05-27-2018, 09:35 PM | #23 | |
Rep 617
05-27-2018, 09:51 PM | #24 |
Rep 459
What do you run on your C63?
05-28-2018, 08:08 AM | #25 |
Rep 617
05-28-2018, 03:13 PM | #26 |
Rep 3,726
32 psi on stock 666m wheels and PSS tires.
also use a QUALITY air pressure gauge to get it down to the exact psi on all 4 corners. my acceleration in a straight line improved tremendously after i purchased a solid analog gauge over my digital one. even the slightest differential in PSI can make the car feel sketchy on WOT.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
05-28-2018, 09:14 PM | #27 | |
Plenipotentiary
2614
Rep 3,046
For the original OE tires (temperature, size, load index, and speed rating), the recommended pressures are: - Operation up to 155mph Light Load: 38f/35r Normal Load: 39f/39r - Operation between 156mph - 186mph Light Load: 48f/44r Normal Load: 51f/51r Recommended pressures are specific to the application and tire design specifications. For example, I have two vehicles that are the same make/model, fitted with identical tires, but they have different equipment. At normal loads, the lighter one is recommended 43f/51r, while the heavier one is 48f/61r regardless of load. Actually there is a specific cold temperature (20°C/68°f). The ambient acclimation correction factor is 1.45psi/0.1bar per 10°C/18°F |
05-28-2018, 10:08 PM | #28 | |
Rep 672
05-28-2018, 10:14 PM | #29 |
Rep 1,003
Drives: 2008 BMW 135i (E88 N54 6AT)
05-28-2018, 11:32 PM | #30 |
Rep 525
That's great but look at the type of questions and responses here. Do you really think getting more technical is beneficial to them? Lol, when was the last time you spoke to anybody about cold tire pressures, measured ambient then adjusted your tires based on that?
