04-25-2024, 06:08 PM | #1 |
Rep 1
PMA Module
I have a 2018 650i. I am trying to code it to have auto and active PDC when a low speeds. The forums I have read say that you need to activate something in the PMA module. In the BimmerTech app I am not seeing that module.
Is it something I need to enable, or is it something that isnt present in the vehicle. It has the driver assists and PDC when the button is pushed or in reverse. Any thoughts? |
04-25-2024, 06:50 PM | #2 |
Rep 7,548
If you have a PMA module it is B41 in the illustration below:
Good luck trying to code this feature…I failed at it. I did get the coding and the icon to appear, but I think that the f06 is missing a module (at least my 2015 is). The auto-PDC works in my 2014 f15 X5 (from the factory)…if I’m pulling into a spot or up to something at a specific speed, the PDC turns on automatically. But on my f06, after a coding attempt…all I got was the icon to appear at the upper left of the display, and the AUTO PDC screen doesn’t allow me to check the box like I can in my f15 X5. I believe it requires a gen2 module to activate auto-PDC. When you’re coding, you should be able to tell if you have gen1 or gen2 module…it will be revealed in one of the lines of coding:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-25-2024 at 07:06 PM.. |
