      11-17-2016, 05:31 PM   #1
terrainx
Drives: bmw
Tire Pressure 17 or 16 M6 -Low pressure warning
Stock tires .. what pressure are you running? Less than 1K miles and got the warning light today. Checked all tires and all are exactly the same . . right at/below 130. Door jam says 35 .. curious to know what folks are running on stock and why low pressure warning would all of a sudden pop.
      11-18-2016, 07:03 AM   #2
melvyn
Drives: 2018 M3 CS
You may of hit a pothole to trigger it, I run 2.2 bar all around on stock.
      11-19-2016, 08:37 AM   #3
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
The same thing happened to me last night??
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold)
2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled!
E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold
E39 M5 UUC short shift,UUC Corsa and More Sold
      11-19-2016, 08:01 PM   #4
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
I run 36 PSI all around.
      11-20-2016, 12:20 AM   #5
terrainx
Drives: bmw
I tend to run a bit lower PSI to get a bit more traction. Looks like I'll need to get into the mid 30's to get the nag light to turn off.
      11-20-2016, 07:16 PM   #6
devondragon
If you reset the TPM won't it adjust to whatever is in the tires?
I personally would be worried about handling performance at that low of a pressure... It's a heavy car and can put a lot of force on the rubber, where you don't want it to deform sideways, etc... I dunno. Not my area of expertise exactly, but when the door jam tells me to run 36 PSI for 100+ MPH, then I run 36 PSI
      11-21-2016, 12:20 PM   #7
melvyn
Drives: 2018 M3 CS
Your right, it will reset to you're tyres.
I drive my car on my own with no passengers, I find 2.2 bar (32lb) very good.Tyre pressure soon reach 2.6 bar (37.5lb) and 40c temp when I am in the mood with an outside temp of say 18c.Just to confirm, tyres are 265/35 and 295/30.
Think you may be looking at 4 persons and 4 luggage in your door jam
      11-21-2016, 12:56 PM   #8
devondragon
Nope, I'm looking at the "Over 100 MPH sticker"
      11-21-2016, 01:06 PM   #9
melvyn
Drives: 2018 M3 CS
Never seen one of them stickers before , weird but am not saying it's wrong.What does your plate say for the 295/30 and 265/35
