02-23-2018, 11:59 AM | #1 |
Joint Chiefs of Staff
23784
Rep 190,103
OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
Can be done from home with the use of the Simon Cable. You still have the option to send your ECU to Active direct if you do not wish to purchase the Simon Cable. Active Autowerke offers unparalleled performance software. Through careful remapping of the factory BMW DME tables, various elements such as ignition timing, fuel delivery, and part throttles are reworked to create performance gains. The Active Autowerke upgraded software is designed to operate with gasoline that has an average octane rating with full emissions to create a clean burning combustion with good AFR’s all within factory specifications. Available Options:
Performance Specs:
Attention Florida Customers: If you are local to Active Autowerke (9940 SW 168th Terrace, Miami, FL 33157), there is no need to purchase the Simon Cable. All you need to do is purchase the map from Extreme Power House and drive down to AA for a free install. This is an OBD flash tune, no need to remove the ECU Dyno from a customer. Car mods: Catless Downpipe Note: Car is using stock intercooler. Temps were going over 180 degrees on high RPM which caused the ECU to cut power. A car with a quality aftermarket intercooler will make even more power on high RPM. Same customer, same day same car with Active A piggy. Im posting this A8 dyno to showcase the power delivery difference between the Active flash and their piggy. F30 335 Stock (With Downpipe) vs Active Autowerke OBD Flash Stage 2 +65whp / +109wtq (notice how important a quality FMIC is to this car. it loses a lot of power after 5500 RPM)
05-27-2018, 01:20 AM | #2 | |
Rep 20
How much? m6 f06/f13 |
05-27-2018, 10:20 AM | #3 |
23784
Rep 190,103
I replied to your PM, AA can adjust the burble tune to your liking
