      09-23-2015, 09:23 AM   #1
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
F13 Wheel Spacers
Hi chaps.
Im looking for spacers for my 640d... I like them wide but not rubbing... Is 25mm rear and 20mm front too much?
      10-01-2015, 01:58 PM   #2
UPWheels
UPWheels's Avatar
52
Drives: E60
What are the specs of your wheels? (size, offset, and width)
      10-02-2015, 12:07 AM   #3
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
373m - f: 20x8.5 et33 / r: 20x9 et44
      10-02-2015, 01:30 PM   #4
UPWheels
UPWheels's Avatar
52
Drives: E60
f: 20x8.5 et33 + 20mm spacers = +13 Fronts
r: 20x9 et44 + 25mm spacers = +19 Rears
You shouldn't experience any rubbing as long as optimal tire sizes are used. Fronts will be flush, and you should have a bit of extra space for the rears.
      10-02-2015, 02:02 PM   #5
Zack G.
Extraordinaire
Zack G.'s Avatar
Drives: '14 650i MSport CP
Please post pics when you add spacers! I am considering them as well and was wondering the same thing as I have the OEM 373M's. I would also consider lowering on H&R springs if I added the wheel spacers.
      10-03-2015, 12:15 AM   #6
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
Thanks bud, my tire setup is standard runflat low pros. Whar does the +13 +19 mean?
      10-03-2015, 12:16 AM   #7
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
I have a steep drive do doubt ill lower, dont think it sits too bad as it is IMO
      10-05-2015, 04:19 PM   #8
UPWheels
UPWheels's Avatar
52
Drives: E60
The above numbers are the offsets.
Front ET13 or +13
Rear ET19 or +13
What tire sizes do you currently have?
      10-05-2015, 05:12 PM   #9
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
Front ET13 or +13
Rear ET19 or +13
275 30 R20
      10-05-2015, 07:27 PM   #10
UPWheels
UPWheels's Avatar
52
Drives: E60
275/30/R20 is your rear tire size. What size are the fronts?
      10-06-2015, 01:31 AM   #11
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
245/35/20
