      01-24-2017, 06:51 AM   #1
AceCobra1
Drives: RX8, Alfa Romeo GTV, 640d GC
Suggestions for new battery
Hi guys, long time no post - been too lazy
Anyway, I think my battery is on its way out because when I try to start the car after 1 week of not driving it, it turns over but is almost out of juice
I used an optima red top on my rx8 and it works really well and stores the charge so well as I am lead to believe that these AMG batteries are good for it.
Do you guys have any recommendations? Optima would be my choice but not sure if it suits a diesel - got the 640d like most here
      01-24-2017, 06:57 AM   #2
NINJA59
You need an AGM battery correct equally dont forget it may need coding and the windows etc. Reprogramming to drop when open and closed...
      01-24-2017, 07:00 AM   #3
AceCobra1
Oh never mind that then - too much hassle
What is the best battery that can be swapped directly without reprogramming the car ?
      01-24-2017, 08:08 AM   #4
Walt White Coupe
Walt White Coupe's Avatar
221
There is no battery that does not need to be "registered" with the car. The charging system alters how it charges a battery through the life of the battery. Your system is now in a mode for charging an old used battery. When you install a new battery apparently the system can not automatically recognize that fact and will treat it as an old battery and overcharge it. Registering the batter just tells the system to start over with the new battery.
      01-24-2017, 08:27 AM   #5
AceCobra1
Wow, seems pretty complex. I thought it would be a direct swap. Is this because of iDrive?
So the best thing is to let BMW change the battery ?
      01-24-2017, 08:35 AM   #6
Walt White Coupe
221
This only has to do with the "charging system" of the car and nothing else. I'd look for an independent garage that specializes in BMW's to have the battery registered AFTER I replaced the battery myself if you want to save money. I haven't done it yet on my 6 series but I did on my previous 1 series and the "registering" cost ~$75 and took about 1/2 an hour. You can drive the car with the system overcharging for a while before it will do any harm to the battery.
      01-24-2017, 08:54 AM   #7
AceCobra1
Thanks bud
      01-24-2017, 10:12 AM   #8
Taheemr
280
Drives: M6 GC
yes for sure needs coding, don't go to halfords or LEx what ever you do, some years ago i had my 330d pack replaced and i had no end spurious issues, such as interior lights, sunroof initialisation etc, best to find a good independent
      01-28-2017, 08:16 PM   #9
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
I'd just have BMW do it. If the window drops need to be reprogrammed, that seems like it would be an immediate problem?
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      01-28-2017, 08:48 PM   #10
Walt White Coupe
221
Just bring some vaseline with you if you let BMW do it. If you loose window indexing when you disconnect the battery here is what I found on the internet to correct the problem.
Control procedure for initialization:
Press the window 'open' switch beyond the second switching position. When the window has reached the lower final position, operate the switch for at least 15 seconds but not longer than 25 seconds.
Then let go of the button and immediately pull the switch beyond the 'close window' position. Do not let go of the switch!
The window now moves into the top final position, stops, then moves to the lower final position, stops again and then moves back to the upper final position. The switch must be held in the "pulled beyond engaging point" position during the entire procedure.
Once the window has reached the upper final position, the initialization is complete.
