      05-17-2024, 11:29 PM   #1
Prieforprook
Drives: mazda
I have 2018 reg 320i MSport with 110k Miles on clock
I have 2018 reg 320i MSport with 110k Miles on clock. Car has been running great until a couple of days ago when coolant level dropped and engine started heating up. I topped up with 1L of coolant and found it was dripping underneath around area behind engine. It's bad enough that a lot newly poured coolant has leaked and car had to be towed to garage. This is the first time a major issue has appeared and I was reluctant to take it to dealership.
I have taken it to a garage (claiming to be BMW specialist) and they haven't found any evidence of leak in first inspection. They have advised me to remove engine manifold to find the cause. I have looked online and seems to be some issues with pipes that can only be diagnosed after manifold has been removed.
Has anyone has any experience with this issue on F30? Some advise will be of great help.
      05-18-2024, 03:44 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
You're at the mercy of the shop. It shouldn't be too difficult for them to pressure test the cooling system.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      05-20-2024, 08:34 AM   #3
Hadden14
Drives: 2018 F80 M3 Comp
Pressure testing the cooling system is a minimum first step in my opinion. At that mileage could be something as bad hose or clamp, but it is not something you want to mess around with.
      05-20-2024, 09:59 PM   #4
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
You can look for BMW shops here:
https://www.bimrs.org/
https://www.bimmershops.com/
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
