04-21-2018, 01:56 PM | #1 |
Rep 131
About fuse number
Hello i need ur help. Couldn't figure it out about which fuse for cigarette light.
Im trying to install dash cam thru chigar lighter of fuse box Also im curious i better hook it up on cigar lighter fuse or exhaust flap fuse? And what amp fuse necessary for it? I will appreciate if u guys share that information Thank you very much |
04-21-2018, 04:53 PM | #2 |
Rep 469
The fuse for the cigarette llighter that is near the shift lever is behind the glove box and is a motherfin pain to change and get to. I’d find a different fuse from the trunk or something.
04-21-2018, 05:10 PM | #3 | |
Rep 131
But im not sure which number fuse need to be hokked up. If u have any information please let me know please 5a fuse is enough for dash cam? |
04-21-2018, 06:20 PM | #4 |
Rep 469
5a should be more then plenty. I can only speak accuracy for the M6 but there’s empty spots in trunk fuse panel. Some are constant on others are on with ignition. You can fuse whichever you prefer. I know some people want their dash cam running 24/7. I’d do ignition power. Also people have pulled power from mirror assembly.
04-21-2018, 06:40 PM | #5 | |
Rep 131
That is better? |
04-21-2018, 07:14 PM | #6 |
Rep 469
Yeah test light with ignition mode on. Varies depending on vehicle options. Mirror route would be better in the sense that it’s cleaner and you don’t have to route and tuck wires to the trunk. There’s a write up for it I’m pretty sure on here
04-21-2018, 09:03 PM | #7 |
Rep 131
Ok thank you so much for ur advising.
04-23-2018, 06:14 AM | #8 |
Rep 23
M6 DIY Post 7 has a write up on wiring a dash cam and shows which Fuse used. Hope it helps.
04-23-2018, 01:44 PM | #9 | |
Rep 131
