      06-09-2022, 12:33 PM   #1
fpvsportsguy
Drives: 2015 F83 M4
PSA on coolant leaks
So for the S63 engine (and maybe even the n63), the overflow tank return hose seem to be a common failure point at one of the unprotected junctions. It's at the driver's side right underneath the side cowls. One end goes to the tank, one end goes to the top of radiator. Mine had a crack and I was losing a fair bit of coolant. First I thought it was the turbo coolant pipes underneath the engine cover, which is also a pretty common failure point due to heat cycling (mine was leaking a little bit, but not catastrophically), but after fixing that I still had a leak, which led me to do a thorough search and found the leak on the tank return hose. It's a pretty simple replacement, part number is 17127599571. Just thought I'd share.
Rolling the dice with high mileage German cars
2017 G30 530i, 119k miles
2016 F33 428i, 85k miles
2015 F36 428i GC, 155k miles
2013 F07 550i GT, 125k miles
      06-09-2022, 08:21 PM   #2
JBF650
Drives: 2015 F13 LCI 650i Coupe
thank you for sharing! I do periodically remove the vanity cover ( usually to wash down the dust and general washing cleaning of the engine bay every few months) to check for any obvious leaks etc etc . This is a good thread to share thank you, ill check these next time i wash the engine bay down.
cheers
      07-01-2022, 06:09 PM   #3
Chief F1 Fan
Chief F1 Fan's Avatar
51
Drives: 650i xDrive Gran Coupe, 335xi
I'm trying to figure out why my N63 motor keeps throwing off a "Low Coolant" warning when I open the hood, open the reservoir and it's full? Ideas? Faulty sensor? Should something be floating to the top of the level of the coolant?
EDIT: BMW's s#%tty manual sez nothing of an additional reservoir to fill with coolant, thank god for YouTube
2014 650i xDrive
2018 Mazda CX-9
2019 BMW 330xi
2023 911 Carrera S 7 Spd. ordered
      11-22-2023, 04:36 PM   #4
Cadmus130
Cadmus130's Avatar
Drives: 2008 BMW 650i
2008 BMW 650i  [5.00]
So my 08’ 650i (N63) has just sprung a coolant leak. All I can tell is that it’s coming from somewhere in front of the engine and leaking directly underneath the middle.
It seems to only leaked when it’s hot after I’ve parked. Then it stops once it’s cool. After four days of this, my reservoir is finally dry. I’ve topped it off with distilled water per the suggestion from a mechanic I know and I have an appointment Friday to have it looked it.
I know it’s a shot in the dark, but does anyone have any suggestions? I’ve heard a lot of talk on here about these cars and leaks…
I just bought this car a week ago for cash, 134,000 miles, cheap. She runs beautifully, this is the first issue I’ve come across. Any help is appreciated!
