      04-21-2018, 01:56 PM   #1
Kkgy79
Drives: 2013 m5
About fuse number
Hello i need ur help. Couldn't figure it out about which fuse for cigarette light.
Im trying to install dash cam thru chigar lighter of fuse box
Also im curious i better hook it up on cigar lighter fuse or exhaust flap fuse?
And what amp fuse necessary for it?
I will appreciate if u guys share that information
Thank you very much
      04-21-2018, 04:53 PM   #2
mastatikle
Drives: m3
The fuse for the cigarette llighter that is near the shift lever is behind the glove box and is a motherfin pain to change and get to. I’d find a different fuse from the trunk or something.
      04-21-2018, 05:10 PM   #3
Kkgy79
Drives: 2013 m5
Yea. I already made a line to all the way back trunk fuse box
But im not sure which number fuse need to be hokked up.
If u have any information please let me know please
5a fuse is enough for dash cam?
      04-21-2018, 06:20 PM   #4
mastatikle
Drives: m3
5a should be more then plenty. I can only speak accuracy for the M6 but there’s empty spots in trunk fuse panel. Some are constant on others are on with ignition. You can fuse whichever you prefer. I know some people want their dash cam running 24/7. I’d do ignition power. Also people have pulled power from mirror assembly.
      04-21-2018, 06:40 PM   #5
Kkgy79
Drives: 2013 m5
Oh i prefer to have ignition one too. I need check 1 by 1 on empty spot?
That is better?
      04-21-2018, 07:14 PM   #6
mastatikle
Drives: m3
Yeah test light with ignition mode on. Varies depending on vehicle options. Mirror route would be better in the sense that it’s cleaner and you don’t have to route and tuck wires to the trunk. There’s a write up for it I’m pretty sure on here
      04-21-2018, 09:03 PM   #7
Kkgy79
Drives: 2013 m5
Ok thank you so much for ur advising.
      04-23-2018, 06:14 AM   #8
Knightro_Circus
Knightro_Circus's Avatar
11
Drives: 2014 M6GC
2014 BMW M6 GC  [0.00]
M6 DIY Post 7 has a write up on wiring a dash cam and shows which Fuse used. Hope it helps.
      04-23-2018, 01:44 PM   #9
Kkgy79
Drives: 2013 m5
Thank you so much buddy
