, Michelin PS4S
Tags
lowered, performance tires, tires, vmr wheel, wheels
m3post
