      06-16-2016, 07:49 AM   #1
cartaa100
cartaa100's Avatar
Drives: 335i, 640i, X6M50d, X3M40i
Where is the neutral/earth on the f12 cars?
Hi guys,
Sorry very nooby question, however I've just installed a jb4 for my 640 and I'm occasionally getting drive train malfunction and occasionally stalling when coming to a stop.
I have it currently attached to the washer bottle bolt as it seems to work better than the strut braces...
So the main question where is the neutral terminal/earth/ground??
THANKS!
      06-16-2016, 09:34 AM   #2
Elfresh
Drives: 2009 BMW 335i
Use a circuit tester (not required)
however usually anywhere with bare metal is a good ground, just take off a bold sand under the bolt and around the area
reattach the bold with wire in that area and it'llw ork just file
      06-17-2016, 03:58 PM   #3
BDO
Drives: 2016 X6 40d M-sport
Why do you think it's the earth? Have you done logs and scanned for errors?
      06-22-2016, 08:05 AM   #4
cartaa100
cartaa100's Avatar
Will be logging on Monday, the reason for thinking its the earth was because the car would run better when earthed in different areas
