      03-02-2017, 01:42 PM   #1
djcevo
21
Drives: M4
Wet rear footwell
Evening all.
My business partner has a 2012 640d and the passenger side rear footwell is soaking, there are no obvious clues as to why, can you guys help at all?
      03-02-2017, 03:09 PM   #2
6coupe
Drives: M6 GC
Convertible or coupe?
      03-02-2017, 04:49 PM   #3
djcevo
21
Drives: M4
Convertible
      03-02-2017, 05:34 PM   #4
6coupe
Drives: M6 GC
Makes more sense. The E85 Z4 had a similar issue due to the roof drains getting clogged and the water making its way in. I have no idea if the 6 has similar issues, but I'd check for other 6 convertible damp threads for likely causes.
      12-20-2019, 06:44 AM   #5
SpokenHands
Certified Car Nut
SpokenHands's Avatar
93
Yikes, I am having the same issue and absolutely beats me!!!!
All other footwells / seats / roof dry.
Door firmly shut
No leaks in the sun roof, B pillar post
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October)
Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series
      12-20-2019, 01:18 PM   #6
Yorkie36
Drives: BMW f13 650i
It’s the yellow gromit in the bulk head, had to do mine a few weeks ago. Must of removed 20 liters of water. Common fault
https://forum.bmw5.co.uk/topic/11609...in-water-leak/
      12-20-2019, 01:43 PM   #7
Opie55
Drives: '15 650i Convertible
Your link does not work.
      12-21-2019, 01:06 AM   #8
Yorkie36
      12-30-2019, 04:57 PM   #9
DE4NO
24
Drives: 2011 640d f13 alpine white
Mine also had this fault. Had the yellow grommet replaced and sealant used as this is not an OEM watertight seal. The drain cover also had an extra hole drilled to prevent future drainage issues. 2 days with a dehumidifier going and now all sorted.
      01-04-2020, 07:43 AM   #10
Russbmw
Russbmw's Avatar
Drives: 2018 630iGT sport
Here's what I wrote up when I checked mine
https://www.6post.com/forums/showthread.php?t=1643842
