10-28-2013, 04:46 PM | #1 |
Rep 127
M Laser Projector Door Courtesy Light
May be corny but I ran across this laser projector light that replaces or can be attached to the door courtesy light on the M6 (under side of the door).
When you open the door, it projects the "M" logo very bright and colorful on the floor or ground, even on grass. See pic. It actually produces more light than the BMW standard courtesy light and is fairly visible during the day. Had many complements like I said may be corny but its actually practical. Install is about 15 minutes and the wiring is fused. Thanks |
10-28-2013, 05:16 PM | #3 | |
Live for today tomorrow never comes
1989
Rep 9,498
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
10-28-2013, 06:47 PM | #4 |
Rep 1,583
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
10-28-2013, 06:54 PM | #5 |
Rep 127
Actually got mine on eBay for $19.99 plus free shipping for 2 lights plus the drill bit. Item # 261295595690. Be sure to buy Version 5, its the newest and smallest.
Buy from a US Seller they ship quickly (3 days) as opposed to 4 weeks. Installation is as follows... 1. Remove the original BMW courtesy light under the door using a flat screwdriver. Slightly pry from the front. 2. Drilling hole is simple. I thought I was going to drill into the metal door, but you are actually drilling on the bottom of the door panel ( a cardboard like material) 3. I drilled about 2 " from the existing courtesy light hole towards the rear of the car. 4. Use a 9 volt battery to check the functionality and position of the "M" and mark it. This makes it easier when you are positioning the light. 5. The light is spring loaded, so just push the wire thru first and then pop the light into your desired position. Use the hole from the original BMW light to make your wire connection. 6. What I did was to strip the light wire about 1/4 inch and push it through the original BMW plug. Tape connection with electrical tape.Be sure you have the right polarity red with red etc. Reason, you will not need the original BMW courtesy light, so after the install, just snap the BMW light into place without connecting the plug. 7. The laser light has a flat and even fit after you install it, nothing will protrude and will not interfere with the functionality of the door or lighting error codes. 8. The new laser light will work only when the door(s) are opened and since they are LED's, it doesn't get hot. 9. You're done - Good luck. Hope this helps with anyone who wants to try it. It looks very cool and is much brighter that the original door courtesy light. Thanks |
10-28-2013, 09:06 PM | #8 |
Rep 3,450
more detail install pic shall we?
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
10-29-2013, 03:51 AM | #10 | |
1989
Rep 9,498
