      01-25-2016, 02:04 AM   #1
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
Another Rim ET question
Sorry guys for another question on fitment
Im after a set of bmw wheels which come in at ET :20 for front wheel and 25 for rear wheel
How will these fit on my f13?
      01-25-2016, 10:30 AM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I believe your OEM rims have ET 44 so basically your new setup will stand out 24 mm (front) and 19 mm (rear).. not sure if is fit
      01-25-2016, 12:45 PM   #3
drmlee
Drives: F06 650i
front may work, but be on the aggressive side, rear will probably not but depends on the width, etc. what are the other specs of the wheel? im running 21x10.5 et 35 and with 295/25/21 I had to slightly camber the rear so it wont rub after lowering it.
      01-25-2016, 01:18 PM   #4
Downfourit
Drives: M6 Gran Coupe`
Those are M offsets. They won't fit because the M3/4/5/6 fenders/quarters are flared.
      01-25-2016, 05:51 PM   #5
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No those are not M offset. For 343M rim:
M5 offset is 32 (f), 34 (r)
M6 offset is 31 (f), 19 (r)
      01-25-2016, 06:32 PM   #6
Downfourit
Those are more like the E46 M3 offsets now that I think about it, my point was that they are aggressive enough to fit the M cars, but overly aggressive for the non M cars rear fitment, you could get away with the front, but anything under +30 is going to stick out a bit much on the rear.
      01-26-2016, 02:03 AM   #7
bravo261
Drives: F06 650
likewise here. a 25 on the rear is asking for trouble unless you really know what you're getting into with camber and stretched tires...i strongly suggest you don't go that route
      01-26-2016, 12:55 PM   #8
BMWLad
Drives: 2013 F06 640d
I've got 32et 9j fronts and 25et 9J rears winters on at the moment. Both fit very flush to the arches.
What width are you looking at? The 9j fronts are closer to the front suspension knuckle there is enough clearance but I wouldn't want to go any closer.
      02-18-2016, 04:13 PM   #9
drmlee
Drives: F06 650i
295 isn't stretched on a 10.5 rim. I added less than 1 degree of camber, 0.7-0.8 degrees of camber as it would rub slightly when I didn't. now im fine even with 4 people in the car. it looks and drives normal. definitely not what the jdm/vip/stance guys are doing.
      02-18-2016, 08:50 PM   #10
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
What width are the wheels? Offset is the distance from the centerline of the wheel to the hub mounting face so that's kinda important.
      02-25-2016, 12:14 PM   #11
bravo261
Drives: F06 650
i didn't say anything about 295 tires...i did say that a 25 offset would require stretched tires, camber adjustment, and lots of luck.
i had 245s on a 10.5" on my GS, and that got to be too much at my age.
      03-03-2016, 08:16 PM   #12
drmlee
Drives: F06 650i
my mistake, I thought you meant me running a 25 series sidewall.
