      04-15-2011, 10:46 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Smile HP Autosport || Swift true coilover conversion for your KW V series
The basic front only kit consists of a custom upper spring perch, Swift springs, and Swift thrust sheets.
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters.
For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included.
The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate.
***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.***
A wide variety of spring rates are available to choose from or we can make a recommendation for you.
Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days.
https://hpautosport.com/product/kw-s...-and-m-series/
      02-13-2012, 05:20 PM   #2
pnosker
ti fan
67
Drives: 14 12C | 17 X5 50i | 19 M2C
What exactly has to be done to machine the adjusters?
      02-13-2012, 06:03 PM   #3
HP Autosport
Drives: F80 M3
Machine down the diameter from 61 to 60 mm to fit the Swift springs and thrust thus sheets.
      02-15-2012, 01:41 PM   #4
pnosker
ti fan
67
I actually have 2 new adjusters that I bought from KW. Would it be possible to send them in as cores for some discount?
      02-15-2012, 01:58 PM   #5
HP Autosport
Drives: F80 M3
Yes, you certainly can.
      09-17-2012, 05:38 PM   #6
HP Autosport
Drives: F80 M3
Swift spring coilover conversion for KW V series
Best kit out there to upgrade your KW V series to a true coilover system with linear rate springs.
This kit fits the BMW 1M and M3 with V series as well.
      01-11-2016, 06:37 PM   #7
HP Autosport
Drives: F80 M3
bump
      02-03-2016, 03:02 PM   #8
HP Autosport
Drives: F80 M3
bump
      02-17-2016, 04:22 PM   #9
HP Autosport
Drives: F80 M3
Bump
      03-02-2016, 03:32 PM   #10
HP Autosport
Drives: F80 M3
bump
      03-17-2016, 11:08 AM   #11
HP Autosport
Drives: F80 M3
bump
      04-05-2016, 12:01 AM   #12
HP Autosport
Drives: F80 M3
bump
      04-27-2016, 06:46 PM   #13
HP Autosport
Drives: F80 M3
bump
      05-24-2016, 11:35 AM   #14
HP Autosport
Drives: F80 M3
bump
      06-07-2016, 12:21 PM   #15
HP Autosport
Drives: F80 M3
bump
      06-17-2016, 05:36 PM   #16
HP Autosport
Drives: F80 M3
bump
      06-30-2016, 10:12 AM   #17
HP Autosport
Drives: F80 M3
bump
      07-13-2016, 10:19 AM   #18
HP Autosport
Drives: F80 M3
bump
      07-27-2016, 11:07 AM   #19
HP Autosport
Drives: F80 M3
bump
      08-23-2016, 10:54 AM   #20
HP Autosport
Drives: F80 M3
bump
      09-08-2016, 01:33 PM   #21
HP Autosport
Drives: F80 M3
bump
      09-21-2016, 12:22 PM   #22
HP Autosport
Drives: F80 M3
bump
1addicts
