      05-16-2014, 01:36 PM   #23
RespectTheGC
RespectTheGC's Avatar
Drives: 2014 BMW 640xi GC
Originally Posted by ARam View Post
My friend did his 5 series by just pulling the grille with his bare hands. You just have to do a really fast-strong pull and they come off.
Pulled out a 5 series grille also. On the 6 its not the same. I tried many times, with gloves, no gloves, hot weather, cold weather...it wasn't happening.
      05-16-2014, 01:39 PM   #24
doug_999
doug_999's Avatar
2542
Not on the 6....only on the 5
      05-16-2014, 01:44 PM   #25
ARam
ARam's Avatar
61
Drives: 2016 BMW X5M
Really!
      05-17-2014, 10:56 AM   #26
Proudluke
Drives: BMW 645
Just grab hold and pull out and up firmly no problem
      05-18-2014, 01:53 AM   #27
SB8
SB8's Avatar
Drives: 2014 640I Coupe M-Sport
Danny's, you are the man!!! Follow your instructions, got it done less than 20 minutes....
Thank you so much ...
Best regards,
SB
      05-18-2014, 01:54 AM   #28
SB8
SB8's Avatar
*** Dannym
Best regards,
SB
      05-21-2014, 11:54 PM   #29
RespectTheGC
glad people are successfully doing this mod now. I was searching for months for info on how to do this on our cars.
      06-05-2014, 02:38 PM   #30
Jgc650i
Drives: 2019 X5 50i
Switched out the stock grilles on my 650 with the gloss black double slat ///M6 style (without the logo of course). Install was a little more challenging because the night vision module is attached to the grill. Wasn't too difficult to figure out and Dannym's instructions for the grill removal were very helpful. Here are a couple quick pics from the phone. Sorry, pic quality isn't that great.
      06-05-2014, 03:50 PM   #31
GreyCoupe
Drives: 15 650i Coupe
Nice. Looks great with some body colors.
Enjoyed some fun cars over the years: 1966 Corvette Convertible, 240Z, E24 L6, 300CE-24, 2004 645 Ci, 550SL, A6s, 535xi, E300/Bluetec/420, Grand Cherokee Overland, 2012 650i Coupe, 12 CL550, 13 SL550, 15 650i Coupe
      11-08-2014, 09:26 AM   #32
jnkirk1974
jnkirk1974's Avatar
Bumping this thread. Curious to see if there is a video or pics that show all of the screws to remove, etc.
Thanks!
      06-03-2015, 04:32 PM   #33
twm6
Drives: 2015 Protonic Blue I8
bump, bringing this thread back
      06-08-2015, 11:42 PM   #34
jwblack750
MBACPA
Drives: 2014 640xi Gran Coupe
I went the safe route...hacksaw. Honestly. If you don't care about saving the original grille, it is much easier to just cut the slats out, and then you can reach in to press the tabs to remove the grille. I call it the "safe route", because you destroy the grille to eliminate the chance of messing up the car.
      06-09-2015, 05:54 AM   #35
Deda
Deda's Avatar
Croatia
563
Drives: BMW M5 comp
Where did you get grills?
      06-09-2015, 11:48 AM   #36
Jgc650i
Drives: 2019 X5 50i
http://ind-distribution.com/ind/cate...ont-grille-set
      06-09-2015, 12:06 PM   #37
Deda
Deda's Avatar
Croatia
563
Drives: BMW M5 comp
Cool..thnx.
      06-09-2015, 01:25 PM   #38
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Nice kidney grills
      06-09-2015, 10:20 PM   #39
twm6
i thought about the hacksaw way also...might actually do it once I get my car back from the dealer tomorrow
      05-25-2016, 01:16 PM   #40
AceCobra1
Drives: RX8, Alfa Romeo GTV, 640d GC
What is the difference in looks of the grills between the 2012 and 2013 6 series ?
      05-25-2016, 05:29 PM   #41
Rufus123
Drives: Bmw 640
They took one slat out a year ago or so ..but theres no difference between 2012 and 2013
      02-12-2020, 05:19 PM   #42
drbenny1976
Drives: BMW F06 M6 Gran Coupe
As unsettling as the noise may sound when pulling the grill, it worked.
However, my M6 GC has night vision so I had to swap out the grill inner insert, paint it gloss black, to accommodate the night vision, and just use new gloss black grill's outer kidney rim. Just 2 extra steps no biggie.
Turner Motorsport wants $470 after tax... https://www.pelicanparts.com/More_In...RoC8uAQAvD_BwE
I spent $35 + whatever black spray paint I buy at Lowe's later... LOL
Best yet, I get to keep my M6 emblem.
      02-12-2020, 06:44 PM   #43
As already mentioned...nothing is different between 2012 & 2013 (except the M6's double spoked grilles). The LCI grilles have one less slat (9 instead of 10)...have a wider notch at the top, the slats are chromed on the front & have black sides. The pre LCI 10 slat grilles are chromed on half of the front side, and are gray on the other side which is also cut at an angle...and the actual sides of each slat are also gray.
BELOW:
1st pic - 9 slat LCI grille (top)/10 slat pre LCI grille (bottom)
2nd & 3rd pic - compares a broken out pre LCI slat to the LCI slat
      02-12-2020, 07:13 PM   #44
Thanks!
It's already been mentioned earlier in this thread...but the pics below shows what to look for.
When you lift the hood...there's a protective (rubber) cover that is easily pulled up/off to reveal the four push pins & four of the six T30 (torx) scews. To remove the push pins...pull up on the pin and that releases the compression & allows it to come out easily. Then undo the T30 screws and this allows you to pull the front bumper cover forward to access the clips that hold the top & side of the grilles. From there decide the methods mentioned to get the grilles out from the clips on the bottom.
Tags
2014, 650i, grille
