01-25-2024, 10:02 PM | #23 |
Rep 1,721
If you have access to a lift, you can knock this out yourself for sure. And probably in less than an hour. Drop the exhaust, drop the gas tank a little and you'll have plenty of access. The way I did it was just absurd but it's what I had at the time.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
youngosbourne6.00 |
01-27-2024, 02:44 PM | #24 |
Rep 11
Stance looks nice, do the 513m's sit flush with the fender as you're set up?
2015 F31 M-Sport
01-27-2024, 02:52 PM | #25 |
Rep 1,721
Rear is pretty flush, the fronts poke out just a smidge
youngosbourne6.00 |
01-27-2024, 03:45 PM | #26 | |
Rep 80
No need to touch the gas tank, but still need to drop the exhaust a bit and deal with some heat shields. Suppose this is more for youngosbourne |
JDAURIA726.00 youngosbourne6.00 |
01-27-2024, 03:49 PM | #27 |
Rep 1,721
Oh wow, if I knew that they made a metal one I would've definitely purchased it. Thanks for link.
dreaming.haze74.00 |
01-27-2024, 08:40 PM | #28 | |
Rep 11
mine broke at approx. 70-75k miles, about 8yrs old. so I guess not too bad, but agreed - shouldn't have to deal with it again if aluminum. their video is great too, like JDAURIA said, pretty straightforward with a lift.
2015 F31 M-Sport
02-26-2024, 07:49 AM | #29 |
Rep 1,721
02.25.24: Oil Service + Thoughts of Selling?
Oil Service was slightly overdue, I thought I could squeeze out one more free oil service from the dealer through the prepaid maintenance period but mileage did not line up. Used LM5w30 purchased through FCP Euro. Quick, easy, 20 mins. Been on the fence about actually selling the F31. It's been one of the best BMWs I've ever owned, never left me stranded and has been rock solid. Not a single issue. But may be looking to jump into an F15/G05 X5 as the wife actually drives this more than I do. Maintenance: [X] Transfer Case Service (preventative) at 64k [X] Automatic Transmission Service (preventative) at 64k [X] Oil Service @ 66,300 [X] Brake Line Bracket @ 66,750 [X] Oil Service (Warranty) @69,206 [X] Brake Fluid Service (Warranty) @69,206 [X] Cabin Filter (Warranty) @69,206 [X] Intake Filter (Warranty) @ 81,000 [X] Spark Plug Service (Warranty) @ 81,000 [X] Oil Service (Warranty) @81,000 [X] Accessory Belt + Tensioner Replacement @ 85,000 [X] Oil Service @ 86,675 [ ] Steering Box/Thrust Bushing Replacement [ ] Coolant Flange Replacement [ ] Water Pump [ ] Thermostat
04-11-2024, 06:10 AM | #31 | |
///M
174
Rep 664
Drives: '18 F80 M3 ZCP, '14 F30 328i
Two Qs: Which steering box/thrust bushing are you replacing? (This one? BMW Power Steering Thrust Repair Kit - Genuine BMW 32106891974) If you're considering selling any reason you skipped over F85s for the X5s?
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI |
04-11-2024, 08:59 AM | #32 | |
Rep 1,721
I assume you mean F15? F85 is X5M, which would be awesome to own - just not practical use for me at the moment. My wife drives the F31 pretty much exclusively right now. I would love an F85 for my commute, and it's crossed my mind numerous times. After owning (3) E70 X5 35d's, I researched quite a bit on the F15 chassis. But once the G05 came out, BMW took it to another level. The base 40i model has the all important B58 while in F15 it's still N55. The interior is a level or two above F15 as well. Specifically the upgraded leather options. Aesthetics is personal preference but I prefer the look of the G05 over the F15 as well (especially the MSport variants). I had a 45e as a rental a few months ago and it was great. Maintenance: [X] Transfer Case Service (preventative) at 64k [X] Automatic Transmission Service (preventative) at 64k [X] Oil Service @ 66,300 [X] Brake Line Bracket @ 66,750 [X] Oil Service (Warranty) @69,206 [X] Brake Fluid Service (Warranty) @69,206 [X] Cabin Filter (Warranty) @69,206 [X] Intake Filter (Warranty) @ 81,000 [X] Spark Plug Service (Warranty) @ 81,000 [X] Oil Service (Warranty) @81,000 [X] Accessory Belt + Tensioner Replacement @ 85,000 [X] Oil Service @ 86,675 [ ] Steering Box/Thrust Bushing Replacement [ ] Coolant Flange Replacement ("micky mouse") [ ] Water Pump [ ] Thermostat Also in need of front tires soon. I currently run 255/40/18 all around on my 513s. Thought about switching to 245/45/18 & 275/40/18 for a better stance/look? I am also on stock OEM chargepipes still, feel like I should replace these are preventative as well soon. Crazy the aftermarket ones are cheaper than OEM?
