      09-28-2015, 12:39 PM   #1
Kopex47
England
Drives: 640d Msport Alpine White 2012
Sideskirt removal help
Does anybody have info on the procedure to do this.Have looked for a workshop manual and cant find one.I have damaged the drivers sideskirt on my recently purchased 640d in alpine white,some help would be much appreciated.cheers
      09-28-2015, 12:50 PM   #2
M6Havana
M6 f12 Havana
M6Havana's Avatar
124
Drives: M6 Cab
There is both sides ive seen for sale on ebay.. Not sure if that helps. Alpine white too
      09-28-2015, 03:28 PM   #3
vaio23
Drives: 650I
I took mine off easily. Just remove all the bolts from the underside of the car, door stills and clips underneath, then pry the off by the front and rear fenders. Come off pretty easy.
      09-29-2015, 02:01 AM   #4
Kopex47
England
do you have to pry off the M kick plate and the black strip that sits on top of it aswell or will the sideskirt come off seperately?
      09-29-2015, 10:15 AM   #5
vaio23
Drives: 650I
You need to pry off the kickplate, be careful it has small white clips that break easily. Once the plate is removed you will see several black clips underneath attaching side skirt to car. Remove these and the ones underneath the side skirt (under car). The plastic strip stays in place it doesn't detach.
      09-30-2015, 06:28 AM   #6
Kopex47
England
Thanks very much,much appreciated!!
