      04-16-2023, 12:20 AM   #1
ocbambam
Drives: 650i 2007
E85 and sugar put in my tank
hello i bought a 2007 a month ago and was at someones house , and my car and a toyota were vaNDALIZED WITH SUGAR IN TANK, and i ran the car until it died. i have drained the tank flushed the fuel system ,and when i checked the plugs they were carmalized, so i cleaned them and the fuel rail and took each injector and flushed it and put power to it until it was shooting clean , i out all back together and i believe there is no spark ? can anyone steer me in the right direction , fuel pressure is 60 lbs
      04-16-2023, 10:44 AM   #2
Opie55
Drives: '15 650i Convertible
This is actually a 2012+ forum, but what makes you believe you have no spark? Are there any codes at all? At a a minimum, if my plugs were "carmelized" by sugar I would have spent the $80 for new ones. If you put in new plugs, then it's hard to see how sugar could cause no spark. Sugar in the gas won't affects coil packs or wiring. The obvious suspect is still the fuel supply. I have never tried to clean an injector, nor do I know how you did it, but the clearances/tolerances are so close that I'd still suspect them. I do not know what normal fuel pressure is on your car, so I can't comment on the 60lbs.
      04-16-2023, 10:48 AM   #3
Opie55
And I'll also note that your post is little short on details. Like how you drained the tank and how you flushed the fuel system and with what.
