      06-03-2018, 07:58 PM   #1
hl0m4n
hl0m4n's Avatar
Arrow ► Outlets Not Working
it seems my outlet under the passenger glove box and center console (smaller smoking bin) is not working.
i plugged in my v1 adapter in both sockets and nothing; then i tried a usb outlet charger in both and same result.
the only outlet that is working is in the main center armrest (the one with the trunk lock switch).
could it possibly be a blown fuse? thoughts on how this should be troubleshooted?
      06-04-2018, 06:06 PM   #2
mrjsmith88
mrjsmith88's Avatar
151
Drives: 2017 BMW X5M
2017 BMW M3  [9.50]
Usually when that happens I check my fuse in the glove box 89.9% of the time it is the fuse..
      06-05-2018, 09:04 AM   #3
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
fuse is the most likely culprit. Good luck getting your hand in there.
      06-06-2018, 12:11 PM   #4
Malik550
Drives: F06 Gran Coupe
You need octopus arms in order to access the fuses inside the glove box. That or take the entire dash down. Worst placement ever.
      02-28-2020, 09:32 AM   #5
e93335i
Drives: 2010 335i E93
I have a 2013 640i M Sport F12 - and for me fuse 54 20A (Yellow) fixed all 3 of my outlets:
- Center Console
- In the armrest next to the Aux in
- Under the glove box
Fuse 54 is located behind the glove box and I used the plastic fuse holder clip - which I found in the fuse box in the trunk. I attached a picture of the fuse box layout and a photo of the actual fuse (Yellow Arrow) behind the glove box - for you to see which one is 54.
It was easy for me to remove the fuse and a little tricky to replace it. It's not as hard as it initially looks - and I don't have the smallest arms or hands.
Good luck.
      03-02-2020, 02:01 PM   #6
e38740imd
Drives: 2016 640i
dont need to pull the dash, just the glove box which is real easy. i changed my brown glovebox for a black one
      03-02-2020, 02:21 PM   #7
Qsilver7
Qsilver7's Avatar
Harbor Freight: 11" long reach needle nose pliers $3.99.
