      12-04-2013, 06:33 AM   #1
RichardP
51
2013 BMW M6 Gran Coupe  [10.00]
1980 E26  [10.00]
2003 BMW M5  [10.00]
Fitting the M-Performance Carbon Fibre shifter trim
Having looked for an install guide for the M-Performance shifter trim and failed, I thought I'd write up my experience.
First, the stock shifter
and the parts that come in the kit P/N 61 31 2 343 709
The part is the same for left and right hand drive and common to the F06, F12, F13 and F10.
The top plaque is a push fit and is also stuck on with double sided tape. I used a pair of plastic trim removal tools to pry it off. If you do it very carefully and slowly then you can re-use it, but a replacement is supplied so it's not the end of the world if you tear the tape or the glue comes off on the wrong part.
Removing the top gives access to a small Torx screw which is at the bottom of a plastic part containing diffusers for the LEDs
Once the Torx screw is removed the trim can be lifted off, it will probably come with the LED module and diffuser module. Gently remove the LED module from the back and the diffuser comes out of the front.
Place the LED module back on the shifter, it locates in a small lug at the bottom.
Put the new trim in place and re-insert the diffuser module, replace the Torx screw (a spare is supplied, no idea why really!) and stick the top plaque back on.
Job done, total time including faffing about and taking the photos, about 5 minutes.
It's a very good match with the rest of the trim as you'd expect. Even the angle of the weave is the same.
The material and finish of the stock part looks very similar to the gear knobs on the early E39 M5's, plastic with a silvered coating. Those gear knobs suffered from the silvering coming off, I suspect that the DCT shift knob would suffer the same problem although it's not used as much as the manual gear lever. Hopefully the Carbon Fibre trim should be much more durable as well as looking good.
      12-04-2013, 02:03 PM   #2
T3X4S
T3X4S's Avatar
Drives: 2013 E92 MW M3
Great DIY and that CF looks awesome.
      12-04-2013, 02:26 PM   #3
stevewilm
Drives: 2103 M6 Coupe
Looks great! How much were the parts from BMW?
      12-04-2013, 02:31 PM   #4
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
List price is £177.50 +VAT, I paid £157.98 +VAT. Not cheap, but then you can sort of expect that for these cars!
      12-04-2013, 04:46 PM   #5
stevewilm
Thanks Richard. I'll let you know how I make out.
      12-04-2013, 05:50 PM   #6
Vervain
Drives: .
You're so brave to do that! It came out very nicely..
      12-04-2013, 06:38 PM   #7
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Good stuff! Where did you buy it?
      12-05-2013, 12:52 AM   #8
RiverRunner
RiverRunner's Avatar
Drives: 2014 M6 Gran Coupe
Looks good!
2014 M6 Gran Coupe-Alpine White/Blk
2015 740i Sapphire Blk/Blk
2018 Tahoe RST 6.2
2019 Porsche 911 Turbo 991.2
      12-05-2013, 01:32 AM   #9
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
I bought it from http://www.bmminiparts.co.uk/ (I'm in the UK) it was ordered direct from Germany, arrived in about a week.
      12-05-2013, 11:31 PM   #10
mr-karim
mr-karim's Avatar
thanks!
      12-06-2013, 04:25 AM   #11
Hargreaves
Drives: X7
Great job Richard! I might have to order that and then drive up to yours for a fitting in exchange for a beer or two! Looks great! How many miles now?
      12-06-2013, 04:35 AM   #12
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
Just shy of 2K miles now, probably do nearly another 2K in the next 2 weeks by which time it will be officially run in!
      02-23-2015, 08:21 PM   #13
savela
savela's Avatar
Drives: 2015 X5M
I would proceed with caution here. I read that the plastic plaque doesn't sit as flush with the carbon piece as it does with the stock piece. There is a transition as oppose to being smooth. Sure enough - just installed mine and that is exactly the case. I'm gonna give it awhile and see if I can get used to it. It does look nice.
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      02-25-2015, 04:30 PM   #14
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
The radius on the Carbon Fibre piece on the edge that goes against the plaque is slightly larger than the stock piece, I'd guess this is just a characteristic of CF. There is a fractionally more noticeable transition between the two pieces, but to me it's not objectionable in any way, it does not leave a sharp edge for example.
      02-25-2015, 06:52 PM   #15
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
This is why I have not done this on my car yet. I have my hand on the shifter a lot and if there is a noticeable transition it's going to bug me. I wish they would fix/change this. You can be very precise with carbon fiber so that can't be the reason. I find it odd that an OEM part like this doesn't fit perfectly. My OEM carbon fiber mirror caps (for example) fit absolutely perfect.
Oh well... I will sit tight until I hear people reporting it fits like a glove (might not ever happen lol).
Brian
      03-02-2015, 09:19 PM   #16
savela
savela's Avatar
Drives: 2015 X5M
Brian
Warranted update. As above, there is a transition. **BUT** I quite honestly prefer this to the stock feel. I know it sounds odd but the offset is no less pleasant to feel and actually looks quite sharp. Best cosmetic mod I've done. Lemons -> lemonade!
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
