03-28-2019, 07:44 PM | #1 |
Master Of My Domain
89
Rep 669
I've got the 1 key from my 2015 650 GC that didn't go to the salvage yard. $85 for one or both for $150. The one with the BMW Roundel is available, the one with the 6 has been sold. EDIT: I have called a few BMW dealerships and they say that they aren't allowed to reprogram a key fob/remote, the key needs to be programmed from the factory (buy a new key $$$), but they all said that there are independent shops that have the programming equipment available and can do it, you just need to find them.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
03-29-2019, 05:41 AM | #3 |
Rep 469
I’m almost 100% sure that newer bmw fobs cannot be programmed to other cars. Only once when the key comes from the dealership. Correct me if I’m wrong but the only ones that can even program a new fob are the dealerships. Especially with comfort access
03-29-2019, 06:36 AM | #4 |
Master Of My Domain
89
Rep 669
I was always under the impression that the keys could be reprogrammed to another car.
03-29-2019, 09:56 AM | #6 |
Master Of My Domain
89
Rep 669
That's true, but I've owned 3 BMWs since 2008 and have never used the key blade once. But there's always that one time.
03-29-2019, 01:01 PM | #8 |
Rep 469
03-29-2019, 02:15 PM | #9 | |
Rep 397
03-29-2019, 03:09 PM | #10 |
Rep 7,535
Remember that the keys operate 3 different systems:
EWS uses an encrypted ISN (individual serial number) that is coded to the car and only BMW has the information in a database. This information is communicated between the DME, key and CAS/FEM/BDC modules (on these later F & G series). This data is hard to retrieve (if even retrievable in the latest iterations). The FZV & DWA (lock/unlock & arm/disarm) features of the keys used to be reprogrammable on other BMWs that operated on the same radio frequency...but I'm not sure how easy or simple this is anymore with the increased technology of the newer gen BMWs with comfort access etc. But even if it is doable...it is different than the immobilizing (EWS) engineered designs. This is what makes used BMW keys almost impossible to reuse. The older E series BMWs can be repurposed if you have an AK90 set-up...which requires retrieving the EWS ISN data from the DME or EWS control module...then rewriting that info on a new transponder that is inside the remote key fob. But again, the new gen BMW keys that have comfort access have a higher degree of technology and the data is written to the CAS/FEM/BDC modules...and I'm not sure how a professional keysmith (or thief) goes about retrieving this data and writing it to a new transponder chip which would then need to be installed in an old (already used) BMW remote key fob. The mechanical key can be purchased separately (see #5 in diagram)...so if you can find someone who can actually retrieve the encrypted data and write it to a new transponder...as well as fit it inside your old remote fob...you can order a new keyblade from BMW and get it already cut through them...or if you want to chance it with a local keysmith...you can buy a blank, then have them cut it. But I'd make d$#m sure the local keysmith knows for certain that they can do it...and if they screw up...its up to them to make it right or eat the cost of a screw-up/mistake. EDIT: here's some info from the TIS about EWS & keys:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-29-2019 at 03:58 PM.. |
03-29-2019, 06:32 PM | #11 | |
Rep 83
03-29-2019, 07:01 PM | #12 |
Rep 1,255
lol dude you cant just buy a key and reprogram it. this is a paperweight at best. ive lost keys plenty of times, i had to buy a 500$ replacement at the dealer later each time. only the dealer can send you a new one.
03-29-2019, 07:58 PM | #14 |
Rep 469
Right? This ain’t some 05 Honda Civic that the local “mobile van locksmith” claims he can program. People don’t listen.
03-30-2019, 03:32 PM | #17 | |
Rep 7,535
I know EWS 2 & EWS 3 have been cracked in that the aftermarket AK90 can retrieve the data (EWS encrypted individual serial number) and write it to a new transponder. But as mentioned in my previous posts...I've not seen EWS 4 cracked yet. Perhaps it has...so let us know if it can be done successfully.
04-01-2019, 05:00 PM | #18 |
Rep 397
04-01-2019, 06:11 PM | #19 |
Rep 83
I haven't received my key yet as its coming from LA and I live in America Jr.
Here is the official answer from the local guy. "Yes i can. But the key itself has to be renewed before can be programmed to your car. It will have to be cut open renewed and put into new case. I can do all of it for $250CAD" So for all you doubting this cant be done, soon you will be proven wrong. They also said you cant load MPPK yourself and I proved those guys wrong as well. |
04-02-2019, 12:32 AM | #20 | |
Rep 328
04-02-2019, 06:53 AM | #21 | |
Rep 469
04-04-2019, 09:31 PM | #22 | |
Rep 7,535
Just for the record...I'll mention it again...I never said it couldn't be done...I just haven't seen the EWS4 hacked yet due to the change from the old gen BMWs that used EWS encrytion in the DME/EWS-CM/key transponder...and FZV/DWA under the control of the GM (general module). The AK90 can hack the EWS-CM and because those old BMWs had a keyed ignition...you can stick the key into the ignition & do a quick on/off which set-up the GM to redo the remote key's programming of the new rolling code table and key identification for every remote programmed during the same session. This gives you a key that can start the car and lock/unlock + arm/disarm the car. The new gen BMWs with EWS4 (again) has the EWS encrypted info written to the CAS/FEM/BDC...so if your guys equipment can retrieve that data and write it to a new transponder...then at least the remote will start the car. But how do you program the key to lock/unlock & arm/disarm the new gen BMWs? Can you take any BMW key on the correct RF (radio frequency) and hold it up to the marking on the steering wheel column...and it will program the key to lock & arm? :dunno: If you can, then we all will learn something new. For your sake...I hope it works out...the price (as someone mentioned) is still pretty high and not far off going the normal way through the BMW dealership. But perhaps the price will drop as it becomes a more popular way to get new remote keys. BTW...if he tells you to send your EWS control module or he'll need to hook up to your EWS-CM or DME...be prepared...because the floor is about to open beneath you!
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-04-2019 at 09:39 PM.. |
