04-08-2024, 08:17 AM | #2 |
Rep 58
Hi, just measured mine for you, using digital callipers, the outside diameter of the exhaust pipe is 65.3mm (2017 640d GC). Measured from behind the tailpipes.
This obviously differs from either of the diameters you mention - maybe you’re working on inside diameter(?) in which case I’d assume 63mm |
04-08-2024, 06:17 PM | #4 |
Rep 7,523
Did you pull up the exhaust for your model using one of the online part database sites like realoem.com? They list the diameter of the coupler/bushing used to connect the exhaust and mufflers etc.
See #2 when you go to realoem.com and input your VIN and pull up the rear exhaust:
