      06-30-2014, 02:11 PM   #1
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Thumbs up AMS turbo upgrade is out!
http://ind-distribution.com/ind/bran...bo-upgrade-kit
Apparently makes 685 whp without the tune on 93 pump, imagine what it will do with BMS piggy back!
A very slow older rwd Mercedes e63 amg did 1/4 in 10.7 secs just by upgrading turbos
I think it's worth a try, anyone else?
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      06-30-2014, 02:41 PM   #2
meshoooo
meshoooo's Avatar
Kuwait
Drives: M6 GC SG, X6M LBB, M5 SB
need to hear also here
      06-30-2014, 03:56 PM   #3
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
By upgrading the turbos I am sure you would need access to change mappings in the ECU to make the new turbos work effectively/efficiently/safely.
I cannot imagine slapping on new (I am guessing bigger) turbos w/o changing the mappings is the smartest thing to do?! Has anyone addressed this part of the equation yet?
Brian
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      06-30-2014, 04:08 PM   #4
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
OK... So I thought what the hell and picked up the phone and called IND. Yes, the hardware (turbos) are available but without any software there isn't much gain. The DMIs see the extra boost and make changes to the rest of the engine to compensate and "bring the car back down to reality".
I was told IND's shop F10 made 590wrhp with the new turbos (no piggy back) -- this isn't a huge gain.
Brian
      06-30-2014, 04:29 PM   #5
Tom C
Drives: M8 GC Comp, Shelby GT500
Originally Posted by bigbrian View Post
OK... So I thought what the hell and picked up the phone and called IND. Yes, the hardware (turbos) are available but without any software there isn't much gain without having software. The DMIs see the extra boost and make changes to the rest of the engine to compensate and "bring the car back down to reality".
Brian
Yup, even if you throw a BMS piggyback on there to "fool" the DME into thinking it is producing less boost the problem is going to be fueling. The stock DME is not going to be able to keep up with additional fueling requirement. Until that is solved, I wouldn't bother with a turbo upgrade.
      06-30-2014, 04:35 PM   #6
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
Brian
+1
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
      06-30-2014, 04:53 PM   #7
mr-karim
mr-karim's Avatar
Do you think we will ever have a full tune available for our cars?
      06-30-2014, 07:16 PM   #8
EuroKar
Absolutely. Needs the correct DME software to make necessary changes for a turbo upgrade.
Not worth a purchase without it.
      07-05-2014, 04:39 AM   #9
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
Can't we use water/meth to compensate on the extra need of fuel issue?
      07-05-2014, 07:09 AM   #10
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
This.
      07-07-2014, 10:02 AM   #11
EuroKar
No you cant. Need correct software to run efficiently.
      07-07-2014, 10:03 PM   #12
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Maybe someone can make a piggy back that taps into the fuel nozzles so we can trick the nozzles into spraying more.
<kidding>
Brian
Tags
bmw m6, m6 tune, s63tu, turbo upgrade
