      08-17-2015, 02:30 PM   #1
Onthatb0mbshell
Onthatb0mbshell's Avatar
21
Drives: 640D
Retrofit options
Hi all,
Owned my 2012 640D for a week now, love the car, a big step up for me from a 2004 350Z.
It's the M Sport model but the original owner wasn't tempted by any other factory options other than ambient lighting, so I've been wondering what options realistically can be fitted to the car other than the obvious 20" wheels.
      08-18-2015, 05:34 AM   #2
SL%%
SL%%'s Avatar
54
Drives: 525i
Original M6 20" rims perhaps
      08-18-2015, 06:02 PM   #3
Onthatb0mbshell
21
Drives: 640D
Thanks, but I did say other than wheels
      08-21-2015, 07:33 AM   #4
Hotrod69
Drives: 640 D M
Smile Retro-fit specialists ?
Hi,
I'm in a similar situation. Just purchased a pre-reg 640D with the M Sports+ pack. Turns out that this was a 2014 build and so is missing the Speed Limit Display ! Otherwise a superb car
Is there anyone out-there that can retro-fit ?
      08-22-2015, 01:15 PM   #5
Onthatb0mbshell
21
Drives: 640D
Unfortunately it's a pretty quite forum, not much in the way of responses, quite different from the UK 350Z forum I came from.
      08-22-2015, 01:22 PM   #6
dsad1
Drives: car
They only sell about 5000 6 series in NA annually, so the forum is a little scarce.
I doubt there would be any options that would be worth it financially, maybe the 6wb (digital instrument cluster)?
      08-23-2015, 05:42 AM   #7
TomF32
TomF32's Avatar
39
Drives: BMW/640d/M-Sport
2005 e90  [0.00]
Here is quiet, yeah. Though you should maybe take a look on the F30 forum. The UK regional section there is lively and full of knowledge so even if you have a f12/13 related question, usually someone on there can advise!
BMW F12 M-Sport|Pro-Nav|Space Grey|20" 373M|
      08-23-2015, 07:25 AM   #8
Onthatb0mbshell
21
Drives: 640D
Thanks Tom, i'll have a look and see what's happening there.
      08-24-2015, 03:31 PM   #9
BMWLad
Drives: 2013 F06 640d
I just picked up my 640D GC loving it, but similarly there are a few things I want to try and retrofit. First mod's will be nav map update and coding as much as I can with the software. Then top of the list for me is Highbeam assist had it on my E92 and would like it on the 6'er. Believe its a new mirror (with camera and a touch of coding) but that should also give me speed limit display.
I guess surround view should be relatively easy if you can get the mirrors cheap enough.
      08-24-2015, 04:53 PM   #10
Onthatb0mbshell
21
Drives: 640D
Sounds good what you intend to do, if you could keep me informed on this thread with any progress you make I'd appreciate it
Drives F13 640D
      08-24-2015, 04:59 PM   #11
C5driver
C5driver's Avatar
3471
Drives: 55...just kidding.
Seems like it would be an expensive proposition for such a depreciating asset. How long do you plan on keeping the car?
I would just enjoy it as is.
      08-24-2015, 05:42 PM   #12
dsad1
Drives: car
I am just curious, I don't know the market accross the pond at all, would it have not been cheaper to find a car with the options you wanted instead of retrofitting? Or is it really hard to find these cars in general?
      08-25-2015, 01:38 PM   #13
Hotrod69
Drives: 640 D M
Retro fit Options
One would have thought that ' electronic system ' options were common to all larger models. However, it seems that if there is no current off the shelf BMW mod for a given chassis, a main dealer cannot add.
In my case of the Speed Limit Display I would have guessed a simple mirror upgrade + a software tweak was all that was required !
Can't even find any information though - frustrating !
      08-25-2015, 03:17 PM   #14
BMWLad
There are only about 90 cars at any one time on Autotrader. Of which there is a split between low spec (naked) therefore cheap, cars one with some spec may not be ideal which are mid price and those with everything which are rare as hens teeth but also push the limit for price.
I decided that I wanted comfort seats, sunroof, reverse camera and 20" wheels as a must. I'd have liked HUD, soft close and high beam assist aswell. But HUD and soft close are really viable as retrofits from what I can see.
I should in the nest few weeks get my data cable so should be able to start the coding fun.
      08-25-2015, 04:17 PM   #15
boyhamdzui
Drives: F13 640i coupe m sport
M6 steering wheel, that what I am getting right now.
      08-31-2015, 04:00 PM   #16
Mud
37
Drives: M4
The surround view needs more than just the mirrors. Also have cameras in the front bumper.
      09-02-2015, 01:42 PM   #17
zanye08
Drives: 2012 BMW 650I Coupe Imola Red
http://www.bimmer-tech.net/shop/bmw-...es-f06-f12-f13
This give you a pretty good idea of whats doable..if these guys have it..then it can be done.
Shoot them an email with your VIN and you will know whats possible..
