07-18-2017, 12:44 AM | #1 |
Rep 18
Spark Plug Change on F13 M6
Took my F13 M6 in for oil change with 38k miles and dealer says its due for Spark Plug change... $920. Thinking of changing plugs myself and just replacing plugs... has anyone done this without new ignition coils for this interval? any issues?
07-20-2017, 10:59 AM | #4 |
Rep 739
i wouldnt wait that long... I changed mine at 35k
IG Page: @bo_buttaa
07-21-2017, 03:07 AM | #5 |
Rep 138
any DIY?
Current: 2013 F13 M6 | Singapore Grey Metallic on Sakhir Orange/Extended Black Merino | Bootmod 3 Stage 2 | Dinan Free Flow Exhaust | M-Performance CF Rear Diffuser | Charcoal Filter Delete BMC Replacement Air Filter |
Current: 2011 E92 M3 | Alpine White Grey Metallic on Black Novillo | AlpineMSS Stage 2 Tune GTS DCT Tune Euro MDM | Rogue Engineering Testpipe ACM Muffler Mod | M-Performance CF Front Lips | BMC Replacement Air Filter | Retired: 2011 F10 535i | Carbon Black Metallic |
07-21-2017, 08:52 AM | #6 |
Super Member
129
Rep 344
I might change out my coils and plugs sometime this month, I can make a write up for you guys.
I recommend using 1 step colder for the guys that plan on modding their cars.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust |
07-21-2017, 04:27 PM | #8 |
Super Member
129
Rep 344
Hopefully we can start a DIY sticky with the M5's and M6's.
07-21-2017, 06:43 PM | #9 |
Rep 138
We're waiting! Thanks man!
07-23-2017, 10:14 AM | #10 |
M Master
74
Rep 551
I did my own plugs.. The OEM Plugs are perfect, even for modified/tuned cars..
No need to go Colder Step with our cars..researched this.. As for install its very straightforward and easy.. You will need a special socket thats super thin to get the plugs out.. I got/ordered mine at Autozone.. You can also look around for a shop that has them in stock. I forget what its called, but search for "Thin Spark plug socket' Besides that, basic tools will do the rest of the job. There is One annoying part.. The Coil lines are packed tightly, so to get to 2 of the plugs is a bit of a pain. You really have to wiggle/stretch the cable to reach down in it.. You can also slowly remove parts of it to get more access.. Just take your time and you shouldnt have a problem. Remember to torque the plugs to the correct common torque.. I think its around 20lbs.. a search will yield this. Good luck!
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
