      06-09-2017, 12:51 PM   #1
kennis827
Costa Rica
Drives: Bmw
Arrow My 0 to 60mph times, how about yours?
Hi Guys i have an m6 coupe competition package 2014, i am using plx kiwi3 (with dash command app)to measure my 0-60mph times, a lot of guys says that without launch control the car moves faster from 0, modulate the pedal and do a little bit burnout to warm up tires before to avoid wheelspin, after 8 runs my times are between 4.8s to 5.2s i think something is wrong there, usually our m6 should be making 3.6s to 4.2s, my car has no fault codes after scanning, any idea of what it could be?
what are your times?
my tires are stock mssp with 80% tires remaining using 32psi all around, mode:
traction off, sport plus, S3.
my stock x6m 2010 hits 4.5s and the specs says 4.3s which is acceptable, but 1.2s is way too much :/
      06-09-2017, 01:24 PM   #2
KauvSTi
Super Member
KauvSTi's Avatar
129
Drives: M6, M8 Comp, S63, 720S, F8
I think you should factor in your tires, pavement type, launching or not launching and much more. I've lunched mine hitting 3s so I think you should probably factor all of the above in.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust
      06-09-2017, 03:28 PM   #3
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No launch control.
Using manual shift (S3) you should modulate the gas unto 4k and then floor it. Shift up when your rev shows 6.5k ...
There are many videos and reported that M5 can hit 60 mph in 3.7 second so for sure your M6 can be faster...
Flying Ace4984.50
      06-09-2017, 05:16 PM   #4
KauvSTi
Super Member
KauvSTi's Avatar
129
Originally Posted by M6-Coupe View Post
No launch control.
If anyone know its this guy! He's hit 2.9s in his M6 lol
      06-09-2017, 05:45 PM   #5
kennis827
Costa Rica
Drives: Bmw
hi thanks for your reply, pavement type i dont think so bcuz the x6m i ran in the same road and hits the proper time, also tried different highways and same results! im launching well without any wheelspining since i burnout the tires before runing.
      06-09-2017, 05:46 PM   #6
kennis827
Costa Rica
Drives: Bmw
No launch control.
yea i did that, since you said that on another thread, i didnt wheelspin cuz i did burnout! still dunno what it can be...
      06-09-2017, 06:57 PM   #7
ARC550
Drives: M3, X5, 720s, X5, 750xi
2.8 sec. 0-60mph confirmed on Vbox.
200M6H- FTW
      06-10-2017, 08:14 AM   #8
M_PWR
Drives: BMW F13 M6 Coupe
Yeah and motor trend did a 3.7sec 0-60mph with an M5 so should be mid to high 3s surely.
      06-10-2017, 04:18 PM   #9
M5 London
334
Drives: F90 M5 LCI - Aventurine Red
But that's four wheel drive which means driver skill is not required!
With the M6 you need quite a bit of skill to launch it well.
Also what have you done to your suspension? It seems very much lowered.
This is also most likely not helping weight transfer to the rear axle when accelerating off the line which helps with grip from the driven wheels.
Also make sure you dampers are in the softest setting to help with this weight transfer
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf
      06-11-2017, 12:29 PM   #10
speedracerlo
Drives: 2015 M6 Gran Coupe
You have too much nonaerodynamic mods! It's catching the wind like a sail and slowing you down! lol jk
      06-11-2017, 07:00 PM   #11
kennis827
Costa Rica
Drives: Bmw
That the irregular ground effect my car has stock suspension never lowered,in regular surface it looks much higher 😅
With LC or without im doing same times 4.8-5.2s i almost dont spin my wheels..
      06-11-2017, 09:09 PM   #12
Nawwledge
Fast Lane
Drives: BMW M6, BMW X5, Mercedes S550
Hi there!
My personal best was 3.7 seconds. As M6-Coupe stated above, modulating the throttle is key. Also I'm sure you are doing something wrong whilst launching - there is no way any normal F12 M6 coupe is doing over 4 seconds.
My personal setup consists of:
sportiest throttle response, sportiest gear change, comfort suspension, manual shifting mode, MDM mode
I haven't ever intentionally done a burn out in my car (tires are expensive yo), but I'm sure that would only help my time. A lot of the magazines have got the M6 in the 3.7-3.9 range with ease, and the last comparison test on C&D got it at 3.5 (although I have my doubts about how they got that number). Keep trying, change your method of calculation, and worse comes to worse go to the dealer to make sure your car is in good condition.
Cheers,
Khan
      06-11-2017, 10:08 PM   #13
kennis827
Costa Rica
Drives: Bmw
Originally Posted by Nawwledge View Post
Hi there!
Cheers,
Khan
Hi! Thanks for your reply, what tires pressure are you using? And dud u got better times using launch control or without?
      06-13-2017, 11:51 PM   #14
wujekwaldus
wujekwaldus's Avatar
Poland
118
Drives: 458,Huracan Spyder,G500
my best 0-60mph "american style" (1ft rollout) with stock M6 CP 2013 is 3.3 or 3.2s but i cannot find vbox graph for my best - so let's take "an average result"
      06-16-2017, 08:22 AM   #15
Msizzle
Drives: 2013 M6 Coupe
your first major problem is timing something so precise with a cell phone, you need a vbox. the phone can "feel" the squat and start the clock before you even move.
      06-16-2017, 12:19 PM   #16
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Well I had discussion with a member long time ago. I was claiming 3.6 and mentioned C&D reported 3.5 second.... regardless of our discussion, 3.2 or 3.3 with this RWD car is kind of unrealistic unless you are using very sticky tires under certain condition/slope or special dragstrip. M6 has enough power and torque (despite the weight) to beat those numbers but the issue is traction ... I'm sure if it was AWD, it could do 3.2 -3.3 second...
Let's see how the new M5 or M6/M8 with AWD can change the game
      06-17-2017, 07:27 PM   #17
M5 London
334
It's the (1ft rollout) he decided to tick as an option whilst measuring his times.
      06-22-2017, 09:23 PM   #18
kennis827
Costa Rica
Drives: Bmw
Hi! Thanks for your reply, what tires and tire pressure did you use? Also did u use launch control or not? If you can provide some settings will be appreciated!!
