08-16-2016, 11:40 AM | #1 |
Rep 48
Drives: '14 535i Msport, 99 M Roadster
TPMS Module Location
I've been having error message pop up daily about the TPMS system not functioning properly. Quick reset and it goes away. The sensors in the tires checked out OK. Haven't pursued it any further.
Getting some coding done and was told I could shut down the TPMS if I can unplug the Control Module. I've looked around quite a bit and can't find it. Anybody know where it is? 2012 F13 650i Msport Thanks! |
08-16-2016, 05:26 PM | #2 | |
Rep 18,712
For 2012, it is about time the battery running out.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
08-17-2016, 08:57 AM | #3 |
Rep 48
08-17-2016, 09:32 AM | #4 |
Rep 18,712
Did they tell you how much battery left in the sensors? If they have a good tool, they should be able to indicate the battery status.
08-17-2016, 10:04 AM | #5 |
Rep 48
08-17-2016, 10:46 AM | #6 |
Rep 1,719
yes - when they start setting off your low tire pressure warning for no reason.
08-17-2016, 11:43 AM | #7 | |
Rep 18,712
08-17-2016, 12:38 PM | #8 |
Rep 48
Gosh...Thanks!
08-17-2016, 12:39 PM | #9 |
Rep 48
08-17-2016, 02:14 PM | #10 |
Rep 1,719
I was being serious. If the TPMS is going off and the pressure is fine and the TPMS sensors are 4-5 years old then change them. Sure they can stick their test tool near the wheel and pick up a signal but that doesnt mean its strong enough for the car to pick up. You will spend hundreds or more for a BMW tech to diagnose or next to nothing for your local goodyear store to put on new TPMS as long as your order them on line. Your local tire shop will rape you for the TPMS.
08-17-2016, 03:50 PM | #11 | |
Rep 48
I do appreciate your help |
08-17-2016, 04:06 PM | #12 |
Rep 1,719
no problem. I guess it sounded a little snarky - but its the truth!
08-18-2016, 09:36 AM | #14 | |
Rep 18,712
Better than any $20 pressure gauge.
08-18-2016, 02:39 PM | #15 |
Rep 133
How do I know if my wheels have the TPMS in them without going to a shop to check? When I bring up the tyre status screen it doesn't show pressure or temperature values (coded to) they remain blank.
08-21-2016, 09:12 AM | #16 | |
Rep 18,712
06-13-2022, 08:18 AM | #18 |
Rep 2,906
06-13-2022, 11:19 AM | #20 |
Customize Everything!
44
Rep 279
This most certainly does. I assume my RDC is going bad because I got the TPM malfunction warning. I spoke to my service advisor and he mentioned that sometimes one bad sensor can throw off the whole system. I would imagine just one would show a fault and just be greyed out in the I drive. But if any truth to one sensor being faulty and bring down the TPM system, time for that sensor to go.
06-13-2022, 12:13 PM | #21 | |
Rep 7,468
Ditto Opie55's reply in the other thread...it appears to be a small component (see current part nbr 36-10-6-881-474 below). And the part database lists multiple part nbrs which have been super...if buying used they are retroactively compatible. Supersession Part number - Production ended
06-13-2022, 12:22 PM | #22 |
44
Rep 279
I was able to pull the part number but was having trouble locating the module in case I needed to do the replacement myself. My service advisor just confirmed that the 1 rear driver side wheel tpms sensor is shot and keeps throwing the fault code.
Tpms is being replaced and tire balanced. All is good now. |
