08-20-2019, 07:34 PM | #134 |
Rep 116
1. Is this the new updates Navigation map??
2. I have my car coded for extra goodies, like top down with the remote for example and etc.. 3. If i update it, will my codes be deleted?? |
08-21-2019, 11:15 AM | #135 | |
Rep 269
Drives: ///M6 GC
Glad to hear. No problem!
2. I coded my car as well 3. No. Does not affect coding or tunes. You will need an FSC code to install the map unless you purchased a lifetime code in the past
PrideRock870.00 |
08-23-2019, 04:16 PM | #136 |
Rep 3
BadSeed - I have downloaded the files from your first post, unzipped them to a USB drive and for some reason when I go to my 2015 x5, nothing happens. Nothing pops up on the screen to update the navigation at all. I have a lifetime FSC due to a purchase I made awhile back directly from BMW.
So what am I doing wrong? |
08-23-2019, 05:04 PM | #137 | |
Rep 269
Drives: ///M6 GC
2. The file system of your USB drive is FAT32? If not, you can use this app to format it to FAT32 http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm 3. You have the following files\folders in the root of the flash drive? config.nfm NBT_NANT_111184.3.112.pkg NBT_NANT_111184.3.112.pkg.sig Folder 1 Folder 2 Folder 3 Folder 4 4. Some cars have 2 USB ports but only one can be used to load maps\music. You'll need to figure out which one you need to use
08-23-2019, 05:41 PM | #138 | |
Rep 3
Yes, the format of the USB is FAT32. The link you provided is the one I used to format the drive to FAT32 Yes, those files/folders are under the main folder for the map update. The only USB port in the car is in the arm rest. Last edited by jsc1205; 08-23-2019 at 05:53 PM.. |
08-23-2019, 05:55 PM | #139 | |
Rep 269
Drives: ///M6 GC
Did you use the USB port in the center console? On the USB drive, when you open it in File Explorer, you immediately see the files & folders or are they all inside another folder? Not sure what else it could be. Do you have another USB drive to use?
08-23-2019, 06:06 PM | #140 | |
Rep 3
08-23-2019, 06:25 PM | #141 | |
Rep 269
Drives: ///M6 GC
08-28-2019, 12:25 PM | #144 |
Rep 269
Drives: ///M6 GC
PrideRock870.00 |
09-09-2019, 07:30 AM | #145 |
Rep 9
Could those maps be used to update NBT EVO? If not, then how to update maps for EVOs?
My 2016 640i seems to have NBT NEO v4. See the screenshot: Thank you! |
09-09-2019, 07:35 AM | #146 |
Rep 41,049
Drives: 2018 Alpina B6 650ix GC
Screenshot shows NEXT Map, meaning NBT, not EVO map for NBT2 ID4/5/6.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
BadSeed158.00 |
09-10-2019, 09:34 AM | #147 | |
Rep 9
I bought a lifetime code on eBay for $10 to avoid e-sys hassle this time. The update took about a couple of hours from USB-3 drive. BTW, I've used 256GB USB-3 drive formatted as FAT32 on Mac - worked nicely. Make sure to clean up all those hidden files if you do the same. Thanks for helping! Last edited by alboko177; 09-10-2019 at 02:28 PM.. Reason: update |
PrideRock870.00 |
09-22-2019, 02:22 AM | #148 | |
Rep 33
12-12-2019, 03:27 PM | #150 | |
Rep 2
03-16-2020, 07:02 PM | #153 |
Rep 18
Hi all im a f30 owner so i know im in the wrong place but just wanted to say thanks nonetheless for this amazing guide which worked perfectly for my car and just a few things id like to add.
-32gb hard drive is sufficient, first tried with macbook pro to download map but car wasnt recognizing so i reformatted the usb again to fat32 and then redownloaded map to usb from PC this time and it worked like a charm. -fsc code was generated beautiful by jaeger app |
