11-08-2006, 12:07 PM | #1 |
Rep 489
Got my drive, now what... (computer guys)
I got the new drive and enclosure, plugged it into my computer and nothing happened. Checked under my computer and everything, nothing. I mean the drive is on and running, i just cant get to it... HELP
11-08-2006, 12:13 PM | #2 |
Rep 5,842
Drives: 2006 325xi
ok you need a little more details there. It sounds like you got an external hard drive and an enclosure.
Did you hook the hard drive up right in the enclosure - Power and data. How does it conenct to the comptuer - USB, Firewire do you hear the drive spin up when you power it on. Go into the device manager and search for new hardware. PM me if you need help |
11-08-2006, 02:12 PM | #5 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
usually if you have a new computer and a new hard drive (as in both items are current) you should be able to plug&play. the cd's that come with a hard drive are normally programs that make the hard drive easier to use... but of course many people wont bother cause its PLUG&PLAY yada. anyways... external hard drives arent the most reliable... so if ur computer does not indicate that there is an external HD, i'd return to the store and ask them to check if the HD is functional.
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
11-08-2006, 02:16 PM | #6 | |
Rep 9,788
what he said...it should b plug-n-play. if not, check to see if the HDD works... |
11-08-2006, 02:51 PM | #7 |
Rep 489
I bought an internal 3.5inch hard drive and an enclosure. I hooked everything up, I hear something whirring, but it may just be the fan that came with the enclosure. I think im just gonna call the place that I bought it from.
11-08-2006, 03:28 PM | #8 |
Rep 489
I went in and unplugged the fan just to check and see if the hard drive itself was working, it is operating. Also, I went into my device manager and it indicates a "USB 2.0 storage device" so im assuming the computer knows its there, it just wont show up under my computer. I bought the damn thing to put my music on because the hard drive on my laptop is out of space. My computer is a toshiba with windows xp. Hope this helps
Thanks guys i am am not technically inclined at all... |
11-08-2006, 04:23 PM | #9 | |
boku no namae ha...
336
Rep 11,025
Assuming you hooked up the power source and the cable thing (i forget what theyr called), the last step is to switch the neutral setting of the hard drive to secondary or primary (depends on whether its linked to thethe secondary or primary position of that cable). Then you need to format the hard drive.... thats about it.
11-08-2006, 06:18 PM | #10 | |
Rep 489
11-08-2006, 06:41 PM | #11 |
Rep 7,519
Drives: 2009 E90 335i MT
If it's an internal drive why did you get an enclosure? Just open the main case and install it there. No need for external power bricks, two cables funning every which way. Now if you don't haver space inside the case, now that's a different story.
With the external enclosures you need to ensure the jumper switches on the hard drive are set as the instructions say (you did read the instructions, didn't you? ). Have you loaded the drivers? Some enclosure models require their own driver, others are just plug and play. Does your operating system support USB? I know that sounds silly but how old is the computer? Does the BIOS recognize the size of the hard drive? I tried to install a 200GB internal drive but my BIOS didn't recognize it because the BIOS was too old.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
11-08-2006, 08:18 PM | #12 |
boku no namae ha...
336
Rep 11,025
do you know what I mean by primary or secondary drive?
the IDE jumper (the thing long thing that connects to the motherboard) has two inserts... one at the end (PRIMARY) and one in the middle (SECONDARY) if you have a primary drive (cd drive, hard drive, something else), then you connect the middle input to your drive LOOK ON THE PICTURE BELOW. there should be a sticker on your hard drive which tells you where to place the little black object in the middle of the jumper to make the hard drive a SECONDARY OR PRIMARY drive. *YOU DO NOT NEED DRIVERS FOR INTERNAL HARDDRIVES
11-08-2006, 10:06 PM | #13 |
Rep 489
Its primary, and i hooked it up right, it was pretty easy. Just put the big one in the big slot, the smaller one in the smaller slot, etc. I mean the drive is working, my computer dings when i plug the usb cable in and dings when i take it out, acknowleging that the drive is there, I just cant access the damn thing...
11-08-2006, 10:32 PM | #14 |
boku no namae ha...
336
Rep 11,025
internal hard drives use usb? are you sure its not an external hard drive. external hard drives use usb.
11-08-2006, 10:33 PM | #15 |
boku no namae ha...
336
Rep 11,025
can you take a picture of your drive... it would make things so much easier.
11-09-2006, 06:22 AM | #16 |
Rep 34
He bought an internal HD and bought an external case for it to avoid paying the premium for external HD's.
Mine came with a driver, when you plug it into the computer and hear the USB 'dun-dun' it doesn't pop up with anything?
I r oph topicness.
11-09-2006, 06:56 AM | #17 |
Rep 6,563
what is the name of the drive you bought and can we see photo pls...Also, if it is used as an external drive, I don't think you should set it as primary. In addition, if this is an internal hard drive that is enclosed in an external case, I think some sort of formatting is needed. When formating, be very carefull. Do not format drive C or D if the operating system is on it. To format, you click on start, settings, control panel, administrative tools, computer management, storage, disk management. under disk management, you should already see System(C and possibly DATA(D if you have a second partition. Now, you need to look for the new unformatted drive and go from there. You can go to google and do a search on formatting in XP and you should have more reading sources to reference. GL.
Be careful and never format C or D...
under construction! |
11-09-2006, 08:03 AM | #18 |
Rep 112
jerrygarcia,
The reason you can't see your drive is because you need to format it...as for what to pin setting to set the hard drive...put it on cable select or primary. Follow the steps below to format your hard drive (assumes that you are using win xp) Start Menu Right Click on My Computer Choose Manage In the Computer Mangement Window go to Disk Management Here you ought to see your C drive (disk 0) then you ought to see your new usb drive (disk 1) Right click on the drive properites (the long side on the right side) and choose format. NFTS file system, choose to give it a letter or a name and tell it to quick format. There might be a few other options I can't remember off the top of my head but if you have any questions just post here or PM me. Sorry it took me so long to post...I usually don't check back here after 5 pm est |
11-09-2006, 10:41 AM | #19 | |
Rep 489
11-09-2006, 10:46 AM | #20 | |
Rep 1,445
My other ride is your mom.
11-09-2006, 10:48 AM | #21 | |
Rep 6,563
11-09-2006, 12:54 PM | #22 |
Rep 112
You should be able to format an external drive as a regular user double check to make sure your not trying to format you disk 0 (your local disk, C: drive). Send a screen shot if you can. You may want to double check and see if you have admin rights and if not try it as an admin user (wouldn't be the first time I'm wrong). Let us know how it goes.
