      10-31-2022, 06:01 PM   #23
OkieSnuffBox
Drives: '13 135i
My 3080 doesn't seem to have a problem pushing my 3 1440p monitors. But I'm mostly doing iRacing and such, even though I haven't even done that in a while.
Need to try AC and ACC and see how it handles it.
      10-31-2022, 10:05 PM   #24
Theruleslawyer
Theruleslawyer's Avatar
Drives: 2019 m4
If you have to ask why, you probably don't need it. It's like putting a 6k suspension on your car.
dizz81312.50
      10-31-2022, 11:34 PM   #25
kring
Drives: ‘19 M550i Dinan S1, 340i
I picked one up, the MSI water cooled suprim liquid X. Nice card it’s my cycle to upgrade so I went with this and an i9-13900k, Z790 motherboard and 64GB DDR5 and 4TB WD SN850X drive.
It’s a blazing rig but my last one was still more than adequate- parts are up on ebay for my 3090 and 9900K w/64GB DDR4 if anyone is interested.
The 4090 is significantly faster but the problem is there are no games that take advantage of the card, in all my years I never thought hardware would outpace games but it has happened. And I dont think there are any games on the horizon for 2 years that would stress this card. Sadly, no one is innovating everything for the past 5 years uses the same few gMe engines and all of them cap out pretty low on quality. We need equivalent od a new Crysis game or someone to start using Unreal5 engine to its max..which is 2 years out likely.
So I am future proof I guess
BMWGUYinCO4122.50
      11-01-2022, 01:21 AM   #26
B58-M340iX
Drives: 2021 M340i xDrive
At what resolution and framerate do you play games? I play 3440x1440 (21:9) 144hz HDR and 175 non-HDR and there are many, many games that require the 4090 for that resolution if I want the graphics completely maxed out, even without ray tracing, and maintain the previously mentioned frame rates. Examples are CoD, Horizon Zero Dawn, Ghost Recon Breakpoint, etc. I've even found God of War using 80-95% of the 4090.
      11-01-2022, 06:24 AM   #27
kring
I run 4K @ 120 all settings maxed, yes the 4090 keeps me at 120+, but the difference between slightly lower settings of a 3090 is visually negligible and a few FPS drop is also negligible for most games.
The card is definitely close to 2X faster in raw performance but it doesn’t give you 2X better visuals. There is diminishing returns taking effect on today’s game engines. All the power just goes to excessive FPS which is a nice bump for competitive FPS but little else need 350fps
What this card really needs are 8K textures, 10x polygon, and character models that don’t walk around like they have sticks up their arse or spin disconnected from the ground instead of walking with real physics and real skeletal motion.
I do prefer visuals over FPS.
BMWGUYinCO4122.50
      11-01-2022, 07:09 AM   #28
zx10guy
Drives: 2013 135i
I blame this on consoles. Back way when, games used to be developed for PC first. Now it's reversed.
kring324.00
BMWGUYinCO4122.50
      11-01-2022, 07:32 AM   #29
kring
Totally agree!
zx10guy5149.50
      11-01-2022, 09:54 AM   #30
Theruleslawyer
Drives: 2019 m4
Fwiw next gen console only titles are just starting to come out. This always happens on transitions. It takes a few years to stop designing around last gen.
I have a 4090 liquid x too. I stayed on the am4 platform though. Picked up a deal on a 5800x3d. Upgrading mb and ram wasn't worth it.
Big wins over a 3080-
Much higher mins, less hitches
I can actually use ray tracing and the shadows are significantly better.
When im way over performance I can turn off dlss and get rid of the weird halos around fine objects.
VR. The 4090 is the difference between in reprojection all the time and having a liquid smooth experience on a G2.
The 3080 was barely 60 in some games at 4k and id have to turn things down. The 4090 just slays everything.
BMWGUYinCO4122.50
      11-03-2022, 08:57 AM   #31
zx10guy
Drives: 2013 135i
Here's a video from Gamers Nexus talking about the power connector issue with the 4090s. Seems they are thinking it's the power cable that might be causing the melting/failures. They're asking for people with failures to send them the cable/card and they'll reimburse you for it.
      11-04-2022, 02:27 PM   #32
B58-M340iX
Looks like Reddit has at least 2 reports of RTX 4090 MSI Gaming X Trios that have burnt. Mine is a Gaming X Trio with the 3 8-pin adapter. I keep checking the adapter and card and am not seeing any issues. I play games where the GPU is taxed quite heavily (high 300/425w power draw) and no problems.
      11-04-2022, 02:33 PM   #33
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
There's been more than 2 in the recent weeks i've seen. I don't think it's tied into the power draw itself, moreso in combination with the way some people have had to bend the cables to route them inside their cases
IG: @lolhpfp
Build Thread
      11-07-2022, 01:40 PM   #34
BMWGUYinCO
BMWGUYinCO's Avatar
4123
Drives: 22 M850 Convertible '23 X3 M40
At first I thought maybe it might have been due to sub-par manufacturing of the cable itself shipped with the graphics cards, but now OEM ATX 3.0 PSU cables are beginning to show signs of melting as well.
A symptom of having to bend them too much to fit in cases....? Or too much power going through small pins? Not sure. It won't be my problem any time soon; even if I wanted to venture out and buy one, it's sold out everywhere.
      11-10-2022, 12:11 PM   #35
B58-M340iX
I camped out at a local Micro Center to get my 4090. Was entertaining to chat with the few guys that were out there a few hours early. Luckily, all people in line (about 25-30) got a card. I wondered if there was a point of camping out because there was a rumor of high availability and that Nvidia was stocking them in warehouses to try and sell more of the 30 series. Looks like camping was a good idea if I wanted one on launch.
It is concerning that both the 450w rated cable (3x8pin adapter) and 600w (4x8pin adapter) are burning up alongside the native ATX 3.0 PSU cables. Something is definitely off. I love how Jay from Jayz2Cents was mocked by providers and here we are LOL
BMWGUYinCO4122.50
      02-08-2023, 11:09 AM   #36
Leo Ice
Leo Ice's Avatar
Drives: X3
You won't believe this, but my radeon rx 580 is good enough for me. However, I ran into a problem: I bought a Samsung Odyssey G5 monitor and now I can play only at 60 Hz. I will wait until prices fall to buy a new one at 144Hz
I am involved in software development for startups. If you need help with development, don't hesitate to contact
      02-20-2023, 01:49 PM   #37
BMWGUYinCO
BMWGUYinCO's Avatar
4123
Update on this topic: I went ahead and got an Asus 4090 TUF OC edition.
I am surprised on a couple of performance aspects for this card, and one other observation.
1. While my monitor resolution is 3440 x 1440, I didn't expect a huge performance jump over my 3080...but in VR, the difference is very noticeable.
2. This card runs really cool. It idles at around 25C and under high load it never exceeds 47C. I'm running the standard Asus OC profile, which takes the baseline GPU clock of 2565MHz to 2595MHz which is an LOL statistic itself because that's hardly any difference...but getting it closer to 3000MHz will not really produce significant performance gains in any real world needs. Power draw under max load has not exceeded 440 watts so far, either.
3. This card is H~U~G~E! And heavy...I'm glad they provided a GPU support thingy, although my mobo has the re-inforced pci-e slots.
I didn't buy this card for regular gaming, but rather for VR to drive the 2160 x 2160 per eye resolution of my HP Reverb G2 at the settings I prefer, especially in DCS, Flight Simulator, and other racing simulations.
Is it worth the cost? I think that is subjective, but for me I see a substantial difference in VR performance over my 3080 (10GB version) so for me, it is.
zx10guy5149.50
      02-21-2023, 08:49 AM   #38
///d
///d's Avatar
Drives: F15 35d M Sport
I've been debating if I want to pick up a 4090 and sell the 3090ti. I either run triple 32's or VR, and while I haven't had true performance issues yet, I do have to tweak VR settings and suffer some quality for performance.
F15 35d M Sport (SOLD ) | F30 328i | 2020 Tacoma TRD Pro
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread
BMWGUYinCO4122.50
      02-21-2023, 09:16 AM   #39
Theruleslawyer
Drives: 2019 m4
If you can afford it, do it. VR will eat every bit of performance you can throw at it. You can run full res with some super sampling.
BMWGUYinCO4122.50
      02-21-2023, 11:39 AM   #40
BMWGUYinCO
BMWGUYinCO's Avatar
4123
For me, coming off the 3080 10GB model, it was worth it. For you, coming from a 3090 Ti you will see a performance improvement, but not as much as me. This now becomes the subjective part...if you can afford and can find one, it is a beast of a card.
PS Rumor mill is beginning to heat up over the imminent release of a 4090 Ti.
      02-22-2023, 12:17 PM   #41
B58-M340iX
I, too, came from a 3080 and the performance difference is massive. Everyone was saying that for 1440p that the 4090 was overkill. I still have games I can't achieve a constant 144hz in HDR or 175 non-HDR with max settings and even some without RT or RT audio with my native resolution of 3440x1440. Way too expensive, but the performance uplift is approximately 100% over the 3080.
BMWGUYinCO4122.50
      03-14-2023, 10:43 AM   #42
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
Im still on an 2080Ti Hydro and running strong at 1440P here. I see no need to upgrade yet. I hardly ever see anything less than 125FPS in the games I play.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
BMWGUYinCO4122.50
      03-14-2023, 01:23 PM   #43
B58-M340iX
Playing games like Returnal, Dead Space Remake, Callisto Protocol, and others with RT and other settings set to max will definitely stress your system. Without my 4090, there is zero chance I would be able to do that and keep a high framerate. My 3080 would have choked badly (3440x1440 native resolution, no DLSS or VRS).
      03-14-2023, 05:08 PM   #44
BMWGUYinCO
BMWGUYinCO's Avatar
4123
Yes, it all depends on the kinds of games you play, even within 1440P resolution. For example, I literally doubled my frames going from my old 3080 to the new 4090 in MS Flight Simulator - and this is even without turning on DLSS 3!
Again though, the 4090 is literally a game changer in VR, especially driving headsets like my HP Reverb G2, or a Pimax 8K for example.
