      01-14-2017, 11:31 AM   #1
BMWlab
Drives: White M6 Gran Coupe 2016
Oil Consumption Problem Gone
There have been a lot of posts concerning high oil consumption in the M6s. After I purchased my new 2016 M6GC I had the same problem. I was using about a quart of oil every 1,000 miles. I had come from AMG CLSs , which used about a quart every 5,000 miles. The BMW dealer gave me the regular b.s. line that a quart every 1,000 miles was acceptable. I should also add that there are 2 late model M5s and 2 other 2016 M6s in the office building where I work, and the owners all claimed to me that they had no oil consumption issues. So, I resigned myself to the belief that I should just carry several quarts of oil in my trunk at all times.
Then around 6,000 miles, I was traveling on the Interstate and my engine shut down with a "Drivetrain Malfunction" signal. This is the only problem I have had with the car (other than the oil consumption). The car was flat bedded to the dealer who believed it was the fuel pump. The car received a new fuel pump, its 1 year oil change and check-up.
Since then, I have put 2,800 miles on the car and strangely, no oil consumption. I also notice better fuel consumption. The performance is as good as ever. I went to the dealer several weeks ago to have them top off the washer fluid. While I was waiting, I spoke to one of the service advisors and told him the story. He did not think there was a connection between a fuel pump and oil consumption, but did not have any clue as to what would have caused the change.
I write this for others who have the oil consumption problem to explore with their dealer.
2016 M6 Gran Coupe Alpine White- Mods: Black Rear M6 Badge, M///Performance Exhaust with Carbon Fiber Tips, Exhaustmeister, Black Kidney Grilles
      01-14-2017, 05:04 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I believe the Oil consumption is the nature of this engine. I always had to add a quarter every 1000-1500 miles will all 3 F13 (650i/M6) cars I had with different engines such as N63, N63tu and S63tu. Sometimes it was 1500 ( in average ) and rarely up to 3000 based on the way I drove them
      01-15-2017, 08:49 AM   #3
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
I have owned an S52, 2-S54, 3-S65s and now an S63. Only my S65s burned oil, and between the three, only 1 had an every 1,000 mile thirst. Since I only bu used, I have to pin the issue on break-in as being the most likely culprit, either too hard or too soft.
      01-16-2017, 08:14 AM   #4
IM6
Drives: BMW M6 F13
Hi
I have just had a new engine block put in and going through break in, so far only done 35 miles and have used quarter of a litre. is that normal for break-in to use more oil?
      01-16-2017, 08:39 AM   #5
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
How do you know it's used 1/4 litre so exactly? If it has done in 35 miles you've got problems. A new engine should use less oil as it's still tight.
Our 2015 M6GC has used no oil in 8000 hard miles since run in service.
But my previous E63 AMG 5.5 V8TT used a lot, a litre every 2000 or so.
Modded and tuned 335i before that used hardly any. 330i before that used quite a bit.
I had all 4 cars from new and ran them in properly, not super careful, but sensible. I think its more about manufacturing tolerances on engine parts, some work out good and pass less oil, some not so.
      01-17-2017, 07:25 AM   #6
IM6
Drives: BMW M6 F13
HI
thanks for the feedback, I was thinking exactly the same , never had issues before on previous cars, v10 m6 used lot less. Turbo driven engines will use more.
You can do engine oil measurement through Idrive and you can see on the bar how much oil has dropped. mine has dropped 0.25 litre on 350 miles.
I did hear that break-in can drink up more oil.
      01-17-2017, 07:27 AM   #7
IM6
Drives: BMW M6 F13
can you please also suggest how you broke in the engine, hard/soft/moderate?
did you open up the throttle after 1200 miles
      01-18-2017, 10:10 PM   #8
6spdterror
Route Runner
6spdterror's Avatar
Drives: 16 ///M6 Gran Coupe
Funny thing is i had an F10 M5 for three years before my current 2016 M6 and that thing drank oil. Always had to keep an extra bottle or two in the trunk. My M6GC is up to 6k miles now and not a single add oil message. Same mods too. I guess its a toss up with these engines.
16 SMB M6 Gran Coupe
16 BS X6 X-line (wife's truck)
13 AW M5 (sold)
04 Honda Pilot (everyday car)
      01-29-2017, 06:28 PM   #9
AntDX316
AntDX316's Avatar
Drives: 2013 750xi ///M Performance
You can get 5qt. of full synthetic 0W-40 from Walmart for $25. I run Turbo Maxx with that concotion. 5W-30 leaks oil but 40 doesn't as much by a lot.
      10-12-2017, 10:26 AM   #10
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Bull I have had all the "M" cars and NONE have used a drop. Run it in properly no Oil use end off.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      10-13-2017, 11:01 AM   #11
tab
Drives: 2016 M6 Gran Coupe MT
2016 BMW M6 GC  [10.00]
My M6 GC is 2 years old, ca. 23,000 miles, and basically doesn't burn oil. I broke it in as advised for the first 1200 miles, not much above 100 mph, no full throttle, tried to vary throttle and speed at first (easy to do for the first several hundred miles, as I was on winding rural roads in Bavaria).
No idea whether it's because of the breakin or just luck.
      10-13-2017, 11:19 AM   #12
JOHNBMWM5
JOHNBMWM5's Avatar
1989
It's the first 40/50 miles once hot It needs working, not over 5.5K but up and down using the gears to slow down, after that easy off, all should be good.
Worked for me for 15 years or so now, never topped any Oil up ever.
bhoch13.00
      12-02-2017, 08:19 AM   #13
dalaalsingh
Drives: 2013 M5
Originally Posted by IM6 View Post
Hi
How did you get them to replace your engine? Please advise
      12-02-2017, 02:21 PM   #14
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
My N63TU motor doesn't burn a drop. Seems to be very individual with these cars - no idea why. The ones that burn a lot of oil don't seem to be blowing up, they are just thirsty.
      12-03-2017, 03:40 AM   #15
Airz
Drives: 2015 M6 Sakhir Coupe
When I bought my 2015 M6 coupe it had about 4500 miles on the clock and after I'd done about 1800 miles it wanted a litre of oil. Over the course of my ownership (about 6 months now) its had a mixture of twisty b road thrashes and 5 hour motorway trips for work every other week and since then its been about 6500 miles and not needed a top up.
Not sure if its the motorway journeys, the b road blasts or a mixture of the two that have maybe seated the rings properly and stopped the oil burning issue.
I'd also add that my E92 M3 before this burned a bit of oil when I first purchased it but after a month or so stopped so I do wonder if its something about the way I drive.
      12-03-2017, 07:07 AM   #16
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Airz, I can tell you that my service advisor said drive harder to help with oil consumption. My car is a dd so I rarely get to stretch her legs, and my two quarts every 1350 miles is sop.
      11-09-2018, 10:49 PM   #17
AtlChrisH
AtlChrisH's Avatar
Drives: F06 M6 Gran Coupe Alpine White
Red face WOW, thanks 6post Member
First off, I'm new to this Forum. I've own many BMW M model and Mercedes AMG model in the past. But non surpass BMW style and character. I'm joining this forum to share experience of my M6 Gran Coupe. Please excuse if break forum rule, just please tell me. So here's my story.
I recently acquire a pre-own 2014 M6 Gran Coupe with 29k miles. Perform oil change with Castrol Edge 5w40 and filter (I perform the service at my shop). Drove about 1,200 miles, "add 1 quart of oil" message came on. Check oil level using Idrive, it was at minimum. I've own E36 M3, E46 M3 and N54 335i and non have used any oil, so this kinda worried me. Raise up to check for leaks, no leaks and no smoke from tail pipe. But oil was low base on the message. I've contacted BMW of North America, explain to rep about it, he refer me to contact a local BMW dealership. I called local Nalley BMW (Decatur, GA), they want to charge me to diag oil consumption and they believe it could have a leak. But I've been reading in this forum and google about the S63 oil consumption problem, it's a problem that BMW should address. If not connecting rod in S54, Rod Bearing in S85 and now Oil Consumption in S63. Man, I've should better off buying a Honda (LOL). So, I just change my oil to 0w40 Castrol Edge to monitor the consumption. If a quart of oil every 1,200 is what I have to live with, is that normal for these S63 motor? Thanks 6POST!!!!
      11-10-2018, 06:48 AM   #18
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Hi and welcome to the forum.
What kind of oil did you use before? Basically 0,05% to 0,5% of the average fuel consumption per 1000km is ok.
I.e. 12L average consumption
0.05% x 12 = 0,6L per 1000km
0.5% x 12 = 6L per 1000km (I find this too high)
Everything in between is acceptable according to the car manufacturer.
As long as there is no blue smoke coming out of the exhaust I wouldn’t be too worried.
      11-10-2018, 02:51 PM   #19
spikespiegel
Drives: BMW M6 comp
I can report no oil burning on my f13, one trackday, drove cross country, etc. I do change oil every 6k miles or so.
      11-18-2018, 04:09 PM   #20
rkb4_photos
Drives: 2013 BMW M6
Was there any update on the fix for the oil consumption or was it as easy as the fuel pump replacement? I currently have a 2013 M6, bought with 19K miles, now at 27K. I used to make it roughly 700-800 miles before the low oil message popped, now its running about 450-550 miles. My driving habits are pretty normal which consists of a small commute to work (20 miles roundtrip) and the occasional throttle romp to express my "love" for slow left lane drivers.... My BMW rep has expressed that the 700-800 miles fell into specs, but now seems a little hesitant about the current numbers. I haven't noticed any oil burn or leaks but they are supposed to take a look after the holidays. I was hoping anyone else has had further info. DINAN stage 1 is the only mod equipped.
