      01-31-2014, 09:22 AM   #23
harrytruman
Drives: 2009 128i
Originally Posted by 631twentyeighteye View Post
No. 125i is rated at about 200hp while the 128 is rated at 230hp, thats why the 125i gets bigger gains, because it has less power in the first place. You'll get both to about 260hp with a good tune(and the DISA manifold swap on the 128i).
You're talking about the n52 that doesn't already have the DISA manifold like the N51? Just checking to make sure I haven't missed something awesome. =O
      01-31-2014, 09:47 AM   #24
harrytruman
Drives: 2009 128i
I put on ~15 miles right after I installed the tune last night and then another ~25 on my drive to work this morning. I'm being very mindful of placebo within the new tune 15-mile break-in period, so I'm essentially writing off the drive from last night. Regardless, I think the biggest changes are more noticeable during my morning drive -- the same drive that I make every day. Power is more readily available at all RPM ranges and the power delivery is a lot smoother. It's definitely not a major ~50bhp change but it's very noticeable and the overall responsiveness seems greatly improved.
Commuting in Seattle is a frustrating and often a miserable experience, but this morning was actually fun! Coming down the I-5 on-ramp in 2-4 gear, full throttle, the torque seemed to have been kicked up, especially at ~3500 RPM when the DISA valves opened. On I-5 through downtown Seattle, maneuvering in/around slow idiots, 3-6 gear was simply far more responsive. And once I finally got out of traffic, the increased power while cruising at 72 MPH in 6th gear and letting on the throttle was *way* more noticeable. The car now immediately gains speed to the point that I didn't have to downshift to quickly pass cars.
It seems like the power delivery has changed enough that my normal speed and shifting had to be readjusted. It simply pulls harder, pulls easier, and there's more available power at all times now. Actually, for the first time in quite a while I'm wanting to simply drive for the sheer enjoyment of driving!
*Edit*
Story time! When I first started uploading the tune last night, the Evolve program began deleting the existing ECU and writing the new file. It almost immediately failed and displayed errors about the connection timing out, about the security keys not matching, and a few other things. Bricks were shat as the interior lights all turned on and the dash console was constantly chiming with the service alert. I turned the car off, reseated the ODB-II cable, and restarted the process -- with great success this time around.
      01-31-2014, 10:47 AM   #25
328papaya
Drives: 2011 328xi N51 ZSP
Thanks for the great write up and your efforts to push the tune to happen. As a N51er, I owe you one.
From what you have described, it seems the output curve fit the dyno result posted for 125i, a uniform gain over the whole range. How's the dead pedal and the engine brake feeling at low gears? That's what bothering me the most with my 328 N51.
And the smoothness of engine, do you feel any change?
      01-31-2014, 11:04 AM   #26
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Good to see something for the N51 guys. It will be fascinating to see where they end up compared to the N52.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      01-31-2014, 11:14 AM   #27
harrytruman
Drives: 2009 128i
I was trying to give the impression that the entire power band had been given a nice increase and that the power comes quicker and smoother. The engine is definitely much smoother as you open the throttle. I had a friend with me last night and he said that he felt the same thing.
      01-31-2014, 11:37 AM   #28
328papaya
I should mention that I had a 2006 330xi (new) for a year before I switched to a Audi B5 S4 (2002) , then finally gave up 100k miles after annoying by all the oil leaking, secondary water pump problem, also the life of turbo.
The 330i was zero mod, the biggest difference between that and my 328xi (2011 CPO) is from dead start, 328 is not as ready, then after 3000 rpm above (up to 3rd gear), both will feel the same. From what you stated, looks I can expect the tuned 328 N51 will be very closed to 330.
      01-31-2014, 12:05 PM   #29
Fume
Drives: '19 Porsche 718 Cayman GTS
*Edit*
Thanks for sharing again! I share your pain about the Seattle traffic for commuting. I drive across the 520 bridge every day and it's just terrible. Some other cities might have a lot of idiot drivers but Seattle seems to have all the slow idiot drivers.
Anyway, does anyone know theoretically what kind of HP difference there is between 10:1 compression vs 10.7:1 engine?
      01-31-2014, 12:14 PM   #30
328papaya
there was some post said 2.5%, but consider that evolve on 330 also give another 5+ hp gain, so if the 2.5 is true, and if the DISA controller is exactly the same (I read from somewhere that it was also tuned down to smooth out the curve), then the tuned N51 shall be same N52 high output. though all just in hypothesis.
      01-31-2014, 02:26 PM   #31
harrytruman
Drives: 2009 128i
Man, I sure hope the gains are that significant. I've been talking today with Imran about scheduling a dyno date. We're close to pinning down an exact date. So we'll find out soon!
Seattle drivers are just #@&%ing stupid. Nobody cares about getting anywhere at a reasonable pace, nobody uses cruise control, but the worst is that nobody pays attention to anything going on in front of them or around them.
      01-31-2014, 02:53 PM   #32
TheSt|G
TheSt|G's Avatar
I found the last time I was in Washington state, there was a speed limit, and that is the speed everyone went. It was one of the weirdest experiences of my life.
I just got in the left lane and cruised past everything like the east coaster I apparently am.
      02-01-2014, 07:18 PM   #33
Deutsche-Broke
Deutsche-Broke's Avatar
Drives: 2016 M235i
I couldn't agree more.. It's the primary reason why I moved North out of the area..
Can't stand driving in Seattle. It's truly, beyond words terrible..
      02-03-2014, 08:32 AM   #34
Imran@Evolve
Imran@Evolve's Avatar
5371
Drives: All of them
Thanks for the feedback so far. The changes we have made are on par with the 125i's we do over here so will be interesting to see what the dyno says. :-)
From your feedback it seems there is a noticeable gain from driving which their should be.
      02-03-2014, 01:11 PM   #35
harrytruman
Drives: 2009 128i
Yep, and my weekend driving gave me a better feel for the changes, although it's basically still what we've already mentioned. There's a nice amount of power gained through the entire RPM range and the power delivery has even smoothed out quite noticeably. The extra torque isn't massive but it's very noticeable.
      02-04-2014, 09:24 PM   #36
328papaya
Dyno!dyno!dyno!
      02-06-2014, 09:41 AM   #37
328papaya
Hows the MPG so far?
      02-07-2014, 08:47 AM   #38
Wakka
but no flokka
Wakka's Avatar
Drives: M2C
I would imagine he's had a heavy foot since the install
Originally Posted by BTM View Post
Entourage sucks. BTM hates everything
      02-15-2014, 04:02 PM   #39
328papaya
Hi Imran,
are you close to the official release?
      02-17-2014, 06:34 AM   #40
Imran@Evolve
5371
Drives: All of them
Hi Imran,
Awaiting dyno graphs before we release.
      02-23-2014, 08:45 PM   #41
harrytruman
Drives: 2009 128i
MPG is about the same as I was getting before. I have a ~50 mile daily commute and I'm averaging 22 MPG for the whole trip, 30 MPG for 75mph on level roads.
Also, I got the green light from Imran to schedule the dyno date. I'll be doing that in the next day or two.
      02-27-2014, 11:40 AM   #42
harrytruman
Drives: 2009 128i
Confirmed with Imran and Carburetor Connection in Kirkland. The dyno day is March 11!
      02-27-2014, 07:31 PM   #43
Fume
Nice. Please keep us updated! I'm pretty excited about what kind of gains this gets. Based on the result, I'm strongly considering getting supersprint headers along with the evolve tune.
      02-27-2014, 10:21 PM   #44
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
patiently waiting, the n51 is getting alot of attention ( evolve, vishnu OFT) and would love to see the cruve.
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
Tags
128i, ecu, evolve, n51, tune
1addicts
