12-26-2016, 05:23 AM | #23 | |
Rep 15,858
There's a clever, but quite complex, double sun and planet gear drive with a clutch pack, one a side for each drive shaft. The closed clutch is (from memory) a 1.1:1 ratio. So driving with a bit of purpose, sensors (including the steering sensor) feeding back data you are entering or in a bend, closes the clutch on the outside wheel, increasing the speed of the drive shaft on that side of the vehicle, (up to 1.1:1). Clutch slip compensates for the exact wheel rotational differences side to side, or one wheel would have to slip or spin. We understand that slip, as it's similar to the transfer box clutch pack in the xDrive, which moves torque rear to front. That extra (geared up) wheel speed translates as extra torque to the outer wheel. Helps for a more neutral turn in, using the outer rear wheel to help reduce the tendency to understeer. Shame it is so complex, or we'd likely see it available for less expensive models. The concept makes so much sense for press on driving. |
12-26-2016, 03:44 PM | #24 |
Rep 168
Torque Vectoring
High Pete
Yea I climbed under my X3 with x drive, and I don't see any clutch housings on the axles, unless its built into the diff hub. So x drive must use the brakes. Perhaps the Go1 will upgrade to this. Bailyhill
Current: "17 i3 REX; X3 30e
History: '67 911S, '72 MB 280 SE 4.5; '74 2002, E21 ('78 320i, E28 ('85 535i) , E36 ('90 325i), 6 Volvos; '14 ForTwo eDrive; '15 i3 REX, F31--'15 328 D Sportwagen; F25 LCI '16 X3 D |
12-26-2016, 04:52 PM | #25 | ||
Rep 15,858
12-27-2016, 11:53 AM | #26 |
Rep 1,213
No it won't be. It will have an xDrive 'option'
11’ E92 ///M3
15’ F82 ///M4 18’ G30 540i ///Msport 21’ G20 ///M340i 24' i20 iX xDrive50 |
12-28-2016, 06:22 AM | #28 |
Rep 6,299
Reportedly it will be,
http://www.roadandtrack.com/new-cars...r-wheel-drive/ |
12-28-2016, 11:25 AM | #29 |
Rep 1,044
