03-07-2018, 10:42 AM | #1 |
Rep 124
Launch Control or Skill?
Who's leaving the line using launch control?
I've personally never used LC. I leave in (my M1) MDM, suspension COMFORT, and all other settings on maxed. After i catch respectable traction i hit (my M2)DSC OFF, and alll other settings maxed out. What are you guys using? |
03-07-2018, 04:57 PM | #2 |
Rep 469
You know I never thought about switching from one setting to another under load or mid pull (m1 to m2). I feel like that takes time away and more importantly might hurt something. Who knows might be safe. Launch control is useless in the M6, too much torque and not enough traction so excessive wheel spin and tire smoke is the result of using launch control. I launch with MDM on and off foot break. Trans on lv2, smoother in my mind.
03-07-2018, 07:12 PM | #3 | |
Rep 804
03-08-2018, 09:09 AM | #4 | |
Rep 469
03-08-2018, 11:38 AM | #5 |
Rep 804
I don't touch it, I just launch at the preset rpm which i think is right around 3k. Those tires made a world of difference and I even drive them in the rain cautiously, although I don't recommend it, I haven't had any issues or scares like hydroplaning or loss of traction.
03-09-2018, 06:15 AM | #6 | |
Rep 124
03-09-2018, 11:39 AM | #7 |
Rep 804
Unfortunately no, I live in Socal where there are no decent tracks and the only one close to me is hours away, once you finally get there you are lucky to put in two runs. With drag radials it's a whole different ballgame, the oem tires were like driving on hard plastic compared to the Nittos. It's not just that you can launch better, but you can drop the car into second at 40-50mph and have traction all the way through the rpm band and before i would lose traction even in 3rd and 4th gears.
03-25-2018, 09:47 AM | #8 |
Rep 106
I switched to 315’s in the rear and makes all the difference in the world. Never tried LC, need to try with new tires. I used to feather the throttle but now I can smash and go. I’m also tuned with DP’s.
2014 ///Ⓜ️6 ⚪️ Comp. Package
| Adv.1 5.2 Track Spec CS Series| Down Pipes | KW HAS | K&N Air Filters | Charcoal Filter Delete | RPI Air Scoops | 2012 RUBICON 🌐|||||||🌐on 4d's Last edited by gab24m3; 03-25-2018 at 10:21 AM.. |
03-25-2018, 07:25 PM | #9 |
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
still on the zero's on stock size and you guys are right, that tire SUCKS. GOing to be upping the size to 305's and 4S's soon for better traction. Also, what is the launch control procedure? I remember it being super convoluted lol
03-26-2018, 01:08 AM | #10 |
Rep 804
Car warmed up to operating temps, all traction systems off, 1st gear in manual mode, foot on the brake, tilt the shifter forward and hold it you'll see the flag icon, fully depress the gas pedal, you can adjust the launch RPM from the steering wheel, take your foot off the brake and let go of the stick keeping the gas pedal depressed, off she goes
03-30-2018, 10:28 AM | #11 |
Rep 15
This car is tricky to launch, even with launch control depending on Tires/Mods.
I coded my M6 with Euro MDM mode (allows more wheel spin, before traction control kicks in compared to US MDM Settings) MDM-Sport Plus-Sport EDC |
03-30-2018, 09:42 PM | #12 |
Rep 238
Drives: BMW M6 comp
03-31-2018, 12:51 PM | #14 |
Rep 238
Drives: BMW M6 comp
04-01-2018, 12:37 PM | #15 |
Rep 804
