      04-14-2018, 04:51 PM   #1
matx1982
M Performance
matx1982's Avatar
672
Drives: G05 X5 + F90 M5 + G80 M3
2021 X5  [0.00]
2021 M5 Competition  [9.17]
2022 M4 CSL  [10.00]
2022 M3 Xdrive Comp ...  [10.00]
M6 Vorsteiner carbon
Hello
I've had Vorsteiner carbon kit installed on my M6 and not happy with the fitment.
Please could people share with me any photos showing the fitment of the M6 Vorsteiner carbon, also the boot lip and diffusor.
Ideally on a light car so I can see how well it fits.
Thanks
Mat
F90 M5 Frozen Dark Silver Ultimate
G80 X Riviera Blue w/ Kyalami Carbon Ultimate
G05 30d Mineral White
Instagram - @matfireworks
      04-14-2018, 11:35 PM   #2
Flying Ace
Flying Ace's Avatar
4985
I only have the spoiler. I'm also disappointed with the fitment. I'll upload photos in a few days when I'm back at home.
      04-18-2018, 05:20 PM   #3
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Originally Posted by mlepyro View Post
Hello
Thanks
Mat
Same here on fitment.
I had the fitment adjusted for the rear diffuser and side skirts. The shop ended up taking off the body panel for the side skirts and bumper for the rear diffuser. They used screws and double sided tape attaching it directly to each part. Fitment is MUCH better, no gap on the side skirts and very little gap on the rear diffuser. There is a small gap on the front spoiler, but it is not noticeable.
- Kris
      04-22-2018, 10:55 PM   #4
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
Is the vorsteiner fitment any better than the V-Style ones? Problem seems to be the edges lifting for me. Do you have the same issue?
      04-24-2018, 11:38 AM   #5
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
I have the same spoiler. It fits OK but there is no margin for error when installing. Even being off my a mm can affect the final placement. You definitely need 2 people and the hinge technique to be able to install it properly.
      04-24-2018, 06:03 PM   #6
//MMachine
Drives: 2017 M6 coupe
2012 Ford SVT Raptor  [0.00]
2017 BMW M6  [0.00]
2107 BMW M4  [10.00]
2007 BMW 650i  [0.00]
2008 MB E350  [0.00]
1999 Ford F350 Lariat  [0.00]
Even though I have an RW Carbon rear spoiler I believe it is virtually identical to the Vorsteiner one. It too had an extremely small "sweet spot" where the spoiler would fit perfect - any deviation from it and would not fit or look good.
Positioning of spoiler is critical - but fairly easy to accomplish by one person using painters tape.
I dry fitted my spoiler and when position was perfect I held in place with just a couple pieces of painters tape. Next I outlined with painters tape on the deck lid around the entire edge of the spoiler. After spoiler is outlined with tape - take off spoiler. You should have perfect outline of the spoiler foot print. Wipe this foot print area on your deck lid down with isopropyl alcohol (IPA) to remove any contaminants on the surface so your spoiler's stickey tape will adhere properly.
I had to put the 3M sticky tape on bottom side of spoiler myself as it did not come that way. I did entire perimeter and offset it from the edge by about 2 mm - the fewer the pieces the better - try to do it with only 2 long strips. Once tape is in place on bottom of spoiler you need to peel back about 15 mm of the backing on the end of each piece of tape and FOLD over. Next attach a longer piece (6 to 8 cm) of painters tape to the FOLDED ends of the backing you just peeled back.
Position spoiler in place on the outline and use a couple pieces of painters tape to hold that position. Make sure your free ends of the tape you attached to the FOLDED backing is poking off to the side and not under the spoiler.
Once you are satisfied with position you can the pull the ends of your backing off the tape. The backing will easily pull off - even while sandwiched between the decklid and spoiler - just pull more to direction of tape than off to side. Firmly press your spoiler down in place while you peel the backing off. Remove the tape that outlined your spoiler and it should now be in perfect position. You don't have to outline spoiler with tape - but thought it was easier for me.
How about a few pics from the ones that have bad fits? Would like to see
      04-26-2018, 04:49 PM   #7
Kkgy79
Drives: 2013 m5
I have full set of vorsteiner carbon.
Fitment is not 100%. But 98% fit well.
If u r not looking close, it looks like have 100% fitment.
      04-26-2018, 05:33 PM   #8
matx1982
M Performance
matx1982's Avatar
672
2021 X5  [0.00]
2022 M4 CSL  [10.00]
Hello
Thanks for the replies.
Here are photos of the front splitter. I will try to get of the boot spoiler.
Thanks
Mat
      05-09-2018, 12:52 PM   #9
kong24680
Drives: Silverstone Metallic F06 M6 Gr
Hello
Thanks
Mat
That's basically how my vorsteiner front splitter fits too.. I've heard later versions of the vorsteiner parts for a lot better than the earlier versions.
      07-05-2018, 11:37 PM   #10
Slimm2.0
Slimm2.0's Avatar
Drives: F13
it actually looks good!
Hello
Thanks
Mat
      07-06-2018, 02:03 AM   #11
BM dnobagaV
BM dnobagaV's Avatar
Drives: 2010 BMW 528i
Doesn't look too bad to me. Not at all.
