      04-22-2018, 03:24 PM   #1
Cincinnatus
Drives: 2013 M6
Coding Question
I used Carly to add the Torque/HP and Sport Mode displays to my F13, but for some reason they're not active. No dial pointers on the Torque/HP screen (though the range circles are displayed) and nothing is selectable in the "SPORT Mode". Is there something I yet need to do, or perhaps I applied settings in the wrong order?
Any help would be appreciated.
      04-22-2018, 03:51 PM   #2
jackliu0527
Drives: BMW 650iXdrive GC
Not sure about carly, but if you code via e-sys here are the parameters
Enable Sports Displays
HU CIC
3000>EFF_DYN_SPORT_CID set to: aktiv
3000>EFF_DYN_SPORT_UNIT set to: aktiv
KOMBI
3008>DREHMOMENT set to: lb_ft (displays ft lb)
3008>LEISTUNG set to: ps (displays hp)
      04-22-2018, 10:46 PM   #3
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
I thought CIC 2012/2013 models does not support sport gauge?
Thanks
      04-22-2018, 11:50 PM   #4
jackliu0527
Thanks
Works on my 650 running CIC
      04-23-2018, 03:25 AM   #5
bleunetizen
Drives: F13 M6
I had that same problem in my '12 M6, ended up taking it off because I didn't want a non functioning option enabled.. keen to get it to work though!
