02-28-2015, 03:20 PM | #1 |
Rep 66
Jb4 not working on 2015 640xi
I just installed the jb4 on my 640xi and I'm not getting any blinking lights on the shifter to acknowledge the maps.
I have no lights or codes on the dash, which confirms that everything was plugged in correctly. HALP please!! 😔 |
02-28-2015, 11:57 PM | #2 | |
Rep 18,713
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-01-2015, 01:04 PM | #3 | ||
Rep 66
Any thoughts? |
03-01-2015, 08:50 PM | #5 | |
Rep 66
03-03-2015, 12:23 AM | #7 | |
Rep 18,713
Did you bought it used?
03-03-2015, 11:02 AM | #8 |
Rep 66
03-03-2015, 12:11 PM | #9 |
Rep 592
03-03-2015, 08:59 PM | #10 |
MBACPA
13
Rep 91
I've always received an amazingly fast reply from Terry, and I think it's just his first name followed by their standard e-mail. I'm surprised you haven't heard anything from them, since they are good about that.
03-03-2015, 09:01 PM | #11 | |
Rep 66
03-21-2015, 01:54 PM | #13 |
Rep 66
ok, so apparently jb4 map switching is not compatible for 2015 6 series...
I was lucky i bought the one with the usb adapter so i can switch maps with my laptop, otherwise this thing would have not worked... |
03-22-2015, 10:19 PM | #14 |
Rep 536
03-23-2015, 12:28 PM | #15 |
Rep 66
Map 1 you only get up to 13PSI's out of the turbos.
I run on Map 7 which is supposed to be race gas (100 octane+) and give you up to 19 - 20 PSI's out of the turbos. It has been working great with 93 octane and i feel a HUGE kick. I will eventually do a video on this. |
04-15-2015, 07:23 PM | #17 | |
Rep 315
Map 7 is definitely more of a race map, and less of a daily driver map. A lot of us N54 guys just run Map 5 which is an auto-tune. Its a fairly aggressive map, but won't push the car beyond reasonable limits for reliable daily driving. OP, turn map 7 off immediately unless you're running race gas or 50%+ mixture of e85!
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
04-19-2015, 04:32 PM | #18 |
Rep 232
I'm about to order the JB4 for my 2015 640i and want to confirm that it won't work unless I buy the data cable too and have to manually select maps?
04-19-2015, 05:31 PM | #19 | |
Rep 66
I even updated to the latest firmware and nothing. So, yes be safe and buy the usb version so that you can use your laptop to switch maps. Good luck! |
04-19-2015, 05:35 PM | #20 | ||
Rep 66
How do you explain that? : |
04-19-2015, 11:17 PM | #21 | |
Rep 18,713
Let me know if you need to get a hold of a unit.
04-25-2015, 11:38 AM | #22 | |
Rep 152
This stuff is not like a grenade where you pull the pin then there is a guaranteed explosion after a few seconds of operation. Oh, it certainly can be like that, but not always and more importantly with engines not usually. If (and I do mean if, because I really don't know exactly how much is being attempted by one of the BMS tuners at all, let alone about their specific maps - like Map 7) - if they are pushing the boost, ignition timing and A/F (air to fuel ratio) to the point they match a tune (or Map) to the particular characteristics of a fuel (like octane for gas or ethanol/methanol) then I would bet it is pretty tight on the tuning - they have pushed boost, timing and fuel to what they think the engine will reliably handle over time. I would think that is especially true if they have a different map for 93 average octane pump gas and 100-101 average octane "race" gas. Assuming that is the case, what you are more likely going to see is a gradual weakening of one or more parts until enough stress fractures have been created that some day there is a catastrophic failure of a component or two. At that point it probably will go boom. Though it is in no way the same process, I would liken it to bending a piece of solid core wire back and forth to friction melt it: grab a piece of solid core wire in both hands. whip your wrists back and forth as rapidly as you can, and it will soon break apart. The wire is going to hold up for a while and everything will seem fine. But eventually after it has been worked beyond its design limits long enough the wire weakens. You will gradually feel it when it starts to approach this point as it will suddenly become noticeably easier to bend the wire. Then it will fail and break in to two pieces. The problem with an engine is you don't know when it is getting to this point. There are rarely any signals until it just goes. When it does, most of the ones I have seen usually take out enough other stuff that it's hard to tell what happened first. This is a very simplistic explanation of detonation and what it does. In reality there are a lot of other variables. Turbulence of the mixture in the combustion chamber is a big one. But it will give you an idea of what is going on and why you might want to rethink running on map 7 unless you put some 101 octane and/or meth in it When your spark plug ignites the fuel around it, everything does not burn all at once. There is a flame front that progresses across the combustion chamber. As I recall from when I used to work with this about 25 years ago the flame front velocity is about 200-300 feet per sec (or maybe it's 200-400 fps). As the flame front progresses the hot burnt gases behind it are rapidly expanding so it is further compressing the end gas (the remaining unburned fuel). This brings it closer to self ignition. If all goes well that never happens and all the fuel burns at a controlled rate. The complete burn takes a few milliseconds. What you want to have happen is for the pressure from the burn to hit and push on the top of the piston when it will produce the greatest force on the crank - the most torque, and since HP = Torque * RPM/5252 the most horsepower too. This burn rate is why ignition timing varies with engine speed. That the burn rate changes with temperature and pressure (and other factors) is why they vary timing with those variables too. Knock occurs when the conditions of the unburned fuel in the combustion chamber reach the point of self ignition. The worst case is dieseling - where there is no ignition and the mixture just blows up under compression, just like a diesel engine uses compression to ignite the mixture. Most often in a gasoline motor it is some small remnants of unburned fuel that go off on their own rather than a controlled burn. When detonation occurs, the end gas goes off all at once; it essentially explodes. This explosion produces a much larger pressure. It also produces a concussion wave that progresses across the combustion chamber at around 2,000 fps. Unlike the flame front that dies when all the gas is gone, this pressure wave only dissipates by friction with the sides of the combustion chamber and repeated collisions with the top of the piston and the cylinder head (and I guess after the exhaust valve has bled some of it out of the combustion chamber into the exhaust system). This is the "knock" you hear. That friction of the pressure wave running along the walls and hitting the piston and cylinder head makes things very hot. Thus the fuel that comes into the chamber on the next intake cycle will be closer to the point of self ignition too. If allowed to continue for very long this heat creates extra and perhaps excessive heat stress on the engine. This is not too good either - no, sarcasm aside, this can be very bad. Look at all the radiators BMW puts on this engine to keep it cool and you will get an idea how important running cool is. Knock is also literally hammering the engine. Though I am an electrical type, I know that impulse loading of anything mechanical is usually not good, especially when it is very hot (materials are usually weaker when heated). In case you are not aware, a big part of the reason that the A/F drops to 12-13 range as you approach wide open throttle is that the extra fuel helps cool the combustion chamber. All this said, an engine will make a little more horsepower when it knocks just a little (I'll be glad to explain that if anyone wants to know). Ideally for the best efficiency and a little more power you want to have a little knock, but very little. But since knock usually generates extra heat and heat increases the chance of uncontrolled knock, running on the threshold of very light knock is not something that is easily maintained. That is especially true when you consider how large the cyclic variations between successive engine cycles can be - in other words, the amount of fuel and ignition timing and air entering the cylinder is not exactly the same every time. They have gotten a whole lot better at controlling it in the last 25-30 years but there is still some variation. When you are trying to control something with precision, the last thing you want is another variable to worry about. The extra heat from detonation is about the worst thing that can happen. Also consider that the engine control system will try to adapt to the knock it is seeing. I do not know the actual strategy the DME employs but generally reducing ignition timing and boost are a good first guess. I'd go with timing first (since it is the quickest to control -you can get the very next cycle), then boost (probably at least a few revs if not a bunch will occur before that can be reduced), and since it is drive by wire maybe throttle too if the other two don't bring the knock under control. Just like your car's engine computer will adapt to the changes you make to improve performance (bolt on stuff and a tune) it will also try to adapt its tuning over time to reduce the knock. It will succeed up to a point, but from what I understand about the BMS system (the fact that they have maps for various operating conditions) I would guess that it cannot completely adapt enough to completely mitigate the problem. Look at Formula One for an example of what happens. Those motors are stressed like crazy. The tolerances are so tight that they have to run hot water through the cooling system and hot oil through the lubrication system to bring the mechanical components up to operating temperatures (or closer than just sitting there at room temp) before they can even try to start the engine. Even with all that precision and all the finest components unlimited sums of money can buy these engines are still pushed so hard that they have to use 4 or 5 engines to make it through the entire 20 or so races that comprise a season. What you are doing when you run an engine in knock all the time is heavily stressing it. I suspect that this is what you may be doing to your engine by running it on a map that is intended for race gas - pushing it too hard, essentially beating on it. Think running with a quart or two less oil than it needs to be full, or straight water instead of a coolant/water mix, or not enough water. You may get lucky and it will last until you move on to another car. Or it might go the net time you floor it. Frankly, with an engine that runs about $30-40K I would not want to chance this. But maybe you have the resources and can be without the car while it is being rebuilt, or a new one acquired and installed. That definitely would be a great time to really hop up that motor . I have heard the rods are the weak point. I also read in the S63TU Engine Manual (appears to be a BMW publication that you can find it in this forum) that the pistons are cast. They are Mahle's (very good pistons from a great piston maker - at least they were back when I was seriously in this stuff) but they are cast and not forged. On top of that, the mechanical compression ratio is 10.0:1. That is pretty high for a turbo motor, and especially one running around a bar of boost (14.7 psi). From what I have read these engines sometimes produce even more boost. I am not sure but I think the BMS race gas tune may be up closer to the 18-20 range. In their forum I have read 20-22 or so but I may have that wrong - I'm still trying to figure out all the BMS and BMW nomenclature). If this is the case, you are asking for trouble. A lot of this will depend on your driving style too. If you do just an occasional hard acceleration to get on the highway or pass someone you are more likely to get away with it for a longer time. If you are doing banzai autobahn runs (high speed driving and repeated accelerations at those speeds) , sustained and/or repeated hard accelerations, or any kind of really hard driving where you are using most of the engine performance and the engine is not given a chance to cool down you are more likely to run out of luck much sooner - think F1 engines. Think ticking time bomb. It's your car and your choice, but I wouldn't do it. Not for very long anyway. On the other hand - If you do end up with a lunched motor and you want to rebuild (assuming the critical things are still intact - not sure it's likely with an Alusil lined aluminum block but who knows), but this sure would be the perfect time to go for a huge power motor or even just beef up the one going in with forged pistons and rods. Even if you have to start with a completely new engine, that new engine would still be out of the car and it'd be much easier to build a really super strong and high power one then, rather than having to pull it out of the car. I have always thought BMW engines were heavily overdesigned. This has been reinforced by both my personal experience and observations of others' experiences with them. For example when they went into F1 I read they used their stock 4 cylinder block and got something like 1000 hp out of it. Wikipedia says 600 out of a 1.5 liter with 2.8 bar boost (41 psi) but I seem to recall C&D or R&T reporting about 1000 one year - not something a hard core car nut driving a 4 cylinder Bimmer forgets. Still 600 out of a 1.5 is 400 bhp per liter. I don't see why you couldn't get a very reliable 250-300 bhp per liter out of this engine - maybe more with all the high tech goodies on it, perhaps a lot more. I have seen that or perhaps a bit more on a car with very basic electronic fuel injection and a very early distributorless ignition system (mapped RPM and MAP) that ran 70K miles before I lost track of it (still running strong). It did not have double VANOS VVT, or scrolled turbos with a pulse manifold (360 degree opposed cylinders feeding the same scroll and opposing cylinders feeding the other scroll) - I suspect they are probably roller bearing too. To do this at the least it would take forged pistons, forged Ti rods and a couple of bigger turbos; probably some head work too (port, polish and match to manifolds), maybe cams as well. I have read the DCT would probably need some help to handle all that but hopefully just some clutches and a maybe few other easy components (I know next to nothing about transmissions - no, less than nothing). And a whole lot of computer tuning. Most likely it would be a very expensive venture but think of the results! You'd definitely need a whole car wide body kit to cover the rubber it would take to get that kind of power on the ground. That or a new set or rear tires every week or two - maybe every day or two. Talk about a beast. Last edited by chask; 04-25-2015 at 03:23 PM.. |
