08-04-2014, 07:49 AM | #1 |
Rep 647
M6 gran coupe vs coupe power
I got the gran coupe because i was stunned how aggressive it looked especially with those standard wheels, but my moto was always to go after power sacrificing everything else, this time I just fell for the pretty girl. So the question is, if anyone familiar in terms of straight line performance, am I losing a lot vs the f13 ? Thanks !
08-04-2014, 08:31 AM | #2 |
Captain Unsensible
99
Rep 737
Drives: 2016 M240i Coupe - Estoril
I believe they are all fairly similar.. if you want exact details check the tech specs on the BMW USA site.
08-04-2014, 08:38 AM | #3 |
Rep 591
Both M6 and M6 Gran Coupe have official 0-60 times of 4.2 seconds.
The M6 Coupe weighs 1925Kg, the M6 Gran Coupe 1950Kg, so only a 25Kg difference, a little over 1% difference. You could save nearly half that by specifying the 343M wheels over the 433M or 601M (Competition Pack) wheels. You can save another 20Kg or so by specking the Carbon Ceramic Brakes. I think overall the performance difference would be totally insignificant. |
08-04-2014, 08:40 AM | #4 |
Captain Unsensible
99
Rep 737
and when doing your high speed runs.. dont fill the tank full Official figures are taken from a 75% full tank i believe and probably a super skinny driver
08-04-2014, 08:42 AM | #5 | |
Rep 1,299
Drives: 2015 BMW i8
0-60 in 3.8 1/4 mile in 12.0 0-150 in 18.5 For non-CP M6 Coupe they were: 0-60 in 3.7 1/4 mile in 11.8 And 0-150 in 18.0 Mind you they were different publications so I would take those with a grain of salt until someone can do a side by side on identical road conditions with the same driver.
H&R Springs 21" ADV.1 ADVNL2 MV2 CS Wheels Coming Soon: 2016 BMW M4 GTS De-Winged and Bagged on 22s |
08-04-2014, 08:43 AM | #6 |
Rep 591
Yep, that 25Kg difference equates to about 30L of fuel, less than 1/2 a tank full.
08-04-2014, 08:48 AM | #7 |
Rep 1,299
Drives: 2015 BMW i8
Also keep in mind that most of us won't be hitting 0-60 in 3.7 or 3.8 consistently ourselves. That would require a near perfect, clean launch and that's very hard to do on less than perfect roads in a car that has so much trouble with traction at low gears. I don't care how good a driver anyone is, it's just very tricky.
08-04-2014, 09:41 AM | #8 | |
Rep 6,067
According to BMWNA, for US spec there is 175lb difference between them (4255 lb vs 4430 lb). I couldn't find any spec for stock M6, bot @Boss330 reported the CP the other day :
08-04-2014, 09:53 AM | #9 |
Rep 591
I can't see those figures being correct if tested under the same conditions.
The weight difference would have more effect at lower speed, but the 0-62mph (0-100 kph)times are identical. The drag differences are very small, but there is a 0.5 second difference in 62-124mph (100-200kph) and a whole second between 62-155mph (100-250kph), that's a very big difference and would indicate that the power in the Coupe was significantly up on the Gran Coupe (0-62 mph being traction limited anyway). |
08-04-2014, 10:18 AM | #11 | |
Rep 6,067
08-04-2014, 10:35 AM | #12 |
Rep 591
It's the 100-200 and 100-250 (kph) times I don't buy.
Given that the drag is pretty much the same and do is rolling resistance (as the tires are the same), the Coupe is doing 100-200 in 7.3 seconds, the GC in 7.8 seconds. 0.5 seconds is about 7% longer. Given that F=mA (assuming friction and drag are the same), 7% greater acceleration means either 7% less mass or 7% more force. 7% of 1925Kg would be 135Kg, but the difference is only 25Kg (or 80Kg if you take the US figures - must be an equipment difference if those figures are correct). Given the relatively large differences in measured engine power by different testers, I think it's more likely that at least some of this difference is due to either engine power or the test conditions (temperature, humidity etc.). |
08-04-2014, 11:19 AM | #13 | |
Rep 1,299
Drives: 2015 BMW i8
08-04-2014, 12:37 PM | #14 | |
Rep 6,067
The Force in "F=ma" is the net force which is not equal in both cars; however they have the same engine produce the same amount of power/force. The net Force can be calculated as F(net) = F - Fd - Frr =ma! where Fd is drag force and Frr is friction force due to rolling resistance. M6 Coupe and M6 GC have different weight and different coefficient of drag and rolling resistance due to their shape since GC is a bit longer. Manufactures report coefficient of drag but not the coefficient of rolling resistance, so it would be difficult to calculate the rolling resistance. According to the following link, they estimate the coefficient to be 0.03. http://www.engineeringtoolbox.com/ro...ce-d_1303.html and this link explains the Fd http://en.wikipedia.org/wiki/Drag_equation Hopefully it makes a bit clear. BTW I asked my colleague ( who is mechanical engineer) to explain these to me since I'm not expert in mechanical stuff
08-04-2014, 12:53 PM | #15 |
Rep 591
I was trying to keep things simple and as much in favour of those figures as possible!
The rolling resistance should be identical. From what I can find, the GC has a Cd of 0.33, the coupe 0.32, so there is a very small advantage to the Coupe there. Taking drag and rolling resistance into account make the figures even more unbelievable as they skew the power even further. If you subtract the power required to overcome drag and rolling resistance the 7% figure will become much bigger as the power remaining for acceleration of the mass becomes smaller. For example, lets say (and this is just for example, it's not based on fact at all) that 50% of the power was required to overcome drag and rolling resistance. That means that the remaining 50% would have to be 14% more for the Coupe to achieve those results, or the mass 14% less. |
08-04-2014, 04:57 PM | #16 | |
Rep 1,299
Drives: 2015 BMW i8
08-05-2014, 01:13 PM | #17 | ||
Rep 6,067
Are you saying Cd is 0.33 for CG and 0.32 for Coupe? If yes then I can show you the difference between the time from 100-200 km/h can be close to 0.5 second, but we need to simplify the calculation since the drag force is an exponential equation ! Quote:
08-05-2014, 03:04 PM | #18 |
Rep 135
There is an easy solution to questionable topic... Get both cars side by side and just race each other ! .. Do it the fast and furious way !...lol on a serious note ,i am sure I read somewhere that the gc map is different from the coupe on its torque curve , but I may be wrong .
08-05-2014, 03:27 PM | #19 | |
Rep 6,067
08-06-2014, 02:29 AM | #20 |
Rep 591
I also have the CP, so not a like for like comparison.
I think at speeds above 100kph drag will massively out weigh rolling resistance, but I don't know for sure. Yes, the extra few Kg will increase rolling resistance slightly, but it would be such a small amount compared with drag. Put the two cars on a gentle slope and release the hand brake, would you see a significant difference in the rate they free wheeled? There would probably be more variation due to the individual tyre variations and differences in tyre pressure. I believe a Cd comparison of 0.33 and 0.32 is pretty small too, I had a car with a claimed Cd of 0.22 in the 80's and with similar power and weight to cars with Cd in the 0.3 range it was only slightly faster at the top end. My bottom line, without careful back to back tests in identical conditions or a very accurate simulation that takes everything into account, would be that the Coupe would be slightly faster then the GC, but in all probability, differences in engine output, driver weight and skill etc. would make them all but indistinguishable in day to day use. |
08-06-2014, 07:38 AM | #22 | |
Rep 1,299
Drives: 2015 BMW i8
